Hello, TV Saamsung UE50MU6102K, BN94-12432B, BN41-02568B damaged W25Q40CL insert, please repair.
Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
Attached FilesComment
Hi Lotas, can you fix the file, please?
I tried some other files, but I managed only to have the stand-by led on.
Thank youAttached FilesComment
Hi Lotas,
I tried with the fix file but the TV set is dead. The standby LED turns on for 1 sec every 15 sec. The standby voltage from 8v goes to 13v. At first, the TV was totally dead. Now it looks like there is some life in it but there must be a hardware problem in the mainboard.
Anyway, I want to thank you for your effort and time. I wish you the best. Thank you.Comment
The TV does not turn on, there is no standby mode! SAMSUNG UE55mu6192 ver01Attached FilesComment
Hi Lotas UE55MU6172 IC401 can you fix please.
Regards,
Pat.Attached FilesComment
Hi Lotas, my TV model is UN50MU6100GCZB, Board Code: BN41-02568B from Argentina. I'm having the same issue as another user before. The standby LED turns on for 1 sec every 15 sec. When Flashing an incorrect bin, the board stays completely dead. So I guess it could be bios related. could you help me? Thanks in advanceAttached FilesComment
Dear Sir can you help me with dead main board ( BN41-01587) for Samsung ua40d6400un and power board (BN44-0427A)
i uploaded the flash files from 24c02 (IC 1205) & 24c512 (IC 1401)
A5 & 3.3 vdc are exist.
thanks in advance.Attached FilesComment
Where did you get the idea that the problem is in these firmwares, if there is no standby mode and the LED is not on, then a common problem in this chassis is IC204 (stabilizer from 5v to 3.3v) and micom Weltrend, check the resistance at 1.2 pin IC203 relative ground and is there 3.3v power on these pinsComment
I measured the regulator and i/p 5.3 v & o/p 3.3 v so it is good, also the voltage at pin 1&2 3.3v and no short with ground. i tried to press the reset button but nothing happened
how can i check ic1203 (61P805) is healthy ??
does it need programing? if yes can it be done by CH341?
What initially happened to the TV? In service mode, at the point you clicked on “Micom Update” and after that the TV stopped turning on?
If yes, then the firmware has been erased in micom, you need to program it.
And also, you have some strange dump 24C512, or it is so badly damaged or poorly read, try this one.Last edited by lotas; 08-19-2024, 11:33 AM.Comment
Hi lotas,
can you help me with this firmware???
Samsung UE55MU6400U
M/B BN41-02568B (BM94-12401R)
by totofCould you help me...
I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
Then motherboard connected, standby led is on and current consuption is 18W.
Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
The model of my TV is :
Power supply BN44-00807A
Main Board BN41-02568B / BN94-12765W
Panel CY-GM055HGLV3H... -
by AhariHi all,
I...-
by jeangonbayCould you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
The model of my TV is UE43MU6105K
Main Board: BN41-02568B
BN94-12007Y
Could you help me to repair the dump please. Thank you.
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by MephysisHello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"? - Loading...
