vizio vw42l hdtv10a no picture/sound
  • aftonr
    • Aug 2011
    • 42
    I'm hoping someone here can help me with my problem, I have a vizio vw42l hdtv10a and I get no picture or sound out of the tv. I took off the back cover and seen the back lights are coming on but again no picture or sound. I can turn on and off the tv by using the panel buttons but thats it no menu channel up/down etc.. I have looked over several other threads involving similar problems and this is what I have replaced on the mainboard so far....
    Mouser #: 621-AP1117E18G-13
    Mfr. #: AP1117E18G-13
    Desc.: Low Dropout (LDO) Regulators LDO BI 1.0A
    used for u9
    Mouser #: 511-LD1117ASTR
    Mfr. #: LD1117ASTR
    Desc.: Low Dropout (LDO) Regulators LOW DROP
    FIXED REG
    used on u8, u2, u33, u7
    Mouser #: 667-EEU-FM1E221
    Mfr. #: EEU-FM1E221
    Desc.: Aluminum Electrolytic Capacitors - Leaded
    220UF 25V ELECT FM RADIAL
    used on ce75, ce8, ce7, ce14, ce16, ce91, ce2, ce1, ce5, ce6, ce23, ce11, ce27, ce18, ce25, ce26, ce20
    Mouser #: 667-EEU-FR1V471
    Mfr. #: EEU-FR1V471
    35VDC 470uF 10x16mm LS5mm
    used on the two inverter boards,
    I also followed the repair manual for this tv on the dc to dc converter trouble shooting guide (see attachment) after replacing all the parts listed above all voltage readings came out correctly as stated in the repair manual. and something else I noticed before doing repairs on the master inverter board there was a blue led on the pcb that would come on then go off, but after doing repairs it stays on so I guess I did something good just not good enough. thanks in advance for any help on this.
    “Be Who You Are and Say What You Feel Because Those Who Mind Don't Matter and Those Who Matter Don't Mind.”
  • rmoody
    Learning Member
    • Jul 2011
    • 262
    Re: vizio vw42l hdtv10a no picture/sound
    I would look at the Tcon, I had the same model with a bad Tcon once.
    • aftonr
      • Aug 2011
      • 42
      how would you check the tcon?
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        Your main problem is consistant with that of an inverter board issue. There are multiple threads for this same TV set. If you search this forum for that tv model number you will find threads that tell you how to test these inverters and so on.
        Here is a post of mine from a similar set with the same symptoms.
        https://www.badcaps.net/forum/showth...974#post129974
        • cadiman
          • Mar 2010
          • 397
          check for power at the t-con (small tiny fuse upon cable input 12vdc or so)
          I would then go after the video board.
          You said you have backlight?
          Can you turn the tv off? (That is a big one) If not then you may need a mainboard.
          • aftonr
            • Aug 2011
            • 42
            dgtech thanks for your reply, I looked at that post during my repairs and checked the master and slave inverter they were reading 8.5k-8.4k ohms on both boards I also replaced capacitors on these boards. I also checked fuses on tcon, slave, master and main board all good and I can turn on/off tv with the control panel buttons also I have Backlight. hope this is enough information and sorry it's taking me so long to respond to your posts I'm in CT doing storm restoration work from hurricane Irene, its hard to find the time to reply. again thanks for your help
            • rmoody
              Learning Member
              • Jul 2011
              • 262
              I had the same problem with the same tv once and the fuse checked ok but I still ended up replacing the Tcon board. I found one on ebay for 35 bucks so instead of trouble shooting the Tcon further i just bought one there. Mine also had the problem where it wouldn't turn off as mentioned earlier. I replaced U33 regulator to fix that problem but I still had the backlight only problem that was later solved by the Tcon replacement
              • aftonr
                • Aug 2011
                • 42
                rmoody, I just purchased a tcon it shows it arriving 9-15-11 I will post the results when it is installed.
                • rmoody
                  Learning Member
                  • Jul 2011
                  • 262
                  good deal, let us know, maybe it will fix it. It's usually the cheapest board to buy anyways.
