Sony XR-77A80J OLED 5 Blink
  • lotas
    • Jan 2016
    • 4803
    • Russia
    #61
    Originally posted by ChattFix
    I noticed that R712 does not have continuity, is it supposed to have continuity? R712 also flashes 12v on one side for half a second.
    These are load, kilo-ohm resistors, one terminal is on ground, the other on +.
    • ChattFix
      • Oct 2021
      • 79
      • US
      #62
      lotas thank you for that clarity. The other kilo-ohm resistors have continuity so it confused me. So I'm assuming that is good so I need to start working backwards.
      • vinceroger69
        • Mar 2012
        • 6714
        #63
        Thanks lotas everyday is a learning day
        • Diah
          • Feb 2013
          • 6498
          Thank you for your response Diah . The only difference I saw was in the pins below located at CN6401:
          1.TCON_12_ON = 3.38v for half a second then down to 0v
          3. EVDD_ON = 0v then when I hit power button goes to 3.38v then to 0v once red light is present.
          Here are the picture below where I started at pin 1 on both PSU to MB then PSU to TCON. I noticed that R712 does not have continuity, is it supposed to have continuity? R712 also flashes 12v on one side for half a second.
          dont miss with PSU,, you have SOS signal coming so the MB turn off t-CON 12 & EVDD, to work around
          try
          1- disconnect the socket of EVDD only from the T-CON driver boards then turn on..... yours sign TV start the audio Optic output lit red
          2- if No 1 didnt help... put back the EVDD plug in place. and just disconnect the lower LVDS from T-CON and turn on check same sign on MB
          • ChattFix
            • Oct 2021
            • 79
            • US
            #65
            try
            Forgive my ignorance Diah is this is incorrect. When I unplug the circled socket (I'm assuming this is the EVDD) I get the same result.
            When I disconnect the LVDS from the T-CON (see picture) boots and I hear audio.
            • vinceroger69
              • Mar 2012
              • 6714
              #66
              is the audio optic output lit red on the mainboard?
              • ChattFix
                • Oct 2021
                • 79
                • US
                #67
                Thank you for pointing that out. Diah yes the optic output lit red for a second then went out.
                • Diah
                  • Feb 2013
                  • 6498
                  at which point 1 oe 2 it come on.....? so now you dont have error blinking.... it could be the tv go to STBY try turn it on with RC
                  • ChattFix
                    • Oct 2021
                    • 79
                    • US
                    #69
                    1. Optical turns red for one second then goes away as the red light starts to blink again
                    2. Optical turns red and stays red as the TV is on and I am getting audio with no display and no red blinking light.
                    • Diah
                      • Feb 2013
                      • 6498
                      stay at points 2 now.... and measure the EVDD 2 black sockets at T-CON and the T-CON 12V ( white socket)
                      • Diah
                        • Feb 2013
                        • 6498
                        Man be careful the disconnected LVDS didn't make contact with Chassis because its active now,,,, this why we disconnect it from MB side .
                        • ChattFix
                          • Oct 2021
                          • 79
                          • US
                          #72
                          I'm not getting anything from the three sockets connected to the T-CON board. I disconnected the LVDS from the MB as well, thanks for that.
                          • Diah
                            • Feb 2013
                            • 6498
                            you said TV booted and you hear sound... so it mean MB send to PSU t-con 12 on and evdd on
                            • ChattFix
                              • Oct 2021
                              • 79
                              • US
                              #74
                              T-CON 12 = 0.01v (I notice this jumps to about 3v when I hit the power button)
                              EVDD ON = 3.38v
                              • Diah
                                • Feb 2013
                                • 6498
                                EVDD ON = 3.38v
                                turn off.... unplug all sockets on PSU .. just PSU plug it in wall and write which pins and its V of course only pins which it go to mainboards
                                • ChattFix
                                  • Oct 2021
                                  • 79
                                  • US
                                  #76
                                  All pins are 0v after unplugging everything from the PSU and testing the pins that go to the mainboards.
                                  • Diah
                                    • Feb 2013
                                    • 6498
                                    common,,, how it come,,, at least you will have V at pins 6 STBY LOL... did you plug it in wall,,,,
                                    • ChattFix
                                      • Oct 2021
                                      • 79
                                      • US
                                      #78
                                      Haha here is a picture.
                                      • Diah
                                        • Feb 2013
                                        • 6498
                                        yours socket are 2 row pins LOL....take the boards out side the set.... put it on the table and plug it in wall... use the black probe on cold area GND
                                        • ChattFix
                                          • Oct 2021
                                          • 79
                                          • US
                                          #80
                                          Lol its not on 2 pins but I'll take the board off and test again.
                                          • iglitare
                                            by iglitare
                                            09-04-2025, 07:13 AM
                                          • jason123
                                            Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                                            by jason123
                                            Hi there,
                                            I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                                            So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                                            I see 2 posts that are relevant:
                                            https://www.badcaps.net/forum/troubl...j-oled-5-blink
                                            https://www.badcaps.net/forum/troubl...g-hardware-dev...
                                            10-29-2025, 02:01 PM
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • thelankanguy
                                            Sony KD-55X9000F TCON Issue
                                            by thelankanguy
                                            The TV shows a black screen with no image.
                                            TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                            Later both ribbons were disconnected and TCON voltages were tested.
                                            12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                            There is also a short to ground in this circled inductor.
                                            Is this a TCON issue or something else ?...
                                            12-13-2024, 12:27 AM
                                          • bbrain
                                            Sony KD-55AG9 TCON?
                                            by bbrain
                                            I have this problem with my Sony 55' AG9.
                                            It flashes 4x.
                                            I have found the service manual, and seems it is the TCON.
                                            Before I buy a TCON can someone check the vid?
                                            Thanks in advance!...
                                            09-19-2024, 10:50 AM
