need help to test inverter transformer
  • selldoor
    Slow Learner
    • 7870
    #61
    Re: need help to test inverter transformer
    good - were you able to find a panel with that type of backlight connector?
    If not ,I am not sure how the Big plugs are wired -perhaps budm will suggest how you
    can best test the bulbs
    • woaimi
      • Sep 2005
      • 94
      • US
      #62
      that is my problem right now, I couldn't find anything with that plug, my bulbs mostly came from computer LCD and the biggest size i have is 19". There are 6 plugs for this tv set and I'm assuming it represent 6 bulbs, here's what I'm thinking will I cause any damage if I only plug in 1 or 2 bulbs to the corresponding transformer and leave the other unplug? this way I can verify which transformer is working and which one is not and may be at the same time can figure out the questionable bulb/s.
      • selldoor
        Slow Learner
        • 7870
        #63
        I am hoping all transformers will be good and we can work out which lamp or lamps is
        causing the shut down. As I said budm has more ideas on this and has a way of using
        old domestic energy saving bulbs to test so we need to hope he comes back to this thread. For testing the size of your panels doesnt matter I think you can get adapter from small to big but for now just see if you can plug a small plug in onto one pin of the big connector. If it will go on then we can consider cutting the small plug in half.
        • woaimi
          • Sep 2005
          • 94
          • US
          #64
          I measured the Vcc input to the transformers and reading 56v at all time whether the TV is on nor not, does that suggest anything?
            OK, I looked at the inverter/power supply board, all three transformers are driven by the same output MOSFET's. I still think you should have replace all 3 transformers.
            You have indicated that you have 56V at all time on the inverter transformers primary side. It should have 0 Volt due to DC blocking cap, and the junction between the two inverter MOSFET's should have 0V (not 100% sure since I did not draw out the circuits in details). I would take that blue DC blocking cap out and measure for any leakage resistance using the highest Ohm scale, cap should show open circuits, you should also check its capacitance.
            Another thing you can check to see if all the lamps do at least try to light up or not by just having one set of lamp connector connected one at a time, then turn on the TV in the dark room and see if each set of the lamp will light/flash.
            I will tell you later how to use home made tester lamp.
            • woaimi
              • Sep 2005
              • 94
              • US
              #66
              Wow, thanks for that drawing, I've learned much more since I take on this project. Thanks for all those replies.
              I checked the light bulbs one at a time and they're all flashed up in the same pattern; it flashes like twice in about 5 seconds, I think they are fine.
              The DC blocking cap were removed to test, it read opened when test with the ohm meter and the capacitance measured 0.452 nF and the caps's label said 474K (I'm guessing that 's a 0.47 nF cap)
                It is 0.47uF cap not 0.47nF.
                • woaimi
                  • Sep 2005
                  • 94
                  • US
                  #68
                  thanks budm for pointing it out, i will have it verify later tonight, I might have mis-read the 'u' and 'n' on the meter.
                  • woaimi
                    • Sep 2005
                    • 94
                    • US
                    #69
                    It was verified as 452nF, that's what happened when I tried to work on it at 2:00 am. So, going back to your drawing, if I can't measure those 2 points you mentioned how can I verify it 0 voltage? I'm feeling very close to get it working, really don't want to throw in the towel yet.
                    • selldoor
                      Slow Learner
                      • 7870
                      #70
                      Perhaps just replace it - I dont think they are v expensive? perhaps you have one on a "spares" board?
                      • woaimi
                        • Sep 2005
                        • 94
                        • US
                        #71
                        Could you please help to id this cap? all I can tell is .47uF, don't know what the voltage rating. I probably be able to find it in my junk pile. Thanks
                        sorry for the blurry image, that's the best i can come up with with my iphone.
                        • selldoor
                          Slow Learner
                          • 7870
                          #72
                          I dont know but thought id say something to bring it back to the top.
                          Is the K relative to 1000 or is it a tolerance value - I have seen some with a J.
                          The 4 could be 400v is there a voltage on the small blue cap next to it?
                          • woaimi
                            • Sep 2005
                            • 94
                            • US
                            #73
                            there's nothing written on the small cap either. From what I found the 3rd character is the multiplier and K is tolerance value of +-10%
                            • selldoor
                              Slow Learner
                              • 7870
                              #74
                              Yes that was what I thought - in the absence of more educated input I would try a 400v - I have looked at a few and some are just coded so 4 could be anything. Can you get a better close up of the logo in the middle of the bottom line - if anyone recognises that we might find the codes.
