Re: Polaroid FLM-2601 - Power Supply keeps blowing fuse
OK, we need to check the resistance of V907 (the 24V MOSFET) between S pin and Ground, G pin and Ground.
Then check the Dc voltage of HV (start up) pin8, Vcc pin 6 (You should see the voltage jumps up if there is any activity).
You will also want to check that 47uF/25V running cap that is attached to the Vcc pin 6. I would replace it anyway.
Then also, with the TV is off for 1/2 Hour, check the resistance reading of all to pin of the 24V SMPS IC with ref to ground.
