Voltage level on LCD power supply board.
    Re: Voltage level on LCD power supply board.
    My meter was on dc it hit 320 and was slowly still climbing all the small caps had dotd on them.from the factory they dont seem bulged
      I tried that with no results im wondering if the 24v section isnt charging up fast enough
        If i let it charge i can get to the point where the lamps kick on real quick then shut off
          If 24V is taking a long time to rise, that is indicative of bad capacitors on the 24V output.
            does any one know of a way to get a schematic for the power supply pcb it seems like im so close
              Did you try running the TV without inverters connected to see if the TV will stay on as I suggested, unless this TV has an error output signal from the inverter to shutdown the TV if it does not come on.
              That rising voltage on the main DC cap can be due to bad PFC circuits not doing its job.
                I did try that but same results im thinking about shotgunning the caps cant hurt shouldent b to expensive
                  Would it be a bad idea to inject a 24V signal in from an outside variable power supply
                    The 300v tops out around 360 and bounces between that and 380 once its up that high the 24 comesup to 24-25vdc
                      I expect it to be steady around 400Vdc (it should jump up to 400V really fast),I do not have the exact spec, but I do expect it to be very steady.
                      By the way, when the TV is just plugged in but in the OFF condition (power switch not activated), the voltage on that cap should be steady 170V (or if it is jumping around also) and not go up to 300+ until you activate the power switch on the TV.
                        You did suggest at one point that the Big cap had leaked- I think I would try and replace that first although a bit expensive if its not the problem. Just as few further tests does it discharge fully - test after 2 minute and 5 minutes (Carefully in case it retains charge) and observe polarity. Next try pre heating the cap with a hair dryer and see if the 24 volts comes up quicker.
                          I tested it in circuit its a 220uf i was getting pretty close i replaced the three freen caps the dark and light blue ones also a total of 7 caps replaced with no results im debating ordering a referb replacment for around 65.00
                            Simply put someone got into this pcb and im not sure what they did if they did any thing its just the 24v that i can tell is the issue
                              I just got this same set today... Plug in to AC and hear a slight click.. Stand by light is solid and it will not power on at all.. Got the back removed and dont see bulging caps.. All I have had time to do is check some voltages at the long plug on the power board.. Here are the results of that with the AC plugged in
                              Boards connected -------- not connected
                              5v-m=6.8 -------- 6.1
                              5v-m=6.8 -------- 6.3
                              sw= 23.7 -------- 100+ and climbing
                              BR1= 3.7 --------- 100+ and climbing
                              12v= 1.7 -------- .01
                              5v-s= 4.7 ------- 4.8
                              Stb= 2.09 ------- 0
                              Something is jacked
                              *sorry that the spacing on the #s is messed up
                                Boards connected not connected
                                5v-m=6.8 6.1
                                5v-m=6.8 6.3
                                sw= 23.7 100+ and climbing
                                BR1= 3.7 100+ and climbing
                                12v= 1.7 .01
                                12v= 1.7 .01
                                5v-s= 4.7 4.8
                                5v-s= 4.7 4.8
                                Stb= 2.09 0
                                Something is jacked
                                Did you use AC or DC setting to take the measurements?
                                Muh-soggy-knee
                                  Originally posted by ben7 View Post
                                  did you use ac or dc setting to take the measurements?
                                  dc
                                    dc
                                    Ok, that is definitely funky!
                                    Well, I bet theres bad caps in there!
                                    Whats the voltage on the big main filter cap?
                                    Muh-soggy-knee
                                      I will have to check it later.. Kiddo just had friends show up to swim. I will try to slip away and check it..
                                        Ok with AC plugged in 250v 390uf cap reads 1.83 as soon as the probes hit it, but this drops in a blink of an eye to .830
                                          Um, you have both probes on the capacitor leads? (+ on +, - on -)
                                          If so, I think your meter might need a new battery, cheapy ones have been known to give wrong readings with a worn-out battery.
                                          Muh-soggy-knee
