Westinghouse SK-32H240S Continued problems
+ More Options
Posts
  • Xavier Renowned
    • Aug 2011
    • 15
    I have been working on a 32" Westinghouse TV and so far I have replaced the inverter transformer and some of the badcaps that I found.
    What is unusual is that after replacing the bad components the TV still won't work. When I turn it on it shows the logo then goes black, then, if I leave it on the picture will show up for a second, then goes black again.
    The capacitors I replaced may not be the right ESR or ripple current rating.
    The old caps were CapXons and the two I replaced were a 2200uF 10v GF 105 C P733 VENT, and a KY 16 v 1000uF (M)105 C 7(7) 8e. Any Links fro finding the specs for these caps would be greatly appreciated. Replaced with 2200 uF, PL(M) nichicon and a 1000 uF FM Matsushita Panasonic cap.
    I also replaced a 5D 3KV, blue ceramic capacitor that was reading 9 pF instead of 5 pF
    In the pictures i have circled the parts I replaced and would like to know where to go next in trouble shooting this board?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Westinghouse SK-32H240S Continued problems
    Could be the CCFL lamps. Do you have another known good inverter you can use to test?
    A working TV? How boring!
    • PlainBill
      • Feb 2009
      • 7034
      This appears to be and should be troubleshot as 'two seconds to black'. The pictures aren't very good, and without a picture of the bottom of the power supply / inverter it's going to require a little extra work. Since you will be doing the work, I don't mind.
      The following tests should be done in as dark a room as possible - you are going to be looking for a brief flash from the backlights.
      Set everything up so you can see the back of the LCD panel. There are usually enough light leaks that you can see if the backlights are on even from the back.
      Disconnect all of the cables to the backlights except one. Turn on the TV. You should see a brief flash before the protection circuits kick in. Turn the TV off, unplug the first CCFL and plug in the next. Turn on the TV and watch for the flash. Repeat for each of the remaining 4 CCFLs.
      With luck, all of the CCFLs except one will light. If none light, repeat, but hooking up a pair at a time, rather than only one.
      Report your results.
      PlainBill
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        I have the same TV and the same problem. I bought this today from someone who had this problem before. They replaced one of the three transformer on the inverter board as it burned the board open. This time (about three months later) it was the transformer on the oposite side of the board that burned open.
        Is this a bad batch of transformers? Should I replace all three to be on the safe side? Where is a good place to find them.
        Pics below.
        I should also mention that resistance checks have been done and they look ok - the ones that weren't burned.
        • retiredcaps
          • Apr 2010
          • 9271
          $10 on ebay + free shipping.
          http://www.ebay.com/sch/i.html?_nkw=4301+transformer
          lcdparts.net also has it, but it is 3x the price.
          http://lcdparts.net/TransformerDetai...ProductID=2774
          --- begin sig file ---
          --- end sig file ---
            Yes those Darfon transformers seem to die all the time.
            • PlainBill
              • Feb 2009
              • 7034
              And from the variety of types that fail, it's not a bad batch, but a systemic problem (poor quality wire, poor winding technique, or both).
              PlainBill
                PlainBill
                It's a shame; the inverters otherwise are a good design (quality caps, good layout & easy to replace the transformers.)
                • PlainBill
                  • Feb 2009
                  • 7034
                  I've got mixed feelings, Once you have the concept, troubleshooting them is easy, and the cost to repair is minimal. On one hand, I'm happy because it was an easy fix. On the other hand I feel sorry for the original customer. On the OTHER hand, I worry that another will fail and my customer will be unhappy.
                  PlainBill
                  • Dgtech
                    E. Technician
                    • Apr 2009
                    • 1462
                    • Steeler
                    PlainBill
                    For this reason, I will replace all three but then again, there's no guarantee.
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Agreed, no guarantees, but there is one indication. I've replace a 4006A type transformer, the secondaries read about 950 ohms. On the replacement the secondaries read somewhat lower - around 800 ohms as I remember. Yet the new transformer worked perfectly. The only conclusion is the 'after market' transformer has the correct turns ratio, but heavier gauge wire - which should be less likely to break.
                      PlainBill
                        PlainBill
                        Same here - I've replaced a 4010A which read about 100 ohms below all the others, but it worked fine. I thought the resistance was part of how they balance the current in each bulb, so I was surprised it worked...
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Do the math. The typical CCFL draws about 4 - 6 ma at 800 - 1200 volts. Taking the worst cases (6 ma, 800 volts, 150 ohm difference), the variation is only .9 volts, about .1%
                          PlainBill
                            PlainBill
                            So, why does transformer resistance matter so much when identifying faulty inverter transformers? (Noob here!)
