Olevia 265FHD problems!
  • akk944
    • Aug 2012
    • 60
    Hi guys!
    I was just surfing around craigslist and picked up a 65 inch LCD the other day. I knew it was bad before getting it, but need some help with this one. Unlike every other TV I ever worked on, it has two power boards. When you try flipping the TV on the "Olevia" screen pops up and then the screen cuts off. However, the LEDs on the board with all the inputs remain lit. You can turn the TV "off" after this happens as well and when you turn it back on the process starts all over again. I examined both PSU's and I don't see any obvious bad caps. However, one of the power supply boards makes a weird winding winning sound before the TV cuts off unlike the identical board right next to it. Does anyone have any idea what this problem sounds like? As usual, any help would be much appreciated! Thanks
    Re: Olevia 265FHD problems!
    Please up load the good clear pictures of the boards and how they are connected, that will be the starter. Make sure to use 'GO ADVANCED' to up load the pictures.
    • akk944
      • Aug 2012
      • 60
      Alright here's what I've got so far. I need to take out a lot more screws in order to get pictures of the inverter boards.. which may be the problem because my symptoms are identical to this guys.
      https://www.badcaps.net/forum/showth...ghlight=olevia
      However, check these pictures out and see if there's anything I should start off with. Thanks!
      • gilly1984
        • 751
        Do you have a multimeter?
        Can you start taking voltages and let us know them.
        Also can you take some nice clear close ups of the connectors so we can see the pinouts.
        Do NOT touch heatsinks when testing for voltages as they may be LIVE!
        • akk944
          • Aug 2012
          • 60
          I do have a multimeter, but don't know where I should be taking voltages from. I'll take pictures of the connectors and put them up in a few. Thanks!
          • drpj23
            • May 2012
            • 528
            You should see a legend by the connector for the voltage on each corresponding pin. Put the red probe in the connecter (get it to touch the wire) and the black probe on the chassis (ground). The meter should be set to DC.
            ...hmm those caps look like rubycons, wonder if it has been recapped - never known Olevia to have quality components - but also didn't know they made 65" TVs either
            • akk944
              • Aug 2012
              • 60
              Here are the pictures! I will take voltages tonight, but in what state should I take the voltages? Also I was reading and I think that the caps are original based on what others have said online as well as the person I got it from.
                Those caps look original. They are Rubycon and United Chemicon, very good caps. Not typical RadioShack replacements, so they are most likely original.
                • drpj23
                  • May 2012
                  • 528
                  Wow, well that is a very good thing.
                  Take the voltages while the set is on.
                  The TV sounds like a 2sec to black thing - can you see a pic with an external source of light?
                  There is an inverter board on this TV - can you include a pic of that as well? (Is that what you are referring to as your second power board?)
                  If it is causing whining then it more than likely sounds like a bad inverter transformer or even CCFL.
                  But first verify voltages.
                  • akk944
                    • Aug 2012
                    • 60
                    Yeah that's what it seems like. I didn't get time to take the voltages yet, but will do that tomorrow along with take picture of the inverter boards (there are more than one I think!). What do you mean by a picture with an external light source? Thanks!
                    • Phaihn
                      • Jan 2009
                      • 842
                      means the sun or a lamp not useing the flash on the camera. edit i think he means shine a flashlight at the screen and see if you can see a picture.
                      My Computer.
                      AMD APU A4-3300 2.5ghz 1mb cache
                      Motherboard GigaByte GA-A75M-S2V
                      Kingston HyperX Blue DDR3 8GB (2x4GB)
                      SB Audigy 2 ZS [B800] Sound Card
                      500GB WD Caviar® Blue™
                      1 Terabyte WD Caviar® Black™
                      2 Terabyte WD Caviar® Black™
                      • akk944
                        • Aug 2012
                        • 60
                        Alright I will do that in the morning. Thanks!
                        • drpj23
                          • May 2012
                          • 528
                          Although the backlights are off, the main is probably still processing the picture on the screen. You can prob see a menu with a flashlight or some light source.
