Lenovo X13-Yoga Gen 1: hibernation problems
  • rumpumpel1
    • Jul 2019
    • 165
    • germany
    I have a Lenovo X13-Yoga Gen 1 that has problems with hibernation mode. When the laptop goes to hibernation mode - either via the start menu or after a time-out - after a short period of activity where the power-on LED flashes, the power consumption should go down to almost 0 and the LED should go out. Most of the time, however, the power consumption indicates further CPU activity and the power LED remains on, but there is no image. Sometimes the CPU activity stops after a few minutes, sometimes not at all. If the laptop enters this state, it can only be brought back to life by a long press on the power button.
    The laptop has a freshly installed Windows 11 Pro 24H2, BIOS and drivers are all up to date.
    I have tried the following so far without success:
    - CleanME
    - New SSD
    - Switched off all devices in the BIOS under I/O Port Access
    - set the sleep state to Linux in the BIOS
    a circuit diagram can be found here: https://www.badcaps.net/forum/troubl...ny-body-please
    does anyone have an idea what else I can test or what the reason for the problem is?
  • JDong
    Problems flashing BIOS for supervisor locked Lenovo V15 G4 IRU laptop
    by JDong
    There was an error... Aborting......I'm using another Linux Laptop with Zorin OS...to try and patch my Lenovo V15 G4 IRU with above specs....It originally had Windows 10/11 installed and converted to a dual boot Kali OS/Parrot OS system. I may have used the wrong lenovo_autopatcher_0.2 (I believe was posted by @knucklegrumble....I am out of ideas and flat broke so i cannot afford another fix (spent it all as an e-com entrepreneur does) any help from anyone would be GREATLY appreciated.....
    • Laptop Model: Lenovo V15 G4 IRU
    • Issue: Forgotten supervisor password.
    • BIOS Chip: GD25B128E (or GD25B128B
    07-06-2025, 10:18 PM
  • confidence
    Lenovo T470s keyboard problems
    by confidence
    Lenovo T470s keyboard not working after Windows installation...
    10-16-2025, 03:50 PM
  • myty6
    BIOS problems Slim 7 16IAH7 Laptop (Lenovo) - Type 82VB
    by myty6
    Hello Everyone,
    Make : Lenovo
    Model: Slim 7 16IAH7
    S/N: YX04XNTW
    Mfg: 2022/09/13
    System will not boot. I have tried the normal troubleshooting (external display, unplugged batter for 24hrs, holding the Novo button, tried to boot from usb using every typed of bootable media) i cannot get a display but keyboard backlight lights up but it's not responsive, fans spin and power button flashes but stops. After researching my symptoms, I am leaning towards a bad bios.
    I have identified what looks to be 2 bios chips on my motherboard, both winbond...
    08-28-2024, 02:41 PM
    Lenovo 3000 Series Schematic
    Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
    3000 C100 laptop with Braille keyboard
    Lenovo 3000 C
    C100, C200 - 15-inch XGA screen
    Lenovo 3000 N
    N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
    N500 - 15.4 inch screen.
    Lenovo 3000 V
    V100, V200 - 12.1-inch WXGA models
    Lenovo 3000 G
    G400, G410, G430, G450, G455, G510, G530, G550, and G560...
    10-04-2024, 06:05 AM
  • clabr
    Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
    by clabr
    Need help to solve some problems with this laptop.
    After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
    After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
    Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
    Before this had happened I observed some other problems:
    When I tried replacing original mecanical HDD with a SSD HDD could not get them...
    12-02-2021, 08:09 AM
