Vizio M55-F0 Cannot be turned on
  • tmhobadcap
    • Apr 2019
    • 156
    • CANADA
    I found this tv's situation is very complicated. It will take a long time for me to tell what I found. Therefore, if you don't mind, before I tell the complete story of what I found, I would like to ask some questions. Of course, if the complete story is needed, I will do so.
    The tv cannot be turned on. I found that the heat sink on the mainboard is so hot to touch even if it is just plugged into the wall outlet but without turning on the tv. Does this indicate that something wrong that needs to replace the mainboard or the other boards?
  • CapLeaker
    Leaking Member
    • 8352
    Re: Vizio M55-F0 Cannot be turned on
    Sounds like the main board is screwed to me. It should not get hot like that in stby.
    • maricm
      Vizio P65 with P55 mainboard
      by maricm
      IH all, Got this vizio tv P65-E1 from FB marketplace hoping to be able to reflow mainboard as selerrstated that it was diagnosed with bad mainboard. However they must have tried to repair tv by putting another board in and they put P55 board in .
      Tv starts and responds to remote but screen does not look right , It looks like low resolution with some image ghosting. Now not having original board I dont know what to order ? Any advice how to figure out what exact board fits this tv ?
      And another question Would it be possible to adopt this board to this tiv by chagning eeprom or tcon...
      04-23-2024, 08:25 AM
    • Mirenia
      Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
      by Mirenia
      I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
      I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
      In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
      The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
      03-30-2025, 06:47 AM
    • Devonavar
      Vizio M43-C1 - How closely do I need to match the mainboard number?
      by Devonavar
      I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
      I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
      Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
      So, I've ruled out the PSU for now.
      The reboot loop...
      08-14-2022, 08:46 PM
    • orcic
      MASTER TL240 and new mainboard LW36BKC01
      by orcic
      I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
      The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
      After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
      Now I have some doubts about how to connect the new mainboard to the old power supply.
      First of...
      05-12-2023, 08:10 AM
