Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
There should be only (S3, S7, S9, S14).
Try to record your native dump again via NeoProgrammer_2.2.0.10.
In the program:
1. Click "Detect Chip" and select W25Q40CL and "Select IC".
2. Click "Unprotect".
3. Click "Clear IC" and "Yes".
4. Click "Open File" and select your corrected dump.
5. Press "Program IC" and "Yes".
6. Click "Verify IC".
7. Press the down arrow to the right of "Unprotect" and select "SREG Edit", put a check mark on SRP0, BP1, CMP, QE (S3, S7, S9, S14) and press "Write" and "Yes"
7. Close the program. Ready.Comment
In the program:
Dear lotas ,
I already have some default parameter set. That's why I can't set the register code 0x42.Comment
Try this dump.
And is your CH341A black or green?Attached FilesLast edited by lotas; 03-18-2025, 11:04 AM.Comment
https://www.fs-pcba.com/ru/spi-vs-i2c/Last edited by lotas; 03-18-2025, 03:17 PM.Comment
[QUOTE=lotas;n3596169]
Don't make me laugh, where did spi flash get the I²C Protocol from, it's not eeprom.
https://www.fs-pcba.com/ru/spi-vs-i2c/[/QUOTE
then start to laugh lotas, script written as befehl which SoC do it as I2C act via eMMC / NAND firmware , when position of script address at SPI or eEPROM different the SoC will take order but it cant deliver it to Main Firmware.. this called Step BY Step start..Comment
by totofCould you help me...
I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
Then motherboard connected, standby led is on and current consuption is 18W.
Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
The model of my TV is :
Power supply BN44-00807A
Main Board BN41-02568B / BN94-12765W
Panel CY-GM055HGLV3H... -
by AhariHi all,
I...-
by jeangonbayCould you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
The model of my TV is UE43MU6105K
Main Board: BN41-02568B
BN94-12007Y
Could you help me to repair the dump please. Thank you.
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by MephysisHello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"? - Loading...
