Emerson LC401EM2F
  • shorteddiode
    • 221
    Emerson LC401EM2F
    TV was off during a lighting storm but wouldn't turn on after the storm was over. I opened up and to my suprise no dark spots and so far all I have found is a bad diode. Number D1215, but has no markings, it is in the power supply and is glass. Anyone have an idea what the replacement would be, or the location of a schematic? I can never seem to find the schematics I need
    I treid Elektro Tanya with no luck, any other good schematic sources?
    Re: Emerson LC401EM2F
    Can you post a picture of where the diode is used - we may be able to guestimate the replacement type.
      Pictures will help. Main fuse did not blow? I expect the TVS devices to kick in and blow the main fuse.
      • shorteddiode
        • 221
        No fuse on the TV is good, I'll get pics and post them
        • shorteddiode
          • 221
          The first pic shows the diode
          the other two just show the power supply board
          Hope this helps
            Can we see the back side of the board so we can try to trace out the connections and figure out the function of that diode.
            Right now do you get any voltage on that large DC filter cap?
            By the way, is that big blue rectangular case next to the Diode a relay? Otherwise that may be the snubber Diode for the relay coil which are hooked up in parallel, then the Diode will read both way due to the relay coil is in parallel with the Diode.
            • shorteddiode
              • 221
              I'll get pics of the back in the AM, I havent run voltage yet since the diode is bad and the set will not turn on
                I edit my post6 so please read more questions I added.
                • shorteddiode
                  • 221
                  I get no reading on that diode, I'll lift a leg and try it
                    I will wait for the bottom side pictures of the board.
                    So is that blue component a relay?
                    • selldoor
                      Slow Learner
                      • 7870
                      Pictures will need to be a lot sharper for troubleshooting - they should look like this - try outside in daylight.
                      Examples of what is needed
                      https://www.badcaps.net/forum/attach...1&d=1290283049
                      https://www.badcaps.net/forum/attach...7&d=1280167246
                      • selldoor
                        Slow Learner
                        • 7870
                        I have been doing a bit of research on this- The blue box is a relay - see pic of another board.
                        Moving on it seems to be the same chassis as a Philips 40PFL3705DF7 chassis no PL10.5
                        The SM is here:
                        From that the diode is a 1N4148-F0021 ( Datasheet attached)which oddly enough used to be stocked by Sears as a spare part- the page comes up then says not found!! perhaps they still have them?
                        Anyway it stays on long enough to see it is a vishay 1N4148 - lots to choose from at digikey
                        I bet after all that the diode tests good.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          sorry ignore wrong post
                          • shorteddiode
                            • 221
                            Here are pics of the bottom of the board. The two black lines indicate the leads for the diode.
                            I did some voltage tests and I have 79 volts AC accross the diode on both sides of it. No power to the inverter from the power supply board. I have two 5 volt and one 3 volt dc to the main board from the power supply. The set will not turn on and you do not hear any clicks whe the power button is pushed. I forgot to look for a standby light.
                            Thanks selldoor for the diode info
                            • shorteddiode
                              • 221
                              Gaining some ground. The diode was bad, and since I replaced it the TV will click when plugged in but won't turn on. I do not have a standby light but I have 5 volts for standby voltage on the IR board.
                                This chassis looks like it was built by an "engineer" (hah!) trying to save every last penny - it looks awful. You get good 5V, any PSON signal from main board? If so, any main outputs? How is the relay driven?
                                  The Diode is in series with the relay coil.
                                  • shorteddiode
                                    • 221
                                    OK I now have the TV with a standby light, But it will not turn on. When I plug it in the stand by light flashes 16 times then stops. When I oress the power button I get 14 flashes and then it stops unless I press the power button again. I can't find the codes, anyone have acess to them?
                                      Not sure if this service manual is close to what you have or not.
                                      http://elektrotanya.com/?q=showresul...oria=&kat2=all
                                      • BFraley
                                        • Feb 2013
                                        • 4
                                        Alright so im new to this whole forum thing so i dont know how to post a new thread so i guess ill just post on here to see if i can get some help.
                                        well this tv i have here (emerson LC401em2f) whenever you plug it in and try to turn it on a red light starts flashing then stays a steady red after a few blinks. The screen doesnt come on and the fuse is fine. I dont have a schematic for the tv and i dont have any software to open any of the adobe files or pdf files on my computer. Thats all i can tell anyone.
                                        My apoligies to the person who started this thread i just cant figure out how to start a new thread since im new to this.
                                        • Alain Renteria
                                          LG OLED77G2PUA Not Powering On After Storm
                                          by Alain Renteria
                                          Got it for free on marketplace because it stopped working after a storm.
                                          When I began troubleshooting the power supply, I fried 2 fuses and a mosfet by shorting 2 pins on accident, but I've replaced those components.
                                          The tv had a soundbar connected, which was also killed by the storm. On the tv side I found a transistor shorted on the hdmi 2 (arc) and a lot of capacitors shorted on the main board.
                                          Disconnecting and reconnecting the psu to main board cable, while still being connected to 120 V AC, would wake things up, such as a red light from the optical...
                                          11-25-2024, 11:11 PM
                                        • bobbintb
                                          TCL Roku 55S403TCAA dead after storm
                                          by bobbintb
                                          I have a TCL Roku 55S403TCAA. It quit working after a storm. Other electronics quit working as well so I am pretty sure the storm had something to do with it. Anyway, I took a look at it, no obvious damage, blown components, scorch marks, etc. I am looking at the power board first, 40-L141H4-PWG1CG. I've repaired bad caps and blown components but nothing more extensive beyond that. I am trying to troubleshoot it, but I can't even find the fuse on this board. There are markings on the PCB saying "replace fuse as marking" however. I attached a photo of the board. I am also testing the...
                                          11-19-2023, 05:02 PM
                                        • DXseekerMO
                                          Emerson LF501EM5F, turns on, logo appears, shuts off, the perfect storm?
                                          by DXseekerMO
                                          Earlier this week I got an Emerson LF501EM5F that turns on, the logo comes up, a menu and the channel box come on and it immediately shuts down a split second later.
                                          This was bought new and went in a Laundromat. From there it was on from 7AM to 10PM every day.
                                          So why is this the perfect storm? A month ago I got an Emerson LF501EM4 and an EM4A, both will not turn on. The EM4A was struck by lightning and has a serial of DS1 The EM5F has a serial of DS5. The EM4 has a DS4 serial and the chirping transformer problem with a replaced power supply.
                                          The info...
                                          04-07-2018, 10:54 AM
                                        • Mustafa85
                                          Emerson PSU schematic
                                          by Mustafa85
                                          Hi guys,
                                          Any one has Emerson industrial PSU schematic, it has 3 electronics cards in one package please have a look at pics
                                          03-16-2024, 06:46 AM
                                        • littlejohn
                                          Emerson clock radio transformer
                                          by littlejohn
                                          Hello I have a Emerson research clock radio model CKS3516C and the transformer went out on it ,the label on the clock radio says 120VAC 6 watt backup battery DC 3v CR2430. the numbers on the transformer ST3591C-13SEN which I can't find anywhere for it. Can anyone please tell me the AC output voltage. Thanks
                                          08-30-2023, 07:13 PM
