40" Sony LCD KDL-40EX500 Seconds to black (6 blinks)
  • tieny
    • Feb 2012
    • 478
    Just picked up a sony KDL-40EX500, the initial owner said it would turn on and then off then it would blink 6 times in a repeated cycle. There was also a repair estimate saying it is the Static Converter (Guessing the power supply?) that is the cause.
    I plug in the TV and there are 6 blinks. Turn on the TV, the sony logo pops up normally, then it goes to the HDMI input screen and it suddenly shuts off and repeats this cycle 3 times then finishes off by blinking 6 flashes .
    When it goes to the HDMI input screen I notice that the backlights become much dimmer.
    Doing some googling, I've read that 6 blinks states a problem with the inverter board? (confused since the repair company concluded that its the psu?)
    Tore the tv down to its backlights and watched the CCFLs but they all seem to be working. It would brighten up intensely then dim to half intensity (as when it goes to hdmi input) then shuts off and repeats.
    I also measured the 24V pins to the inverter and am reading 26V on each (is that a little high?). Also when the on and off cycle finally stops I notice that the 26V slowly and gradually drops down until it hits zero (doesn't it usually immediately drop to zero?).
    Any ideas to whats wrong?
    Re: 40" Sony LCD KDL-40EX500 Seconds to black (6 blinks)
    Check BL-ON or ON/OFF.
    Dimming may be normal. Some TVs dim the screen with no picture, to save power.
    • tieny
      • Feb 2012
      • 478
      Checking BL_ON, I get 0.054V as soon as I hit the power button, and it goes up and stays steady at 3.29V when the lights come on and as it cycles through the on and off.
      ON/OFF (Is that the same as Power_ON?)
      Measuring Power_On, I get 3.32V steady when I press the power button through the cycle.
        ON/OFF == BLON.
        So, BLON is steady, even when backlights go out?
        Can we have a picture of parts of the chassis?
        • tieny
          • Feb 2012
          • 478
          Actually no, it stays steady at 3.28V once the lights go on and then drop back to 0.05V when it goes off, and repeats
            Mkay, is there an ERROR or ERR signal labelled on inverter?
            • tieny
              • Feb 2012
              • 478
              Yep theres a BL_ERR. It measures 3.3V on standby and once the backlights turn on it drops to 0.04V then back up to 3.3V when off, and cycles
                So, it is signalling an error.
                Can I make a suggestion: Cut BL_ERR and force it low, using a 100 ohm resistor. Then see if the cycling continues. If not, then you need to suspect the inverter board itself.
                • tieny
                  • Feb 2012
                  • 478
                  Which one should I cut? theres one output going to the main board and one going to the inverter. I'm guessing the one leading to the inverter? I'll have to find a 100 ohm resistor from a salvaged board.
                    One from inverter to main board; the signal is a message from the inverter saying "houston, we have a problem", main board says "shit guys! let's shut this whole show down" and then restarts.
                    • tieny
                      • Feb 2012
                      • 478
                      Kind of confused, the inverter board isn't directly connected to the main board. Or I'm guessing it goes through the psu first?
                        Yep, it just goes thru PSU to reduce wiring clutter.
                        • tieny
                          • Feb 2012
                          • 478
                          Just put the 100 ohm resistor in place. I'm still measuring 3.3V on the BL-ERR though and theres no change at all.
                            On which end is that?
                            The BL_ERR on PSU needs to go to ground thru 100 ohms. Inverter side disconnected. Is this what you have done? But you still measure 3.3V?
                            • tieny
                              • Feb 2012
                              • 478
                              Ohh okay, it was on the side going to the inverter. So the right end of the resistor should go to ground?
                              • tieny
                                • Feb 2012
                                • 478
                                Alright just grounded it, okay now it turns on normal, sony logo comes up, goes to hdmi input, then backlight shuts off. With a flashlight I can see the input and also when the menu if I bring it up.
                                So the cycling stopped, thus the problem is with the inverter board itself?
                                  Yep.
                                  Gonna need a pic of the inverter.
                                  • tieny
                                    • Feb 2012
                                    • 478
                                    Here it is.
                                      OK, I'd suspect the transformers (test secondary resistance); if it's not that, could be the bulbs in the panel.
                                      • tieny
                                        • Feb 2012
                                        • 478
                                        Those are the pins toward the output to the ccfls correct? Do I just measure the resistances in circuit? pins 1-2, 1-3, 1-4, 2-3, 2-4, etc?
                                        I also have an inductance meter.
                                        Heres a video of the backlights when I tore it down
                                        http://www.youtube.com/watch?v=AVvDn...ature=youtu.be
                                        All the lamps seem to turn on fine. Would it still be a bad transformer?
                                        • mauda
                                          Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                                          by mauda
                                          I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                                          Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                                          05-21-2023, 11:56 PM
                                        • tec3000
                                          Sony LED 65X9005A shuts down after few seconds - looking for help
                                          by tec3000
                                          Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                                          I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                                          03-20-2024, 07:29 AM
                                        • AK_777
                                          Sony KD-65A1 Repair – 4 Red Blinks Error
                                          by AK_777
                                          Hi everyone!
                                          I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                          Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                          02-20-2025, 04:15 PM
                                        • jchon
                                          Sony A1e 5-blinks help
                                          by jchon
                                          Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                          I found the service manual, which was critical to know where to probe.
                                          https://www.manualslib.com/manual/20...1e-Series.html
                                          With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                          Unfortunately the 5-blinks...
                                          06-28-2023, 11:52 AM
                                        • Nicktronic
                                          Sony XBR-65X850D 2 Red Blinks
                                          by Nicktronic
                                          I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
                                          Any Sony experts out there that can help??...
                                          11-19-2023, 06:51 AM
