Polaroid FLM-2601 - Power Supply keeps blowing fuse
    Re: Polaroid FLM-2601 - Power Supply keeps blowing fuse
    OK, we need to check the resistance of V907 (the 24V MOSFET) between S pin and Ground, G pin and Ground.
    Then check the Dc voltage of HV (start up) pin8, Vcc pin 6 (You should see the voltage jumps up if there is any activity).
    You will also want to check that 47uF/25V running cap that is attached to the Vcc pin 6. I would replace it anyway.
    Then also, with the TV is off for 1/2 Hour, check the resistance reading of all to pin of the 24V SMPS IC with ref to ground.
    • tibimakai
      • Jan 2012
      • 3680
      Ha ha, I have just picked up one of these right now and it's completely dead, haven't opened it yet.
      Here is a video one Youtube:
      http://www.youtube.com/watch?v=OqZG1F_h1CA
      I may just keep it as a monitor for my workbench.
      • drpj23
        • May 2012
        • 528
        Sorry I haven't gotten to this, been busy.
        But do have some results. I have not tested the cap or resistance of all the pins yet but here are the voltages and resistances.
        I had to test the board out of the tv so where the ground is connected to chassis is just hooked to an outlet screw.
        I tested from the ground pin of the IC (and the main ground which yielded very different results)
        The results from the ground pin are:
        Pin 6: 6-8v
        Pin 8: 365-380v
        (The voltages would cycle through those numbers)
        S->ground and G->ground were .3 ohms (from pin 4)
          Since youi will be working in the AC Primary side circuits, the circuit Ground for that section will be the Negative leg of that Large Main DC filter cap, not the safety ground.
          Be real carefull not to touch the priamary section with your body, you should have this TV/Board plugged into the GFI outlet. You check the resistance on the pin of the IC with ref to the same ground as above without power to the board, you should let the big cap discharge down to 0 volt.
          • drpj23
            • May 2012
            • 528
            Ok here are the resistances
            P1: 16.38 kOhms
            p2: 86.5 kOhms
            p3: 220 ohms
            p5: 221 ohms
            p6: 5 MOhms (then steadily drops)
            p7: OL
            p8: 8.4 MOhms (then steadily increases)
              Pin5 (output drive) does not read right (I expect at least 4700 Ohms) since it has (R932) 220 Ohm resistor which is connected to Zener Diode D910 to Ground, it also has (R930?) 4700 Ohms resistor in parallel with this Zener Diode. So something must be shorted to Ground at the right side of R932 like shorted out D910. Otherwise it may have internal short. You may have to lift up the IC NCP1207 () pin 5 from the board and take the measurement again. It may have been damaged when the MOSFET went out.
              • drpj23
                • May 2012
                • 528
                I think thats R939 (for resistor in parallel with that zener). Ok, I'll take D910 and the IC out and check it.
                  Just lift just pin 5 and put the meter on pin 5 of the IC and ground to check the resistance. I think pin 5 is shorted out inside the IC.
                  • drpj23
                    • May 2012
                    • 528
                    It measures 3.23 MOhms
                      So the short is external to the IC, if you measure that 4.7K resistor which is in parallel with the Diode D910 (15V Zener), what do you get (do not solder pin 5 back in yet), I expect to see 4.7K Ohms (use Ohm mode to check the resistance).
                      • drpj23
                        • May 2012
                        • 528
                        It is only coming up at .2-1 ohms nonetheless no where near 4.7k
                          That makes sense why you are getting about 200 Ohms reading at pin5, so it can be either shorted out Zener Diode or shorted out Gate to Source on the MOSFET. Take your choice, remove the Diode or the MOSFET to find out where the short is. Getting close!
                          • drpj23
                            • May 2012
                            • 528
                            Well resistor checks out now. I took out the zener and it passes current both ways. So what else should I look for when replacing these other than the power rating?
                              Great! It is 15V, 1/2 Watt will be enough, is it surface mounted? At first thought, I was thinking that your new MOSFET has gone out again.
                              You can use through hole if you have room.
                              Oh, I forgot, there is also Resistor-Diode connected in series and then in parallel with the 220 Ohms resistor, might as well check that also.
                              • drpj23
                                • May 2012
                                • 528
                                Yes it is surface mounted. I might as well start practicing soldering with smd components lol.
                                And thanks so much I am learning a lot through this, oddly enough I just got several samsung and panasonic plasma power supplies all with different issues so hopefully some of this can be helpful towards those or at least the approach and narrowing it down. But they dont have blowing fuse issues lol.....so they might pop up on the site haha
                                  You know, we really have to thank ecking767 for providing us the diagram, otherwise we may have not gotten this far.
                                  • drpj23
                                    • May 2012
                                    • 528
                                    That is true, very much so since the one I had was for a different power supply so that was a humongous help.
                                    • drpj23
                                      • May 2012
                                      • 528
                                      Hello, sorry for not posting in a while. I havn't put in the new diode yet but I am just posting to let you know I have not forgotten, since I know this is valuable to other people; I just had some inconveniencing events which cause me to move. So access to my tools have been slim to none till now so I should be getting back to it soon.
                                      • Danny Parten
                                        • Sep 2012
                                        Does anyone know the value and where to get 926 on the FLM-2601 power supply.
                                        • drpj23
                                          • May 2012
                                          • 528
                                          If you are talking about the component beside 905 that looks like a MOV or round ceramic cap
                                          This may be what your looking for
                                          http://html.alldatasheet.com/html-pd...1/MF72-D5.html
                                          Not same company as mine but it may work
                                          Digikey has those MF72's for under a half dollar if that matches.
                                          • Dannyx
                                            UC3842 Power Adapter Blowing Fuse
                                            by Dannyx
                                            Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
                                            Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
                                            12-05-2023, 12:06 PM
                                          • Tips
                                            Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
                                            by Tips
                                            Looking for some assistance please.
                                            Trying to repair a PD27AOQ samsung power board.
                                            Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
                                            Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
                                            Testing it the fuse blows immediately power is turned on.
                                            diodes dm852 and dm853 test as shorted when in the board but fine when removed.
                                            any assistance, guidance would be appreciated.
                                            04-11-2024, 11:24 AM
                                          • RogerH58
                                            Samsung 46" TV LE46B530 blowing fuse
                                            by RogerH58
                                            I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
                                            I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
                                            I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
                                            06-10-2023, 10:27 AM
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                          • Bootleg1
                                            Samsung UN65KS9800FXZA T-con fuse blowing
                                            by Bootleg1
                                            Hi all, so i was watching tv acreen went black and no sound. Traced problem to blown tcon fuse. Replaced and it blows replaced again samething. So my tcon fuse keeps blowing. I bought a new board havent installed yet infear its just going to keep blowing the fuse. If i only connect the right side ribbon cable the fuse doesnt blow but as soon as i connect the left cable my tcon fuse instantly blows and no picture. The right side picture works clear as day and left side picture is grey (picture attatched) im hoping its a bad tcon board itself or a cable or anything and not the panel. Thank you for...
                                            02-04-2020, 01:05 AM
