Samsung UE55MU6120K Boot loop with backlight no video
  • lotas
    • Jan 2016
    • 4753
    • Russia
    #41
    Re: Samsung UE55MU6120K Boot loop with backlight no video
    This jumper is placed to determine which half of the panel is not working, insert one cable and turn on the TV, then do the same with the other cable.
    • lotas
      • Jan 2016
      • 4753
      • Russia
      #42
      Here I give you a photo of each half (left and right cable) where to isolate the CKV. Maybe it will be easier for you.
      • Diah
        • Feb 2013
        • 6439
        lotas photo this is the cKV usual get issue at NU/MU/TU.
        ESD you cant test them with DMM. only if you have Laser Temp pointer you will find one of them more warm to hot than other.
        • fanaticgames
          • May 2017
          • 138
          • italy
          #44
          I put scotch tape on both flats and the result is that it restarts anyway, tried to put first on one, then on the other and then on both, when the flats are connected the TV restarts
          I positioned the tape counting pin by pin with the microscope so there is no error, covered the pins from 12 to 20 and then from 75 to 83
          • lotas
            • Jan 2016
            • 4753
            • Russia
            #45
            Remove the jumper and test without it. Isolated should be only on one half, on the one that does not work.
            And you need to put adhesive tape on the other side where the contacts are on the cable.
            • fanaticgames
              • May 2017
              • 138
              • italy
              #46
              The
              jumper has already been removed, the wire is broken, and I tested it by covering one flat at a time
              obvious that the tape is also on the side of the pins
              • Diah
                • Feb 2013
                • 6439
                mask only the LVDS on the top of MB.... from Top count 11 pins and mask 9 pins.. it can be too from top start from 10 or 9 try you will have working TV at least but not perfect
                by the way we have in forum digram where to mask on NU... MU will be same way just 1.2 more or less...
                • fanaticgames
                  • May 2017
                  • 138
                  • italy
                  #48
                  I have already covered the pins that lotas told me, can you name other pins other than his? honestly I don't think much will change since the TV keeps restarting with 2 connected flats
                  • fanaticgames
                    • May 2017
                    • 138
                    • italy
                    #49
                    you mean in this area?
                    • Diah
                      • Feb 2013
                      • 6439
                      NO
                      i linked before lotas photo... its for LVDS which are on the top of MB... and as lotas remarked... i give you other remark to count from the top 11 pins and start masking.
                      • lotas
                        • Jan 2016
                        • 4753
                        • Russia
                        #51
                        Sometimes it helps in some situations to reduce the VGH voltage to the panel and the reboot stops.
                        • Diah
                          • Feb 2013
                          • 6439
                          blue color
                          • lotas
                            • Jan 2016
                            • 4753
                            • Russia
                            #53
                            CN1802_UT (USI-T RIGHT) and CN1801_UT (USI-T LEFT)
                            • fanaticgames
                              • May 2017
                              • 138
                              • italy
                              #54
                              blue color
                              ok, I understand, I'll try like this then, leaving the other flat free
                              • fanaticgames
                                • May 2017
                                • 138
                                • italy
                                #55
                                The pinout is clear, first I covered exactly the ckv area, first right and then left but nothing has changed
                                • PaolinaSparks
                                  • Feb 2023
                                  • 4
                                  Hi fanaticgames,
                                  i had the same error.
                                  Please try to block only the CKV lines without the STVP line. So the pins 12-19 on the left cable(CN1801). You have to work very precisely, preferably with a microscope. Do not block any pins on the right cable. Connect both cables and test if there is a picture.
                                  If there is no picture, you block the CKV lines without STVP on the right cable. So the pins 76-83 on the right cable(CN1802). Don't block anything on the left cable. Reconnect both cables and test. If an image comes up in one of the two attempts, we'll see what's next.
                                  • fanaticgames
                                    • May 2017
                                    • 138
                                    • italy
                                    #57
                                    Originally posted by PaolinaSparks
                                    Hi fanaticgames,
                                    I'll try later and update the status here
                                    • fanaticgames
                                      • May 2017
                                      • 138
                                      • italy
                                      #58
                                      Hi fanaticgames,
                                      nothing changes, it always restarts, i guess the ckv lines have nothing to do with it at this point
                                      • fanaticgames
                                        • May 2017
                                        • 138
                                        • italy
                                        #59
                                        blue color
                                        Nothing has changed
                                        I masked both 10 pins and 9 consecutive pins
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4463
                                          • Italy - Milan
                                          #60
                                          Now that we have listen to the others would you like to follow my advice? what do you think?
                                          • Takeatry
                                            Yet another Samsung QLED Boot Loop
                                            by Takeatry
                                            Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                            10-04-2024, 02:57 PM
                                          • torchzack
                                            Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                            by torchzack
                                            Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                            I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                            Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                            08-28-2023, 07:42 AM
                                          • NolesFan
                                            Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                            by NolesFan
                                            Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                            10-24-2024, 06:36 PM
                                          • eigma
                                            Samsung UN40H5003 boot loop every ~8 seconds
                                            by eigma
                                            Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                            Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                            SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                            Main board: BN94-07592P / BN97-08922R...
                                            11-20-2024, 10:31 PM
                                          • signedupfordownload
                                            Samsung UE49KU6500U boot loop
                                            by signedupfordownload
                                            My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
                                            With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
                                            I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?...
                                            07-29-2024, 01:56 PM