                  • aftonr
                    • Aug 2011
                    • 42
                    your the man rmoody got the board in last night hooked it up and fired up like a champ. thanks for your suggestion.
                    • rmoody
                      Learning Member
                      • Jul 2011
                      • 262
                      Good deal, I checked everything i could think of on my vw42L before finally purchasing a tcon and saved the day. Mine had vertical multi color lines like a public broadcasting announcement background.
                      • aftonr
                        • Aug 2011
                        • 42
                        well I got to do some smd soldering while fixing this tv what an experience Im just glad I got the tv back I was hesitant to try the tcon but I figured it's only 50 bucks why not. thanks again!
                        • shorteddiode
                          • 221
                          I have mine fixed, I replaced U2 U7 U8 U9, U33 and CE27. I screwed up removing U8 and pulled up the pad to the adj side of the regulator and I was even using the chip set stuff. Luckly it was easy enough to trace it back to the adjusting resistor so I used a small piece of wire and ran from the resistor to the regulator and saved the board. Now I have ordered a Hot air rework station for SMD work.
                          • shorteddiode
                            • 221
                            Want to thank everyone on this site, great information and without you guys I couldn't have fixed my TV
                            • Echo210
                              • Aug 2013
                              I am having the same issue as the person who started this thread. Since I am not very savvy with tech issues coulds someone explain what a Tcon is.
                              Thanks, Jon
                                Are you getting backlights?
                                Here are the pictures of the boards, there are more than one version of this TV.
                                http://www.shopjimmy.com/catalogsear...+vw42l+hdtv10a
                                • blmcamp
                                  • Aug 2013
                                  • 18
                                  I have a very similar issue with a VIZIO VW42L HDTV10A. I am fixing it for a older couple in our community and trying to save them from having to buy a new one. when I first got the TV it was not getting any power, the Visio light on the front would not com on either Orange or white. from another thread I found that the f1 fuse on the main board was bad. it had no power across the fuse and when I pressed the power button the F2 fuse did not get any power. I ordered and replaced the f1 fuse (3A) and now both of them get power when I press the power button and the f2 looses power when I turn the power off.
                                  However, the back lights do not come on still. so from another thread I was led to test the power on the J1 connector to the Main power/inverter combo board. here are the voltage readings I get:
                                  unit in standby
                                  Pin#
                                  14 0.0
                                  13 0.0
                                  12 4.7
                                  11 4.7
                                  10 4.7
                                  9 Blank
                                  8 0.0
                                  7 0.0
                                  6 0.0
                                  5 0.0
                                  4 0.0
                                  3 0.0
                                  2 0.0
                                  1 0.0
                                  unit turned on "white logo"
                                  14 1.5
                                  13 0.0
                                  12 4.7
                                  11 4.7
                                  10 4.7
                                  9 Blank
                                  8 0.0
                                  7 0.0
                                  6 0.0
                                  5 0.0
                                  4 12.0
                                  3 12.0
                                  2 12.0
                                  1 2.1
                                  When I turn the unit on, the blue lite on the tcon board comes on bright and then fades out. Is that normal.
                                  I have also checked the voltage at the connectors for the inverters by checking red to ground and white to ground and with the unit on none of them have any volts.
                                  I am at a loss now where to go form here. can someone please tell me what is going on. I have good pictures and can post them.
                                    We need to know what the pins are labeled as so we can tell if it is getting the correct signals. Does it have any kind of labels, I.E. ps_on, stby, etc.? Pictures of your board?
                                    • blmcamp
                                      • Aug 2013
                                      • 18
                                      Here are some photos of the connector. I have to sigh off for today but will check back tomorrow, thank you
                                      • blmcamp
                                        • Aug 2013
                                        • 18
                                        OK. I am back now. I had to go home and put our some fires
                                        I hope the pictures I attached help.
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • ggil44
                                          Vizio M65-E0 No Picture, No Sound
                                          by ggil44
                                          Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                          09-03-2024, 08:30 PM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • shelby5041
                                          vizio d40f-j09 no pic no sound standby always clear
                                          by shelby5041
                                          hi
                                          anybody have experience with this model tv
                                          07-19-2025, 06:58 AM
