32" Vizio Fixed Regulator. How do I/Can I adjust
    Re: 32" Vizio Fixed Regulator. How do I/Can I adjust
    If you still do not get 3.3V, then for sure there is damaged place some where on the board. Good luck.
      Alright so i just picked up 3 of both kind of regulators. They are arriving later today. My only question is about the pins. The fixed i got looks identical and should line up the same. pin 1 will connect to where the adj pin went originally correct?
        If the tab is in the correct position, and the device is not upside down, it is not possible to put it on the wrong way. Unless spacetime curves in upon itself. But then you may have bigger issues...
          With the luck i been having i was suprised the world didnt end the other day haha.. Just making sure
            Here's the adjustable regulator that I ordered and used as a replacement for U33 for a different model Vizio. I think it's the same as what you ordered but made by a different manufacturer,mine has been working for 2 months so far.
            http://www.digikey.com/product-detai...SCT-ND/1967218
              Here's the voltages I had on the working Regulator U33 -Input 5.19V - Output 3.35V - Adjustment Pin 2.08V
                Reg is good.
