Please Help Have a vizio va26lhdtv10t with not picture
+ More Options
Posts
  • sam55555
    • Apr 2012
    • NC
    So i have a vizio va26lhdtv10t with no picture and I read that this happens because of the backlight inverter but I just want to make sure thats the problem before I buy a inverter for $40.
    Re: Please Help Have a vizio va26lhdtv10t with not picture
    You should up that brown stain off the main board. You need to check F1 (20) black fuse on the inverter board and also F2 (7A) White fuse also on the inverter board. More likely to have blown F1 fuse.
    I have 28 pictures so I am going to post them here, you can see them at:
    http://s807.photobucket.com/albums/y...cpZZ1QQtppZZ20
    By the way, please use advanced/ attachment to post the pictures.
    • selldoor
      Slow Learner
      • 7870
      Hi welcome to the forum - pictures are not really good enough for trouble shooting.
      We should have been able to see the fuses budm refers to. I attach my standard greeting should you need more advice.
      Welcome to the forum-
      We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
      Examples of what is needed
      https://www.badcaps.net/forum/attach...1&d=1290283049
      https://www.badcaps.net/forum/attach...7&d=1280167246
      It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
      • x_orange90_x
        by x_orange90_x
        01-29-2025, 09:24 PM
      • gavric
        Vizio M70-C3 Half picture is bad, main board on its last leg?
        by gavric
        Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
        When tv powers on vizio V logo shows nice on whole screen. picture 1
        When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
        When i start youtube picture shows on left side fine, right is all scrambled. pic 2
        When i click video to start playing picture goes black(like when you change...
        09-02-2021, 08:55 PM
      • ggil44
        Vizio M65-E0 No Picture, No Sound
        by ggil44
        Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
        09-03-2024, 08:30 PM
      • maricm
        Vizio m65-c1 picture flashing on and off on the screen
        by maricm
        HI all,
        hope someone point to the possible issue before I start buying replacement parts.
        Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
        Backlight stays on all the time,
        Sound works fine.
        screen keeps changing form black to full picture in about 1sec intervals.
        Picture looks fine with no visible artifacts.
        I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
        Disconnecting left and right ribbons on...
        11-25-2023, 06:32 PM
      • csmith
        Vizio D50u-D1 Powers up no picture
        by csmith
        I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
        Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
        supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
        issue. Set will power up with remote but not power off....
        07-11-2025, 11:52 AM
