Polaroid TLA-04011c Red Light on, no power on
  • PlainBill
    • Feb 2009
    • 7034
    Re: Polaroid TLA-04011c Red Light on, no power on
    Originally posted by ryn0909
    lovely.... lol i was probing the caps with the multimeter in diode mode, checking to see if i could find any that had a direct short but founf none. HOWEVER, i did notice that all the 16v 220uF caps would measure around the same except for 2 of them. those 2 would go to infinite while none of the others would. Is that a sign of a bad cap??
    No.
    The problem COULD be a bad cap, but I'd suspect otherwise. One thing I suggest is checking the LDO regulators on the main board. They are one of the few readily identifiable and testable components on the board.
    According to information I found, the 200-107-gt321xa-Bh can be used as a replacement for the 200-107-gt321xa-Ah
    PlainBill
    • ryn0909
      Professor X
      • 122
      awsome ldo regulators do u know off hand how to check them or should i check it out online? either way, thanx a million i appreciate it yer the man PlainBill
      • PlainBill
        • Feb 2009
        • 7034
        As usual, retiredcaps has an excellent description of the process. I'll do my best.
        A common LDO type is the xx1117-vv family, usually found in the SOT-223 package. xx represents two or three letters which normally represent the manufacturer. Common ones are AS, CLM, IRU, REG, TS, etc. vv identifies the output voltage - Typically 18, 25, and 33, representing 1.8 volts, 2.5 volts, and 3.3 volts. If vv is missing, it's an adjustable regulator.
        I've attached a picture of the SOT-223 package. The pins are numbered left to right 1, 2, and 3. Pin 2 is electrically connected to the tab. Pin 1 is Gnd, or the Adj pin. Pin 2 is the output, Pin 3 the input.
        Testing is easy. Measure the voltage from circuit board ground (NOT pin 1) to pin 2. It should correspond to the voltage designated by vv. If it doesn't check the voltage on pin 3. It should be at least 1.2 volts higher than the output voltage designated by vv. Now, since the board is not receiving main power, most of the LDOs will have no input voltage. What you hope to find is an LDO regulator with 5V in (from 5Vstby) and some non-standard output voltage.
        PlainBill
        • ryn0909
          Professor X
          • 122
          ok ill do the checks. i did notice that this component had gotten really hot. hot enough to the point that the solder on the legs of it is pitted and the packaging is discolored. i circled it in the picture i attached. sorry for the not so great photos, my camera sux ass when i get it that close, i even zoomed in and out and its just a crappy camera.
          • ryn0909
            Professor X
            • 122
            ok after doing the checks on the ones labeled xx1117-vv, they all measured out to be the same. from board ground to PIN1: 2.08vdc PIN2:3.35vdc PIN3: 4.95
            Now, in the picture i attached, the one circled is labeled U35, marked with UTC 78TO5AL i checked it for shits and giggles and this is what i got..... From board ground to PIN1: 11.89vdc PIN2: 0VDC PIN3: 4.98vdc. i dont know if that is relevant or not. Sorry if im jumping ahead.....
            • Scenic
              o.O
              • Sep 2007
              • 2642
              78T05AL is a beefed up version of the 7805 linear voltage regulator. basically (as in how they work) the same thing as those xx1117-vv.
              output 5V (05 at the end) with 3A (indicated by the T).
              you measured 4.98V, so that's probably ok.
              That AIC1084PM is an adjustable voltage regulator capable of 5A
              http://www.alldatasheet.com/datashee...C/AIC1084.html
              to find out if that's ok, you would have to find out what voltage it's supposed to put out first (as it's adjustable, not fixed voltage like the others).
              • ryn0909
                Professor X
                • 122
                ok thanx for the info Scenic, really appreciate it. Well now im at a stand still, not quite sure what to check from here. Its gotta be something that can be replaced rather than getting a whole new board.cuz if i have to go that route, ill be screwed. lol
                • PlainBill
                  • Feb 2009
                  • 7034
                  I don't see why. There are several compatible main boards on eBay available for under $130 delivered. Granted, a Polaroid is a poor excuse for a TV, but your friend could still wind up with a working 40" TV for about half the price of a new one.
