Colorful LCD Vertical Lines on Samsung ue55es8090
  • Falki
    • Aug 2025
    • 8
    • DE
    Hello there, ive recently found an older 55inch Samsung SmartTV.
    Sadly it has vertical lines at the left and one line in the middle-right.
    I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
    I have factory resetted the TV as well but also with no luck.
    I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
    A similar issue has been posted as well but also with no actual response
    https://www.badcaps.net/forum/troubl...-lines?t=65022
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    I would say panel dead. You don't need to see impact for it to be there. I've had many tvs that appear no impact but have broken screens.
    • Unspun01
      • Jun 2011
      • 349
      Random vertical lines with no discernible repeating pattern are indicative of panel problem. An identifiable "repeating" pattern of vertical lines or blocks or colors can be due to a TCON or mainboard with a shorted address line and can be repaired.
      In your case, I suspect the panel-to-buffer-board flex ribbon cables which possibly have COF (chip-on-flex) ICs. The ICs can fail and appear like your image.
      Specifically on your TV, the localized nature of all lines in one area tells me one ribbon cable or the IC that drives the lines on that ribbon is damaged. The other random line in center tells me another failure is about to happen there as well - it just isn't as bad yet.
      More commonly I see this random vertical lines issue as the result of people spilling liquid on the screen (like children), or spraying liquid cleaner directly on the screen instead of using a slightly damp cloth with no risk of liquid running down the screen. Most TVs now have ribbon cables and buffer boards located at bottom of screen below bezel and any liquid that gets to them will certainly damage them.
      Did anyone clean the screen or spill anything on it? Don't rule it out. Be honest with yourself. I have lost count of how many times I told someone their TV has liquid damage and they deny it absolutely only for me to show them there is water, or windex, or milk, or hot chili sauce between the LCD panel and the bezel. It happens and family members are quick to lie to each other about it.
      On another note, I checked out the link you posted to the other forum. One user with the same TV and same issue reported that their problem was magically solved by transporting the TV on a bumpy road. Some of these new TV designs are terrible and have inadequate structural build quality. I wonder if you can try removing the base stand or supports and screws and see if anything changes. I doubt it will do much, but if the TV's own weight is improperly supported by the stand design, then removing the stress could change the image issue slightly.
      • Falki
        • Aug 2025
        • 8
        • DE
        Thank you thank you very much for your thorough answer. A bit of context to this device: I have found it on the street from somebody who threw it away. I have no idea what happened to this tv but there was no physical damage ANYWHERE. I couldnt even find any corrosion on the COF cables. It was just dusty. I just thought this could be a nice little project to learn about TV's and maybe preventing a device from going to the landfill. Ive seen some videos about fixing the issue with a toothbrush or tape on those connections but I couldnt repeat it, nothing really happened or changed on the screen.
        I would be really saddened to give up on this only because a very small part is actually causing this...
        • Stanley1843
          Screen Display Vertical Multicolor Lines
          by Stanley1843
          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
          06-29-2024, 11:54 AM
        • x_orange90_x
          Samsung UN46C8000XFXZA vertical bars/horizontal lines
          by x_orange90_x
          I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
          The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
          09-04-2023, 12:09 PM
        • polaro
          Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
          by polaro
          Greetings,
          I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
          08-27-2022, 08:46 AM
          09-07-2024, 05:50 AM
        • Anonmis
          Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
          by Anonmis
          Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
          The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
          12-01-2023, 04:31 PM