                          Generally, I use a overhead fluorescent and lay the TV back while adjust my viewing angle and turning on and off the menu.
                          If you can manage to see an image somehow then it just verifies there is a problem with the backlight section of the TV.
                          • akk944
                            • Aug 2012
                            • 60
                            Alright, well I will probably try starting off with a flashlight. The TV is heavy (5 year old off brand 65 inch LCDs are NOT light!) so moving it around would't work too well.
                            • akk944
                              • Aug 2012
                              • 60
                              Okay well I didn't get around to checking voltages STILL but I did try using my little harbor freight LED flashlight to see if I could get a picture... with no luck. Is it possible that I need something more powerful or am I hitting it with the wrong angle? Please let me know. Thanks!
                                I have to say I've only seen the flashlight trick work on some LCDs. It doesn't work on all of them.
                                • LBN
                                  • May 2013
                                  • 4
                                  Akk944 I want to thank you for you pictures. Specially of the Main Board LED's. I have a 265fhd-t11 that the the audio has gone out on. It only get clicking noise from internal speaker. and if I connect external speakers I get the same clicking noise. I have the exact same lights as in your picture except I have a red LED next to the D2Audio chip. I"v been looking for a main board with no luck. I think I have found a D2audio chip and will have a friend of mine that dose board repair replace it for me. crossing fingers and hoping that works. This has been a great TV for 4 years, and still has a great picture. I hope you were able to get your TV working. Thanks again for the pictures. It confirms for me that the led should be green and not red.
                                  • HAHOMETP
                                    • Nov 2012
                                    • 155
                                    LBN, since your Olevia is working could you possibly measure voltages relative to the chassis on White, Blue and Yellow wires in the CN2 connector on the Main PCB when the TV is running? It should be between 3 and 12v DC. Thanks!
                                    • LBN
                                      • May 2013
                                      • 4
                                      messured White, Blue and Yellow wires on CN2. while tv was on and running. got no reading on White, Blue and Yellow wires. Messured orange wire and got 11.88 volts DC.
                                      • HAHOMETP
                                        • Nov 2012
                                        • 155
                                        LBN, thank you very much for the information!
                                        FYI I have attached a portion of my Main PCB with *presumably* working sound. The LED D204 is green. It turns on after a very slight delay and when it does the 4.2v appear on the brown wire in J60. So if your D204 is red, it might indeed be indicative of a malfunction.
                                        Incidentally, in my Main PCB the D1 and D2 are red. The D1 is a STANDBY indicator, so probably red is normal. Could you possibly tell me what color is the D2 in yours? Also, if this is not too much trouble, could you measure the voltage at TP9?
                                        • jean luc ferre
                                          laptop hp g72 b52sf screen problems
                                          by jean luc ferre
                                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                          06-07-2025, 03:27 PM
                                        • Hondaman
                                          USB problems?
                                          by Hondaman
                                          Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                          (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                          I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                          08-12-2024, 03:26 PM
                                        • clabr
                                          Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                          by clabr
                                          Need help to solve some problems with this laptop.
                                          After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                          After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                          Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                          Before this had happened I observed some other problems:
                                          When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                          12-02-2021, 08:09 AM
                                        • jean luc ferre
                                          display screen problems after changing motherboard
                                          by jean luc ferre
                                          First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
                                          I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
                                          Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
                                          Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
                                          09-11-2025, 10:28 AM
                                        • rumpumpel1
                                          Lenovo X13-Yoga Gen 1: hibernation problems
                                          by rumpumpel1
                                          I have a Lenovo X13-Yoga Gen 1 that has problems with hibernation mode. When the laptop goes to hibernation mode - either via the start menu or after a time-out - after a short period of activity where the power-on LED flashes, the power consumption should go down to almost 0 and the LED should go out. Most of the time, however, the power consumption indicates further CPU activity and the power LED remains on, but there is no image. Sometimes the CPU activity stops after a few minutes, sometimes not at all. If the laptop enters this state, it can only be brought back to life by a long press on...
                                          11-03-2024, 12:31 AM