                  PlainBill
                  • ryn0909
                    Professor X
                    • 122
                    true i guess yer rite.... i just have a thing for having to fix something if i think i have a chance at fixing it lol
                    • crtfool
                      • Jun 2010
                      • 82
                      Here's an idea - Since you are fixing it for your friend, why don't you get the board on eBay - make sure that the TV does work properly, then very carefully take measurements and comparisons between both boards - you can use this as a learning exercise for your own experience, and you may actually determine what is wrong with the original board. You are going to charge your friend for the repair anyway, and you can sell the original board on eBay if you do fix it - WIN WIN.
                      • ryn0909
                        Professor X
                        • 122
                        well thats a good idea only thing is that im broke rite now and im not gonna charge them to fix it..... because it happened to die when i brought a desktop computer over to their house and hooked it up to the tv with the vga cable. the tv turned on, showed the desktop and we played around in windows for about 5 min, then i rebooted the pc to make sure it was gonna boot properly and while it was rebooting the tv screen went black. as if it went to standby mode and just never came back on
                        • crtfool
                          • Jun 2010
                          • 82
                          The red light of death is very common on these Polaroids - I am quite sure that you connecting a VGA computer to the TV had absolutely nothing to do with the failure, but trying to convince your friend of that will be impossible. I have had similar situations happen to me, and there is no way that anyone will believe that it was just a coincidence.
                          Here is an example that happened to me recently - I have 2 laptops that were working perfectly - I shut them down properly, and when I tried to turn them on again - NOTHING! The second 1 died about 3 months after the first. Both of them are dead motherboards.
                          • ryn0909
                            Professor X
                            • 122
                            EXACTLY! so im not gonna even try to convince them or argue about it, its one of those thing were ill just bite the bullet on it. lol
                            • cadiman
                              • Mar 2010
                              • 397
                              #34
                              I have had no power supply issues with these.
                              I have had three with main board problems. I found a good used one on ebay for 22.00 (The whole module).
                              I had a lot of green pins on the plug connection where the module plugs into the tv also.
                              I think these also had the amf1116s fail.
                              • ryn0909
                                Professor X
                                • 122
                                i know its gotta be sumthing thats staring me right in the face. i just dont know if and how to check the caps. can i do it with a multimeter? if so do i check them in circut or out of circut? im willing to learn if someones willing to teach. im not to proud to admit when i dont know how to do something. lol
                                • crtfool
                                  • Jun 2010
                                  • 82
                                  You need an ESR meter to check capacitors.
                                  I highly doubt that it is a bad capacitor - I checked every cap on mine when I was troubleshooting, they were all perfect. It probably is an IC failure, and they can't be tested without documentation.
                                  • ryn0909
                                    Professor X
                                    • 122
                                    ahh i see, thanx for that info. so basically i could make a list of all the ics and get their data sheets online then test each one??
                                    • crtfool
                                      • Jun 2010
                                      • 82
                                      Theoretically, yes - but very unlikely that you will get any info on most of them, and even more unlikely that you can buy replacements.
                                      • Dgtech
                                        E. Technician
                                        • Apr 2009
                                        • 1462
                                        • Steeler
                                        #39
                                        Not really true. I use a Fluke 87-III that has a capacitance check function on there. It will not measure ESR but it will find a bad cap by measuring the uF (micro farad) value. For instance, good 2200uF caps will measure a little high at 2500uF. I have a bad one in a power supply that measures low at 2000 uF. Sometimes you'll get no reading at all on a cap that will need to be changed. The ESR is important also, however, I never use one. If I manufactured caps, I might use one. I just swap out bad caps with new ones. There are lots and lots of TV's out there with high ESR caps in them that work just fine.
                                        • ryn0909
                                          Professor X
                                          • 122
                                          Dgtech..... as you were saying about checking the caps, do i check them in or out of circut??
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • russpall
                                            LG 39ln540v - red light flashes twice, no power to LED driver?
                                            by russpall
                                            Hi there,
                                            I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                            The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                            08-27-2024, 01:07 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            Laptop computer that went completely dead no boot no power light no hard drive light
                                            by sam_sam_sam
                                            See pictures for type of laptop computer
                                            I checked switching power supply brick 19.2 volts multi meter only
                                            No booting without switching power supply connected
                                            Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
                                            What the heck is going on here...
                                            04-04-2025, 04:58 AM
