vizio d40f-j09 no pic no sound standby always clear
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    hi
    anybody have experience with this model tv
  • fharris1977
    Vizio D50u-D1 Dead Set No Standby
    by fharris1977
    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
    12-28-2023, 10:25 AM
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
  • B0r1s
    Samsung UE49KS7000SXXH - fast clicking sound in standby mode
    by B0r1s
    PSU - BN44-00878A
    Symptoms:
    The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
    A weak clicking sound was coming from the transformer.
    Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
    Progress:
    After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
    01-17-2023, 04:58 PM
  • rebelkustoms
    VIZIO D60-F3 Wont Power ON, No Standby, No Picture, No Sound
    by rebelkustoms
    Hi all, got a new set to look at. This one is a Vizio D60-F3 it has no standby light, wont power on and has no pi or sound. I have checked continuity in the fuse. I checked the pinouts to the motherboard several times and I am getting no voltage on any of the pins. Guy who gave it to me told me it was turning on then going off and then it stopped coming on. There are pics of the model and powerboard. Thanks...
    10-29-2020, 12:23 PM
  • ggil44
    Vizio M65-E0 No Picture, No Sound
    by ggil44
    Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
    09-03-2024, 08:30 PM
