Replaced T-con board and now getting vertical lines
  • capkid
    • Oct 2010
    • 1339
    Re: Replaced T-con board and now getting vertical lines
    I'm going to say that you have a bad panel. I've worked on several TVs that showed vertical lines that would gradually fill the screen. I found a cheap replacement panel for one of those TVs, and it's worked fine for about two years.
    LG Plasma Mal-Discharge Correction Service
    • shanusmarty
      • May 2013
      • 19
      • India
      #42
      Thanks everyone for the inputs!
      where can i get a cheap replacement panel, in what price range ?
        Not economical - 90% the price of a new TV in most cases.
        • capkid
          • Oct 2010
          • 1339
          Yeah, you're most likely not going to find a replacement panel at a practical price these days. I got mine on eBay about two or three years ago, and it was for a smaller TV (26").
          • haron
            • Jul 2015
            i have tv kdl46vl160 but i have picture vertical line help me
            • Stanley1843
              Screen Display Vertical Multicolor Lines
              by Stanley1843
              Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
              06-29-2024, 11:54 AM
            • pni
              LG 49uf695v vertical coloured lines
              by pni
              Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
              11-14-2025, 03:15 AM
            • Daren87
              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
              by Daren87
              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
              08-13-2023, 03:25 PM
            • Falki
              Colorful LCD Vertical Lines on Samsung ue55es8090
              by Falki
              Hello there, ive recently found an older 55inch Samsung SmartTV.
              Sadly it has vertical lines at the left and one line in the middle-right.
              I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
              I have factory resetted the TV as well but also with no luck.
              I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
              A similar issue has been posted as well but also with no actual response ...
              08-12-2025, 04:19 AM
            • gpo23
              Sony KDL-40V3000 - Vertical lines
              by gpo23
              i order a t-con because i had bad colors on my SONY KDL-40V3000 :
              With the new t-con the color are good but there are vertical lines on all the screen :
              I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
              Is there a way to fix the vertical lines on the new t-con ?
              Thank you for your help
              gpo23...
              10-04-2023, 09:11 AM