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              beause you will find the bad one open or many shorted turns.stands out from the others.made in the same batch they should all be close.
                              • PlainBill
                                • Feb 2009
                                • 7034
                                As kc8adu said, it's the most practical way to identify a transformer with an open or shorted secondary (it is highly unlikely there would be an open primary).
                                A much better method would be a ring tester, but that is a rather specialized piece of equipment that most hobbyists won't have.
                                PlainBill
                                • Dgtech
                                  E. Technician
                                  • Apr 2009
                                  • 1462
                                  • Steeler
                                  CRAP!!! Now I caught a snag with this TV. There is a capxon at location C709 (inside the two heatsinks). It had the white glue on it covering the value. When I lifted it up from the board, the glue snatched off the plastic covering with the value. I need to know what this cap is. I tried to find a schematic or parts list with no luck.
                                  • Xavier Renowned
                                    • Aug 2011
                                    • 15
                                    That capacitor is 2200 uf and 10v I replaced this one too, but the new one is too big for the heat sink bridge plate now and there isn't space to lay it on its side. sorry haven't been on since Nov. busy Christmas season.
                                    • Mike95inNJ
                                      • Feb 2011
                                      • 18
                                      Re: Westinghouse SK-32H240S Garbage picked yesterday.
                                      I found this yesterday morning being tossed to the curb. I found this post and I'm glad I did. These forums are always helpful to me when trying to fix a discarded lcd/plasma tv. This was a two seconds to black tv. I saw the three bulging caps right away and thought to myself I'd have it up and running in no time. Then I got a closer look and saw the fried transformer. If I had'nt read this I would've never known about these known issues and just want to say thank you to everyone that posts replies to help out noobs like me when it comes to trying to bring a tv back to life. I ordered the transformer I found on ebay for $9.69 free shipping from China. Just have to wait a couple of weeks for delivery. I hope the pcb itself isn't ruined by that nasty burn mark.
                                      I already replaced the bad capxcon caps. I'll post a followup after replacing the transformer. Thanks again for all the expertise offered here. I appreciate it.
                                      Take care, MikeinNJ
                                      • Mike95inNJ
                                        • Feb 2011
                                        • 18
                                        I received the replacement transformer today and replaced it but unfortunately it did not fix the problem. I followed PlainBill's advice by
                                        testing the CCFL's by unplugging all but one connector and powering it up in
                                        a dark room. I did this for all six connectors and had a flash for each one.
                                        So I assume all six lamps are working. I could see each individual lamp light
                                        up on the screen as well. Same symptoms as described by Xavier Renowned.
                                        Westinghouse logo shows up, goes black, backlights come back on then goes black. Is it possible that the burn mark from the fried transformer ruined the pcb itself? Any advice would be helpful.
                                        Thanks, Mike
                                        • darckreign1984
                                          lenovo y530 dead ite replaced - problems
                                          by darckreign1984
                                          shorted pin-id with vcc
                                          initial-ite------
                                          IT8226e-128
                                          1839-BXS
                                          S167RA
                                          L002
                                          i test with this type (3 chips,same results)
                                          IT8226E-128
                                          1649-BXS
                                          -laptop show for a short time lenovo logo without light
                                          i test the ite from a lenovo y540 - laptop start, i can work on windows - all good, only problem battery cant be charged, and when i connect the laptop turn off in few seconds
                                          IT8226E-192
                                          1847-BXA
                                          03-22-2023, 11:06 AM
                                        • dragon3x
                                          by dragon3x
                                          power on.
                                          Here are some examples :
                                          switching supply area).
                                          than 6.3 V.)
                                          03-21-2025, 02:46 PM
                                        • jean luc ferre
                                          laptop hp g72 b52sf screen problems
                                          by jean luc ferre
                                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                          i verified the driver of the pΓ©ripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                          06-07-2025, 03:27 PM
                                        • Hondaman
                                          USB problems?
                                          by Hondaman
                                          Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                          (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                          I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                          08-12-2024, 03:26 PM
                                        • MicroSMD Lab
                                          MSI MS-16W1 no power, EC replaced by other.
                                          by MicroSMD Lab
                                          Hi, I'm working on a MSI laptop, Motherboard number MS-16W11, GF-65 Thin 10SDR-459US. Went to another shop because the screen was flickering, but it was working well on an external monitor. The LCD was ordered and the laptop was returned to the customer and it no longer worked. It was then sent to another tech (by the shop who ordered the LCD) and the EC (ENE KB9028Q) was replaced with a donor from another MSI board with different board number and no programming was done. It looks like work was done on PU6 (TPS51225) as well as one of the GPU mosfets was burnt (I removed all three GPU mosfets)....
                                          03-27-2025, 07:35 AM
