Sanyo dp42848. No picture no sound?has anyone found the problem
    Re: Sanyo dp42848. No picture no sound?has anyone found the problem
    The tv shuts off after 5 sec so I test in the 5 second window?
      Pson-4.9 v
        Pson results-
          The pson voltage
            Stop that and just list the results as I asked you to - Are you using that ground screw we can see in the pictures for the black prob.
            And did you do the first Ohms probes touch meter test.
              Sgnd 0 volts
                0 volts sgnd
                  5vsb
                    Results 5vsb-05.0
                      Ok the first pic 200 v dc 000 touched the probes togeather
                        Pson-0.49-sgnd-0.00-5vsb-0.50-sgnd-0.00-12v-00.2-sgnd-00.0-24v-00.0. Sorry wanted to make sure I was doing right with the pics,yes I'm using the ground sctew
                          The pink fusable resistor - no continuity,200 ohms 1.
                            Ok what do you think?
                              I probed the pink fusable resistor with the bord still mounted on the tv,should I probe it from the back of the board?
                                I will wait for the next step?
                                  I think you should go back and read how I asked you to post the result.
                                  There is nothing worse than being faced with a long line of numbers to decipher.
                                  Oh! Sorry, there is - its a long line of numbers where several are listed
                                  totally incorrectly and some pins are missing.
                                    Pink resistor is that from primary to chasiss? It should normally read open. Please be patient. We are busy. I have a maths test to revise for.
                                      Try it again with meter on 2000 ohms
                                        I'm am not being in a hurry..that's why I said I will wait!and I did post the results like you asked,,what did I miss?
                                          No I tested continuity from one side of the pink fuse to the other
