Replaced T-con board and now getting vertical lines
  • sr9800
    • Nov 2012
    • 3
    • Tnt
    I have a Sony bravia KDL46VL160, first problem was a blank screen with sound.
    When bought and replaced the t-con board, coloured vertical lines are as shown in the picture
    What do you all think is the problem ?
    Thanks for the help...
    Re: Replaced T-con board and now getting vertical lines
    Was the T-con an exact match?
    • sr9800
      • Nov 2012
      • 3
      • Tnt
      Yes, the same exact t-con...
      i am sure...
        Did you match the P/N on the barcode, not as printed on the board.
        • sr9800
          • Nov 2012
          • 3
          • Tnt
          yes, it is correct ...
          do you think i got a faulty t-con board ?
          or is it possible that the tv has a faulty panel or main board ?
            I would suspect the T-con in this case.
            • shanusmarty
              • May 2013
              • 19
              • India
              even i have the same problem, but i replaced TCON, but no solutions
                Do you mean you originally had:
                - a blank screen (lit up)
                - vertical lines?
                • tron
                  • Apr 2009
                  • 47
                  http://www.youtube.com/watch?v=GcBwTums_mI
                  • shanusmarty
                    • May 2013
                    • 19
                    • India
                    - vertical lines?
                    hello,
                    i originally had vertical lines with audio, but same results after replacing TCON!
                    Please help!
                    this was the original condition with out replacing TCON!
                    http://www.youtube.com/watch?v=PKrUvpyHxUI
                      You may have a main board or panel fault then.
                      • shanusmarty
                        • May 2013
                        • 19
                        • India
                        changed the main board and tested.. but same results!
                        can lcd panel faulty with out physical damage?
                          Yes, it is quite possible you have a bad tab bond.
                          Different fault, same possible cause + possible fix:
                          https://www.youtube.com/watch?v=purk_SyiT44
                          • shanusmarty
                            • May 2013
                            • 19
                            • India
                            thanks for so much help, but for info i was WATCHING TV(using as a monitor connected to my laptop thru VGA port, it was running smooth) n suddenly withOUT any physical contact or any thing, black part appeared from right to half and then full black and boom it was gone forever.
                            so the summary is it was working perfect and running smooth and next moment it was at fault!
                            what could be the culprit?
                              Usually the tab bond faults get worse progressively, but there have been reports of sudden failures due to tab bonds. I recommend you try and eliminate it. Also, can you post pictures of inside your TV? Perhaps there is another board that can cause this. Unlikely, though.
                              • shanusmarty
                                • May 2013
                                • 19
                                • India
                                thanks again!
                                this is the picture of old TCON! LINKhttp://db.tt/RJGiVua1
                                  What about one of the rest of the TV?
                                  • shanusmarty
                                    • May 2013
                                    • 19
                                    • India
                                    picture of old TCON attached!
                                    • shanusmarty
                                      • May 2013
                                      • 19
                                      • India
                                      will post tommorow! the whole of TV!
                                      Thanks TOM66 for so much help! and BadCaps too!
                                      • capkid
                                        • Oct 2010
                                        • 1339
                                        LG Plasma Mal-Discharge Correction Service
                                        • Stanley1843
                                          by Stanley1843
                                          06-29-2024, 11:54 AM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • Falki
                                          Colorful LCD Vertical Lines on Samsung ue55es8090
                                          by Falki
                                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                                          A similar issue has been posted as well but also with no actual response ...
                                          08-12-2025, 04:19 AM
                                        • gpo23
                                          Sony KDL-40V3000 - Vertical lines
                                          by gpo23
                                          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                          With the new t-con the color are good but there are vertical lines on all the screen :
                                          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                          Is there a way to fix the vertical lines on the new t-con ?
                                          Thank you for your help
                                          gpo23...
                                          10-04-2023, 09:11 AM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