                              • woaimi
                                • Sep 2005
                                • 94
                                • US
                                #75
                                I'll try with a real camera later when I get home.
                                Anyhow, I wanted to retake the voltage reading off the connector so I soldered it back on last night, plugged everything in, turned it on. I realized I was able to see the screen with a spot light. I checked the transformers in frequency mode to find out they were all run at 63 kHz (if I remember correctly) and all shut down as the screen goes dark.
                                The CN600 connector reads as follow
                                V-PWM = 0.54V/ 0.54V (on/off)
                                BL-ON = 5.15V/ 65mV
                                PS-ON = 4.7V/ 4.7V
                                GND
                                GND
                                5V = 5.2V / 5.2V
                                5V = 5.2V / 5.2V
                                5V = 5.2V / 5.2V
                                5VS = 5.2V / 5.2V
                                GND
                                GND
                                12.5V = 12.7V / 12.9V
                                I also took reading at the secondary diodes (D601, D605, D607) but forgot what they were
                                I hope that would give the experienced users some more details to work with.
                                  That cap should be 630V or higher due to high voltage pulse.
                                  http://www.digikey.com/product-detai...F6474-ND/56678
                                  Bythe way:
                                  474k = 470000 pico farad(pF is x 10 to the minus 12) = .47uF (uF is x10 to the minus 6), K = 10% tolerance)
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #77
                                    Right - that is the blue cap sorted then. I think we need to have a look at the Tcon board it is under a metal panel in one of your pics. Can you get to it and take some pictures - I think there will be fuses on it to test.
                                    Have you tried unplugging the lead to the Tcon from the main board to see if that allows the backlights to stay on?
                                    • woaimi
                                      • Sep 2005
                                      • 94
                                      • US
                                      #78
                                      whew! my 2 little boys are really know how to keep daddy busy, finally able to break away from them to work on this tv set
                                      I couldn't find 1 similar from my pile of electronic junk so I guess I will have to order the replacement.
                                      I scanned through the t-con board and couldn't find any fuse, may be someone can help me spot it. I hope the photo is clear enough
                                      I have not tried this because I currently have couple mosfet off the pcb for testing.
                                      As I mentioned, I de-soldered these 2 mostfet U603 & U600 of the board to test (using retiredcaps instruction). The part numbers are P65NF06 & FQP17P06. The test (setting @ 200 ohm)result are "1" on every pair of leads. Isn't that suggested the mosfet are bad?
                                      EDIT: i found the fuse on t-com board, so obvious can't believe I missed it. It labeled on board as F1 and has letter K on the fuse itself. It measured 0.4 ohm, i think that meas it's good.
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #79
                                        Yes - just check that the "1" is one ohms and not "1" meaning "out of range"
                                        would would mean they are likely ok.
                                        ohm, i think that means it's good.
                                        Yes fuse is good- There are at least 2 voltage regulators on that board
                                        They will need checking if new mosfets and blue cap doesnt fix it.
                                        • woaimi
                                          • Sep 2005
                                          • 94
                                          • US
                                          #80
                                          that was the "1" on the left, so it's out of range
                                          I'm waiting for the blue cap in order, I'll update with result later. Thanks
                                          • caseyjay_48
                                            Sony KDL-46BX450 Inverter Troubleshoot Logic
                                            by caseyjay_48
                                            I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                            I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                            09-23-2022, 08:08 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • lostone
                                            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                            by lostone
                                            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                            05-19-2024, 11:40 AM
                                          • signal.quest
                                            Samsung LN40C630K1F LCD TV No Backlights and Flashlight Test Fail
                                            by signal.quest
                                            I have been working on a Samsung LN40C630K1F LCD TV. On power up the backlights only briefly light up when first powered on then they go out (2 seconds to black). The flashlight test also fails. The sound works fine. Please see attached pics.
                                            I have researched the forums a lot. I have watched the videos of trying to locate the bad CCFL or transformer and bypassing. I can't find any evidence of a bad transformer/CCFL. I verified I get 376V from the big caps to the fuse. I have used a small/cheap oscilloscope and it looks like the MOSFETs on the inverter...
                                            09-30-2024, 11:21 PM
