Mitsubishi CNC switching power supply board dead / relay board bad diode failure
 Re: Mitsubishi CNC switching power supply board dead / relay board bad diode failure
 Digi-key, passives, film capacitors. 85,051 Results.
 Then input what you know like: mounting type through-hole, 4,700pF or 10mm lead spacing, Ratings any Y1 or Y2, in stock... down to 42 results.
 Mouser has a checkbox for "safety capacitors" which makes it easier.Comment
 Okay thanksComment
			by InsertCoinHello and happy new year ,
 my Analog Combustion Machine Honeywell gone bad and I don't know what type of diode is utilized.
 There is no mark around the body of the diode. The Schematics are general referred only, without any electronics components and values.
 The two contacts (2),(5) of the Relay Coil need 48 Volts DC to begin operating. Between these two contacts in series is the bad diode and near of contact (5) is the bad pnp (bc856b) Transistor that can be easily replaced.
 I have made a diagram of the PCB and some measurements along some...
			by sam_sam_samThese cheap non brand capacitors at it again
 Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
 Well at least I have the cameras back on line I to try the...
			by sam_sam_samWhen I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
 Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
 This...
			by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
			by sam_sam_samI saw this switching power supply on eBay and wanted to see if could be modified to run 14.5 volts before the blocking diode was add and this switching power supply seems to have no issues doing this
 I did recap the switching power supply except the the main filtering capacitors and I managed to break the selector switch for the voltage setting but just jumped it
 One note I used 25 volt capacitors on the output side of this power supply because they used 16 volt capacitors and because I am running the voltage up a little bit higher 12 volts to 14.5 volts there would...
- Loading...
