Replaced T-con board and now getting vertical lines
  • haron
    replied
    Re: Replaced T-con board and now getting vertical lines
    i have tv kdl46vl160 but i have picture vertical line help me
  • capkid
    replied
    Yeah, you're most likely not going to find a replacement panel at a practical price these days. I got mine on eBay about two or three years ago, and it was for a smaller TV (26").
    replied
    Originally posted by shanusmarty
    Thanks everyone for the inputs!
    where can i get a cheap replacement panel, in what price range ?
    Not economical - 90% the price of a new TV in most cases.
  • shanusmarty
    replied
    Originally posted by capkid
    I'm going to say that you have a bad panel. I've worked on several TVs that showed vertical lines that would gradually fill the screen. I found a cheap replacement panel for one of those TVs, and it's worked fine for about two years.
  • capkid
    replied
  • shanusmarty
    replied
    they are very less at starting and grow more.. then fill up.. then very light when the cfl is on full brightness.. u can see the full video.. in my earlier post
  • capkid
    replied
    This is purely unscientific, but Sony LCD TVs are notorious for panel and main board issues. If you've tried a known working main board, you probably have a bad panel. Do the vertical lines on the screen in your pic show up like that when it's first turned on, or do they gradually appear?
  • 1supertech
    replied
    If you tried a good mainboard & Tcon then it may be the panel
    their may be a fuse on the Tconn did you check
  • shanusmarty
    replied
    i have checked by replacing the main board once.. the results were same!
  • 1supertech
    replied
    sir if the main board is bad(faulty), can the tv function properly ?
    all buttons and sounds working good!
    I would say so but I could be wrong may be someone else out their with more TV experience can suggest some more ideas?
  • 1supertech
    replied
    Here is a cheap capacitance meter
    http://compare.ebay.com/like/1308375...Types&var=sbar
  • shanusmarty
    replied
    Originally posted by 1supertech
    Even thou it may look like it's bulged in the picture and it's not
    capacitors don't have to bulge to be bad I test all my caps to find a problem
  • 1supertech
    replied
  • shanusmarty
    replied
    and if main board is at fault, can the tv switched on, and all sounds and buttons are working fine ?
  • shanusmarty
    replied
    but they are not bulged, though it may seem in the pic!
  • 1supertech
    replied
    You would need a ESR meter that is capable of testing on board or take them out to test.
  • shanusmarty
    replied
    I put red circles around caps
    ok i located, how can it be checked?
    i have a multi meter, i checked , they have continuity with out power!
  • 1supertech
    replied
    sir can u mark it out in the pic and attach the pic ?
    but i think the main board is working fine, coz there is sound and the buttons and remote is functioning well..
    need your suggestions ?
  • shanusmarty
    replied
    fourth pic of main board polymers caps look like they are starting to bulge 100uf 6.3v & 47uf 16v
  • 1supertech
    replied
  • Stanley1843
    by Stanley1843
    06-29-2024, 11:54 AM
  • Daren87
    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
    by Daren87
    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
    08-13-2023, 03:25 PM
  • gpo23
    Sony KDL-40V3000 - Vertical lines
    by gpo23
    i order a t-con because i had bad colors on my SONY KDL-40V3000 :
    With the new t-con the color are good but there are vertical lines on all the screen :
    I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
    Is there a way to fix the vertical lines on the new t-con ?
    Thank you for your help
    gpo23...
    10-04-2023, 09:11 AM
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
  • Hakuu
    by Hakuu
    Hi There,
    More Details
    TV Model - LG OLED77G1PUA
    07-12-2023, 02:37 PM
