So i just replaced a bad regulator on a Vizio i have. It powered on with backlight but no sound or no image whatsoever. Also it couldnt be turned off once turned on unless you unplug the power cable. Well I recieved and new regulator and replaced it and when i turned it on i had an image of (channel 37) and some vertical blue lines on the screen. It also turned off from the side inputs which was good but when i check the voltages on the new regulator the adjust pin reads .01 V. I know this is wrong and there is a few resistors that i dont think i touched but maybe its possible i unsoldered one because one of them reads 2.02 V and the other reads nothing. Not sure because i didnt test them before (stupid) Now its back to the old symptoms tho and i get no picture/wont turn off. My question is can i adjust the last pin back up around 1-2 V where it should be or did i blow this new regulator already? Any help would be appreciated thank you.
32" Vizio Fixed Regulator. How do I/Can I adjust
Re: 32" Vizio Fixed Regulator. How do I/Can I adjust
You should test the resistors off board meter on ohms scale to cover the expected result. Do you mean new regulator in the last sentence - perhaps edit it.
This might help
https://www.badcaps.net/forum/showpo...2&postcount=80Last edited by selldoor; 11-30-2012, 03:27 PM.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740 -
Voltage from OUT to ADJ should be 1.25V.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Thanks.
u33 reads:
Yes pin 1 reads 5.07 and pin 2 reads 2.02. Pin 3 is reading .01
which would mean its bad right. I checked U7 too which is connected to U33(the one i replaced)
u7 reads:
pin 1- 2.01 pin 2 - .97 pin 3 - .02
i will check the resistors tonight when i get off work. But appreciate anything you can add to help.Comment
This might help
Now one more time? Do what?Comment
My question is can you manually adjust the 3rd pin on U33? i know the voltage is wrong but i literally just got it in the mail today. If not im just goin to order 2 new regulators and replace both U33 and U7 and hope for the best.Comment
i know thats what it should be. The new regulator however is reading the same as the old one. Im wondering if you can adjust it or if it sounds to you like its just another faulty regulator. Thanks again tomComment
The voltage on pin out looks confused: It looks like you count it as, with big tab up, pin1 as the right most pin.
I look at it this way:
If we are looking at the regulator with the Big tab up (the big tab is tied internally to the center pin).
Adjustable regulator will have two resistors attached to it, one resistor (Rfb) is between pin1 and pin2, another resistor (Rg) is between pin1 and ground. Pin3 is an input pin.
The voltage between the Adjust pin (left pin) and the center pin (Pin2, output) will always be 1.25V +/- 2% (this is the precision voltage reference), if it is not, it is bad.
To figure out what the output voltage should be: measure the voltage between pin 1 and ground and add 1.25V to that number, that is the output voltage on pin 2 but you have to make sure you do have 1.25 between pin 1 and 2 as noted above
What is the model of this VIZIO?Attached FilesLast edited by budm; 12-01-2012, 12:50 AM.Never stop learning
You may have damage the resistors or thy came off during de-soldering. Do you have good clear pictures of these two regulators.
I just upload the calculator for the LDO in post 8Never stop learning
I look at SHOPJIMMY and see that both regulators have two resistor close by. Do you know what the output voltage should be? I can try searching the forum for U7, U33 but that may take times.
If the resistors are still there, you can give me the value then I tell if they are correct or not using my calculator.
Follow-up: I found the value:
U33 = 3.3v
U7 = 1.25VNever stop learning
Thanks.
u33 reads:
u7 reads:
i will check the resistors tonight when i get off work. But appreciate anything you can add to help.Never stop learning
yeah i only have a pic of from before until tomorrow.
alright i set the multimeter to 2000 ohms and:
R30 read: 354
R32 read: 1 (thats what it reads when not even connected to anything, So looks like this is bad or damaged)
CB21 actually made the meter dim out and displayed nothing. Not sure what that means
I may be looking for a new board as it looks. I may have burned something when taking out the original. It doesnt look prettyComment
Which one of the resistor has one end connected to ground?Never stop learning
What do you mean by bottom 6 and bottom 1?
Is the reading across R30 = 354 Ohms
and the reading across R32 = 351 Ohms?Never stop learning
yes I dont know when i touch the top(in pic) or piece closest to regulators they read 354 ohms and 351 ohms. on the opposite side one doesnt read anything and one reads 6. (on 2000 ohms setting) its very possible that there may be a solder bridge tho. im not the most precise yet hahaComment
I think you should remove U33, then take the resistance reading across each resistors for me.
It is 12'O clock, so I am going to bed. We will continue tomorrow evening, good night.Never stop learning
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... -
by tmhobadcapI found this tv's situation is very complicated. It will take a long time for me to tell what I found. Therefore, if you don't mind, before I tell the complete story of what I found, I would like to ask some questions. Of course, if the complete story is needed, I will do so.
The tv cannot be turned on. I found that the heat sink on the mainboard is so hot to touch even if it is just plugged into the wall outlet but without turning on the tv. Does this indicate that something wrong that needs to replace the mainboard or the other boards?... -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by tmhobadcapI am trying to help my friend to fix his Vizio tv with a vertical line on the screen. The line is on the right side. It is blue/purple on the right side starting from the top. But it only goes to about 3/4 of the screen height (not to the bottom of the screen). It is very obvious when the screen is dark and it is hard to be seen when the screen is bright. Please help....
The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
Internal soft-start results in small inrush current and extends battery life.
The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...-
Channel: Common Parts Library - Datasheets
10-07-2024, 05:02 AM -
- Loading...
