Sony XR-77A80J OLED 5 Blink
dont miss with PSU,, you have SOS signal coming so the MB turn off t-CON 12 & EVDD, to work around
Thank you for your response Diah . The only difference I saw was in the pins below located at CN6401:
1.TCON_12_ON = 3.38v for half a second then down to 0v
3. EVDD_ON = 0v then when I hit power button goes to 3.38v then to 0v once red light is present.
Here are the picture below where I started at pin 1 on both PSU to MB then PSU to TCON. I noticed that R712 does not have continuity, is it supposed to have continuity? R712 also flashes 12v on one side for half a second.
try
1- disconnect the socket of EVDD only from the T-CON driver boards then turn on..... yours sign TV start the audio Optic output lit red
2- if No 1 didnt help... put back the EVDD plug in place. and just disconnect the lower LVDS from T-CON and turn on check same sign on MBComment
Forgive my ignorance Diah is this is incorrect. When I unplug the circled socket (I'm assuming this is the EVDD) I get the same result.
try
When I disconnect the LVDS from the T-CON (see picture) boots and I hear audio.Comment
is the audio optic output lit red on the mainboard?
1. Optical turns red for one second then goes away as the red light starts to blink again
2. Optical turns red and stays red as the TV is on and I am getting audio with no display and no red blinking light.Comment
			by iglitareHi,
Or is it always a bad/shorted... -
			by jason123Hi there,
I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
I see 2 posts that are relevant:
https://www.badcaps.net/forum/troubl...j-oled-5-blink
https://www.badcaps.net/forum/troubl...g-hardware-dev... -
			by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
			by thelankanguyThe TV shows a black screen with no image.
TCON ribbon connectors were disconnected individually for image and there was no half image even.
Later both ribbons were disconnected and TCON voltages were tested.
12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
There is also a short to ground in this circled inductor.
Is this a TCON issue or something else ?... -
			by bbrainHi,
I have this problem with my Sony 55' AG9.
It flashes 4x.
I have found the service manual, and seems it is the TCON.
Before I buy a TCON can someone check the vid?
Thanks in advance!... - Loading...
