Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • cortador
    • Feb 2017
    • 6
    • spain
    #41
    Re: Samsung UN55MU6103F IC1604 dump
    Hello
    I could review this eeprom of a samsung ue65mu6402uxx that does not work and when removing the connection from the source the leds light up
    Thank you
    • lotas
      • Jan 2016
      • 4753
      • Russia
      #42
      Originally posted by cortador
      Hello
      Thank you
      Try.
      • cortador
        • Feb 2017
        • 6
        • spain
        #43
        OK muchas gracias, no funciono mirare otras opciones
        • lotas
          • Jan 2016
          • 4753
          • Russia
          #44
          After writing the dump, did you set and write the status register (0x88, 0x42)?
          • cortador
            • Feb 2017
            • 6
            • spain
            #45
            Hello, the board had another fault, if it worked without problems, then I will dump the other memory, which was the one that also failed
            Thank you very much
            • cortador
              • Feb 2017
              • 6
              • spain
              #46
              This is the dump of the eprom of the samsung that did not work
              • lotas
                • Jan 2016
                • 4753
                • Russia
                #47
                This is not the dump you posted, this dump is W25Q80DV (IC1603) - T-CON, but W25Q40CL (IC1604) is needed!
                • cortador
                  • Feb 2017
                  • 6
                  • spain
                  #48
                  Yes, it's clear, I know, I'm only uploading it for any member who needs it, it's from a board that's working and that prevented my TV from working
                  • giogipala
                    • Jun 2008
                    • 10
                    #49
                    hi, I have a tvUE55MU6500U main BN41-02568B BN94-12394N the screen remains black and the TV restarts if I disconnect the panel flats the TV works, with a new main the TV can be seen well so the panel is ok.
                    I tried to modify the original file with the procedure described with AsProgrammer_2.1.0.13_fix but the TV still doesn't start, maybe I made a mistake?
                    • lotas
                      • Jan 2016
                      • 4753
                      • Russia
                      #50
                      This dump is working for you, the problem is different.
                      • giogipala
                        • Jun 2008
                        • 10
                        #51
                        could it be the spi t-con file?
                        can I write another file?
                        • nomoresonys
                          • 12276
                          • U.S.
                          #52
                          Quick question, can I program 25Q32FVSIG with CH341A?
                          • lotas
                            • Jan 2016
                            • 4753
                            • Russia
                            #53
                            Yes.
                            • nomoresonys
                              • 12276
                              • U.S.
                              #54
                              Got this mini black ch341a, the software for it doesn't seem to be clickable but the rest do, do I need to pick a different one? : https://ch341aprogrammersoftware.com/
                              • nomoresonys
                                • 12276
                                • U.S.
                                #55
                                Wonder is that their official site or is it some fraud site?
                                • lotas
                                  • Jan 2016
                                  • 4753
                                  • Russia
                                  #56
                                  I have posted software for CH341A many times, at least here https://www.badcaps.net/forum/showpo...81&postcount=8
                                  • nomoresonys
                                    • 12276
                                    • U.S.
                                    #57
                                    Right right, I hate regurgitating shit over and over again too, our dear friend Budm would put those things he found he had to keep going over, in his signature, great idea, then he could just say look at #3 below, like pictures, that's going in mine, SOO tired of typing that shit out.
                                    • zaratustrax
                                      • Aug 2015
                                      • 9
                                      • mexico
                                      #58
                                      Hi everybody.
                                      I have a similar problem with my Samsung Un55mu6300.
                                      When I plug the cable the leds turn on and off. If I disconect the Mainboard the leds keep on.
                                      I was trying to fix and I already programed the bios chip using the programmer tl866ii, but no luck.
                                      Browsing a lot I found this post and I beg you to clear my bin file please.
                                      In addition I want to point that my file is 1024 kbytes Long, but to my surprise the files that the People have uploaded in this topic is half the size. I thought that maybe the chip was touch but ir wasnt. The solder points were old as the other in the board.
                                      If you please clear my file I am going to try the options as describe in post # 4
                                      Thanks in advance for your help
                                      • lotas
                                        • Jan 2016
                                        • 4753
                                        • Russia
                                        #59
                                        Originally posted by zaratustrax
                                        Hi everybody.
                                        You posted a dump from T-Con, it is responsible for the panel settings - this chip is IC1603 25Q80 (1024k), but you need IC1604 25Q40 (512k) it is responsible for the standby mode, if you saved the dump from 25Q80, put it back and post it from 25Q40!​
                                        • zaratustrax
                                          • Aug 2015
                                          • 9
                                          • mexico
                                          #60
                                          Thanks a lot for your reply.
                                          I made a terrible mistake. You are right, the ic is different. And I could find the correct one.
                                          I attached the file, please clean my bin archive.
                                          Thanks again for your help and guidence
                                          • Yanleb
                                            UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
                                            by Yanleb
                                            My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
                                            Disconnecting the main board from the power supply makes the backlight come ON.
                                            I did disconnect the panel cables and the WIFI modules, the board is still dead.
                                            I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
                                            Thanks.
                                            11-18-2024, 12:34 AM
                                          • ogabuga
                                            Asrock B650E PG-ITX BIOS_WHP1 /25Q40/
                                            by ogabuga
                                            Hello, I need a dump of the BIOS_WHP1 /25Q40/, EC controller chip /NTC6686D/. The motherboard is coming for repair after a another service, what is in the dump that I downloaded is the beginning of the MAIN BIOS, according to the analysis that I did based on the documentation of the EC controller NTC6686D, the content should be different. BIOS_WHP1 /25Q40/ is connected directly to SCE1#, SO1, SI1, SCK1 pins 66, 68, 67, 69 of the NTC6686D​
                                            01-28-2025, 04:48 AM
                                          • alro7779
                                            Samsung UN55MU6103F video problem; has colored stripes on the display
                                            by alro7779
                                            Hello, everyone!
                                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                            09-27-2025, 11:29 PM
                                          • totof
                                            Samsung UE55MU6102K IC1604 dump needed - TV don't start
                                            by totof
                                            Could you help me...
                                            I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
                                            Then motherboard connected, standby led is on and current consuption is 18W.
                                            Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
                                            Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
                                            The model of my TV is :
                                            Power supply BN44-00807A
                                            Main Board BN41-02568B / BN94-12765W
                                            Panel CY-GM055HGLV3H...
                                            05-01-2023, 04:30 AM
                                          • Mirenia
                                            Samsung UEMU6199U - no Standby - bad Firmware?
                                            by Mirenia
                                            I've got a Samsung UEMU6199U which has no Standby LED and no reaction if try turning it on.
                                            Voltages on the power supply board is okay. Backlight test is also okay.
                                            I read about a corrupt firmware on IC1604 on some models, did a dump of this IC and turns out: First sectors are empty.
                                            So I think my TV has exactly this issue.
                                            Can someone please fix the dump?
                                            And how do you do that?
                                            As I understand you fill in the empty sectors and leave the rest as it is. But where do you get the "information" of what you...
                                            05-12-2025, 06:13 AM
