32" Vizio Fixed Regulator. How do I/Can I adjust
+ More Options
Posts
  • Loozer
    • Nov 2012
    • 84
    • US
    Re: 32" Vizio Fixed Regulator. How do I/Can I adjust
    now without U33 attached it reads 181 ohms for both resistors. and instead of 6 on bottom one it is now 3 ohms. I also resoldered first with a much cleaner job making sure they were not touching. Didnt work so hopefully this makes better sense to you. Thanks Budm for everything so far.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Originally posted by Loozer
      Now one more time? Do what?
      Measure the resistors?
      Also that blue/black cap connected to u7 looks to have a brown mark on the side is it ok or is it leaky - bad caps adjacent to regulators can distort the voltages.
      • Loozer
        • Nov 2012
        • 84
        • US
        All caps look fine. Im not sure what your seeing.
        R30 - 181 ohms
        R32- 181 ohms
        (without U33 attached to the board)
          If that is the correct reading on those two resistors, the output will be 2.5V
          • Loozer
            • Nov 2012
            • 84
            • US
            So i need a new regulator?
              What is the voltage between OUT and ADJ?
              • Loozer
                • Nov 2012
                • 84
                • US
                #27
                Out (center)= 2.02
                ADJ (left pin)=.01
                so 2.01?
                  Yes, the regulator is very bad. It should be 1.25V. Where did you get it; is it definitely an adjustable regulator?
                  • Loozer
                    • Nov 2012
                    • 84
                    • US
                    #29
                    digikey... well tell me is this even the right one? I thought it was but maybe not.
                    http://www.digikey.com/product-detai...29-1-ND/586229
                      It looks correct, seems very odd!! What is the part number on it?
                      • Loozer
                        • Nov 2012
                        • 84
                        • US
                        #31
                        The original number on the old regulator said AMC1117
                          What about on the new one?
                          • Loozer
                            • Nov 2012
                            • 84
                            • US
                            #33
                            Ld1117astr
                              Very odd. Have you got a second part you can try? It does not make sense. Is there no shor between Vin and ADJ, or Vin and Vout?
                                If the two resistors having the same value, even with the good regulator, the out put will still be only 2.5V. That U33 is set to have output of 3.3V, its output is also feed U7. So we need to concentrate on the area around U33 to see if there are shorted path somewhere, we can easily change the two resistor to make U33 put out 3.3v, but we need to look around the area first.
                                • Loozer
                                  • Nov 2012
                                  • 84
                                  • US
                                  #36
                                  Yea im afraid I may have ruined the board after taking the regulator out so many times. Its got some black burn marks around where it was. Might be getting a new board unless its fixable
                                    By any chance that you also bought the 1117-3.3?
                                    • Loozer
                                      • Nov 2012
                                      • 84
                                      • US
                                      #38
                                      I just bought one from the link above. Im probably gonna buy a few more should I try a different one?
                                        If it is fixed 3.3V regulator, then you can use it by having pin 1 connected to ground, the middle pin will go to same point (same place as original), the third pin will go to the input (same place as original). You will not need those two resistors since we will use fixed output regulator which does not need external resistor. I do not know why Vizio does not use the fixed regulator in the first place for the 3.3V.
                                        By the way, the input voltage to this U33 is 5V, right?
                                        • Loozer
                                          • Nov 2012
                                          • 84
                                          • US
                                          #40
                                          Yes 5 V. Im gonna do that then. Sounds easier
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • tmhobadcap
                                            Vizio M55-F0 Cannot be turned on
                                            by tmhobadcap
                                            I found this tv's situation is very complicated. It will take a long time for me to tell what I found. Therefore, if you don't mind, before I tell the complete story of what I found, I would like to ask some questions. Of course, if the complete story is needed, I will do so.
                                            The tv cannot be turned on. I found that the heat sink on the mainboard is so hot to touch even if it is just plugged into the wall outlet but without turning on the tv. Does this indicate that something wrong that needs to replace the mainboard or the other boards?...
                                            07-08-2023, 12:58 PM
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • tmhobadcap
                                            VIZIO M60-C3 Can the vertical line be fixed?
                                            by tmhobadcap
                                            I am trying to help my friend to fix his Vizio tv with a vertical line on the screen. The line is on the right side. It is blue/purple on the right side starting from the top. But it only goes to about 3/4 of the screen height (not to the bottom of the screen). It is very obvious when the screen is dark and it is hard to be seen when the screen is bright. Please help....
                                            02-05-2023, 03:37 AM
                                            MT3608 Step-Up Converter IC Datasheet
                                            The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
                                            Internal soft-start results in small inrush current and extends battery life.
                                            The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
                                            10-07-2024, 05:02 AM
