Emerson LC401EM2F
  • Mark369
    • Jul 2009
    • 163
    #81
    Re: Emerson LC401EM2F
    Oh yea my father said the the power for his house was flickering on and off about 6 times before the tv stoped working.
    Is there any way of marking the thred as solved?
      Thanks for posting the repair feedback. You should look for power conditioning outlet that has Extreme voltage shutdown function. And check the breaker panel if it is running hot, you can also find out if it has loose connection by using Transistor AM radio tuned it to unused frequency then move it around the panel and listen for loud static noise if it has poor connections. I check my panel once a year, you will have to turn off the main feeding switches that feed the panel first. I also switch the circuit breakers on-off a couple times to keep the contact clean.
      • Mark369
        • Jul 2009
        • 163
        #83
        do you mean like a power bar with a surge protector built in.
        I hope this thread will help some one eles.
          I do not believe it has Extreme Voltage shutdown function, that is the function that you should have.
          Google "power strip with EXTREME VOLTAGE SHUTDOWN"
          • BFraley
            • Feb 2013
            Posted in Error
            • MC_Collector
              • Mar 2013
              I had a friend tell me about badcaps and I've been fighting with a Emerson (Funai) LC407EM1 LCD TV which uses the identical power supply as the on you guys have been troubleshooting. We got a power surge that damaged it and it was blowing fuses. I had gone through the same sort of process as above, but set it aside for a long time after finding nothing bad. Amazingly D1208 was shorted on mine too. I ordered a replacement tonight and hope for the same results. What a great site!!
              • MC_Collector
                • Mar 2013
                I just got the new zener diode in from digikey today. You guys nailed it. The TV seems to work perfectly now. I wanted to let you know that I am thankful for the help!
                Best wishes,
                Dusty Evans
                  Thanks for another great repair job, glad that it is working again with a couple dollars worth of part.
                  • Mark369
                    • Jul 2009
                    • 163
                    #89
                    Good to Job.
                    • MtPockets
                      • Jul 2013
                      • 7
                      Just came across this thread while having the same issue with a buddies set.
                      I came across The failed D1208, then I came across this site while searching to see if there were any other related issues to this board.
                      Time to place my order as well.
                      Thanks to everyone for their knowledge and posting information.
                      • MtPockets
                        • Jul 2013
                        • 7
                        Mark did you make an error in your Digikey part number#
                        should it be this:
                        http://www.digikey.com/product-detai...ICT-ND/2880396
                        • aaronpass
                          • Jul 2011
                          • 33
                          #92
                          Hello Everyone! I just replaced the diode at 1208, as my tv had a blown fuse as well. When I go to power it up all I get is a click sound when I first plug it in, and then another click about 5 second after I unplug it. Does anyone have any suggestions for me to look at? Thanks!
                          • Mark369
                            • Jul 2009
                            • 163
                            #93
                            do a search and you will find other sets that have the same clicking and start from there.
                            Or start new topic
                            • aaronpass
                              • Jul 2011
                              • 33
                              #94
                              Or start new topic
                              Thank You!
                              • joshbsg
                                • Feb 2014
                                • 13
                                • U.S.A
                                #95
                                The service bulletin for this model lists: "Cure: Remove the diode, replace fuse. Do not replace the diode. Perform any additional repairs as necessary. "
                                • phil10
                                  • Jul 2014
                                  • usa
                                  #96
                                  I followed this thread all the way through and replaced diode 1208 and fuse on a Emerson LC401EM2F power board. Turned it on and now it works great. thank you all for the help. Next lightening storm I will look for the same things. Thanks
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    #97
                                    Well Done ! Tip - next lightning storm unplug the tv and aeriel
                                    • coreyand
                                      • Nov 2014
                                      • 88
                                      I have a TV same model that I just purchased from somebody at a garage sale, I am not an expert at this by any means but I have fixed some much older LCD displays by replacing bad caps. I understand with caps you can use a larger voltage rating as long as the uf value is the same(I hope that is right). Maybe its the other way around, perhaps the voltage is supposed to be the same but the UF value can be larger than specified. Please correct me if I am wrong on that. Either way I am wanting to learn how to repair electronics because I come across a lot of bad components in my line of work(Audio/Video/Home Theater Business 8+ Years) and would like to repair said items that we replace because they quit working either by hardware defect or mother nature(Lightning).
                                      Repairing this TV will be my first for replacing anything like diodes and what not so I want to use this tv to familiarize myself with things to look for. I have watched a few videos on youtube but none that pertain to this tv specifically. I apologize this probably isnt the best thread to announce all of the above said information but I have read over this thread and the other one mentioned in this thread that both pertain to this set, and I needed to know if it was indeed the D1208 diode that was replace that solved this problem. If so, when shopping for a diode to replace where is the best place to learn of the values of diodes and be able to understand what values of a diode I need to replace the above mentioned one? Also, I see that the diode is a "zener". If somebody could explain this to me or point me the correct direction that would be much appreciated. I would to go to radioshack and get this "zener" d1208 diode and replace it but I feel like d1208 only pertains to this board as a marker of diode placement. Thank you all very much.
                                      • selldoor
                                        Slow Learner
                                        • Dec 2010
                                        • 7870
                                        #99
                                        Personally I would say learning electronic repairs starting with a TV is a bad idea. You should start with something simpler like a monitor. Emerson Tvs seem particularly bad I have seen many on here where we were unable to fix it. Often blown components kill off the eeprom. So yes you can use it to practice on and practice soldering and testing but dont be too disappointed if it dont get fixed. Guy in post 96 seems to have had a simple fix.
                                        I understand with caps you can use a larger voltage rating as long as the uf value is the same - that is correct usually one step higher in voltage..
                                        You can also go one step higher in uf and when you REALLY know what you are doing
                                        you can sometimes go one step lower in both - but I wouldnt try that.
                                        Here is a good starter guide - written for monitors, but the tests are the same.
                                        https://www.badcaps.net/forum/showpo...4&postcount=19
                                        The internet is the best place to learn most things - google is your friend.
                                        Google "emerson D1208"
                                        For values of specific components a schematic/service manual might help
                                        • Mark369
                                          • Jul 2009
                                          • 163
                                          #100
                                          im glad to see that this post has helped a lot of you guys.
                                          @coreyand
                                          if you want to fix this tv you might tell us some more info.
                                          and we will need pics of the boards inside top and bottom.
                                          good luck with your quest of learing.
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                          • jesterace
                                            Samsung UE46ES8000 Blown fuse but no other signs of short
                                            by jesterace
                                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                            09-11-2024, 03:14 PM
                                          • jshhh
                                            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                            by jshhh
                                            Hi guys,
                                            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                            Anybody know how to remove this type of fuse?
                                            (The fuse is toward the bottom of the image labeled F2)...
                                            06-17-2025, 01:35 AM
                                          • Babbar
                                            by Babbar
                                            04-12-2024, 01:12 AM
                                            Surface Mount Fuses Fundamentals Datasheet
                                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                            10-07-2024, 06:07 AM
