Sony KD-65A1 Repair – 4 Red Blinks Error
  • AK_777
    • Oct 2019
    • Украина
    Hi everyone!
    I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
    Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and TCON into standalone mode.
    Initial Diagnostics
    As in many similar cases, disconnecting the lower ribbon cable from TCON helped bypass the error – the LED turned white, which theoretically meant that the TV was working correctly. However, I did not hear any sound.
    I tried updating the device via USB – saw white blinking, then the LED turned blue.
    From the beginning, I noticed a yellow spot (photo 1) in the lower-left corner of the panel frame, but I initially ignored it, thinking it was some sort of indicator or sensor.
    Repair Attempts and Unexpected Results
    After unsuccessful attempts with taping the EVDD_RESET and ERROR_DETECTION contacts, I finally tried OLED panel standalone mode.
    The result (photo 2) was disappointing – no image appeared, and there was a dark spot resembling a broken panel.
    Upon flashlight inspection, no visible cracks were found in that area.
    Hypotheses and Questions
    At this point, my assumption is that a factory defect in the lower-left corner caused a short circuit, which:
    Melted the glass, leaving a noticeable bump.
    Possibly damaged the decoders on the panel and TCON.
    Unfortunately, there is no access to the panel’s boards where the decoder ribbon cables are attached – the rear part is sealed with glass.
    My main questions now are:
    1. Based on the photos, is there any chance of getting some kind of image from this panel?
    Given OLED panel construction, a 24V power line runs along the perimeter of the panel (inside the frame). Since there is no more short circuit, does that mean the circuit is broken – and could this affect TCON signal output and the error state?
    2. Theoretically, if I grind down the affected area with a rotary tool and restore the circuit using conductive adhesive, could this at least partially revive the panel (fully aware that the black spot will remain)? Or is it completely beyond repair?
    Looking forward to hearing from anyone who has encountered similar issues!
  • Diah
    • Feb 2013
    • 6496
    panel look out not good.. but you want to see image on it... then just remove all your masking of t-con error etc.
    just disconnect EVDD socket on T-CON. then turn on.. see the optical port on Mainboards will lit red and remain on.... ?
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4515
      • Italy - Milan
      Child case, broken panel, shock..
      • markolino
        • Mar 2020
        • 109
        • Slovenia
        Originally posted by AK_777
        Hi everyone!
        Initial Diagnostics
        Click image for larger version  Name:	PXL_20250210_120117146.jpg Views:	93 Size:	2.19 MB ID:	3577160
        Hello. Do you still have the Sony KD65A1 TV at home?
        Thank you.
        • iglitare
          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
          by iglitare
          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
          Backlight seems to work, Sound (Setup menu after reset) works.
          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
          With my small knowledge i would think at least the cables are good.
          Can this happen because of a bad tcon board?
          Or is it always a bad/shorted...
          09-04-2025, 07:13 AM
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • rimwall
          Sony KD-65x8500b - bad Tcon or panel?
          by rimwall
          Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
          a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
          b) the Tcon board is malfunctioning,...
          10-24-2023, 07:58 PM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • swrb898
          Sony KD-70X690E Bravia; Bad TCON? Bad panel?
          by swrb898
          What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
          Problem:
          Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
          My troubleshooting got me this far:
          With the left-hand TCON to bottom-board ribbon cable...
          12-28-2021, 08:12 PM
