Sharp LC-40LE810UN question
    Re: Sharp LC-40LE810UN question
    No fan noise problem here. It's quieter than my old HP 54501A.
    • tibimakai
      • Jan 2012
      • 3680
      Do you guys think that I should still check the 18V at the start up, since I have the output voltages?
        PSU is fine, for now. Check main board. Maybe TV was hit with a surge.
        • tibimakai
          • Jan 2012
          • 3680
          What should I check on the mainboard?
            Post some pictures of it.
            • tibimakai
              • Jan 2012
              • 3680
              I will a bit later.
              Bud, you are thinking about getting this scope?
              Tom, how come your doesn't have a noisy fan? 1102 has a different one then the 1052? Everybody complains about the fan noise.
                No, it's got the same fan. Scopes are identical hardware wise. It just doesn't bother me much...
                  No, I just saw the video and thought it is the same as yours, I already have 3 Tektronix scopes at home.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    I have made some pictures, not the greatest ones, specially the bottom one:
                    • tibimakai
                      • Jan 2012
                      • 3680
                      We can't move to the mainboard.
                      I have/had the voltages, but the 13V did not reach the connector.
                      At the connector I had only the 5.5V.
                      After a couple of minutes of measuring, the voltages are gone again.
                      I have tried it again after a while and it was back again for a couple of seconds and then drops to 0.7-0.8V.
                      I'm so pissed on this power supply, that I'm thinking of just buying another board and be over with.
                      I can have a short or something in the secondary and the feedback kills the power source?
                        Why is the tuner can rusted? Has this TV been exposed to water?
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I have no idea.
                          I have just purchased the power supply.
                            Well, the power supply was probably fixable... I suspect you could have additional damage to the TV due to water.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              I was trying to fix this power supply for over a month with no success.
                              I have waited for two ICs(same) and when I install one it runs for a bit and then it quits, replaced the second one and the same thing happened.
                              Now I will have to order two more($15 shipped=total $30), wait another three weeks.....
                              Last couple of days I didn't get any real help, plus the frustration and I have just pulled the trigger. It wasn't easy to give up.
                              It was less then $78 shipped.
                              The back cover of the TV is Aluminum(!) and that one too has some white spots, not sure if it's water or oxidation of the Aluminum exposed to the elements
                              The guy from whom I picked it up he said that it was his own TV, but then he has a company which installs TVs on the wall.
                              I'm guessing that he lied and this TV it was installed at an outdoor place most likely.
                                I never trust people when I pick up a TV .
                                I didn't realise you were having so much difficulty with the PSU. I hope the replacement works.
                                I want a nice Sharp 40" LED set to work on soon .
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  ..and it's a smart TV too!
                                  Today before I left to work, I have checked it again and the voltages were there at the two capacitors.
                                  It seems that all the voltages have to drain out of the TV before I have the voltages back.
                                  I may have some short in the secondary side of the PS?
                                  The FET and that double diode(not sure how is called, looks like a FET) under the black heatsink has voltages at there pins.
                                  Not sure what happens between these and the connector.
                                  Man I don't like to give up, and I hate myself that I have purchased that board.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    I have just noticed that actually the LEDs are on an blinking while I have the voltages. I haven't notice them before, since they were up side down.
                                    The code that flashes is 2 slow and 5 fast blinks which in the manual says that it's:
                                    -Power PWB failure (Power failure, etc.); Panel power supply error.
                                    -PANEL_POW; Panel 12V failure; Flashes fast 5 times; DET_PNL12V(35pin) failure (L). Panel power is not applied.
                                    Detection is started after turning on the panel power and receiving command; the power is turned off by polling.
                                    It would be nice if we could fix this board also. I would have a good board.
                                    The new one from partstore is in it's way.
                                      Probably the component responsible for providing panel power is dead. The corrosion could have killed it.
                                      You will have to let us know how smart the smart TV seems! I have always found them annoyingly slow.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        I will let you know. I'm using a WDTV Live streaming player now. It's hard to believe that it could be better then that.
                                        • tibimakai
                                          • Jan 2012
                                          • 3680
                                          Power supply/Inverter board arrived. I have installed it and it's exactly as with the original board. Still blinking a code. Board ordered from partstore.com.
                                          So, it looks like it's the mainboard is the problem. Not receiving any voltages other then the STBY voltage.
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:10 PM
