Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • pepebmx
    • Aug 2020
    • 11
    • Argentina
    #201
    Hi, I have a Samsung TV model UN43MU6100GCZB (mainboard BN41-02568B BN41-02568). It first had random HDMI issues, then progressed to turning on with backlight but shutting off after a few seconds. All main power rails are present. Could you please check this dump? I suspect its the main problem. Thanks a lot!
    • lotas
      • Jan 2016
      • 4753
      • Russia
      #202
      Hi, your dump is fine, working, the problem is different.
      • zmeutul
        • Apr 2018
        • 17
        #203
        Hello. I also have a samsung ue65mu6172 with the bn41-02568b motherboard that doesn't turn on and doesn't have the standby LED. From what I saw in the hex of the W25Q40CL chip, it seems to be corrupted at first. Can you help me with its repair? Thank you very much!
        • lotas
          • Jan 2016
          • 4753
          • Russia
          #204
          Done, try it, don’t forget about status register (0x88, 0x42).
          • zmeutul
            • Apr 2018
            • 17
            #205
            Perfect. The TV works. Thank you very much.
            • lotas
              • Jan 2016
              • 4753
              • Russia
              #206
              OK!
              • catran
                • May 2013
                • romania
                #207
                hello, can you help me with UE50mu6102k mainboard bn41-02568b, stdby led on, flash on power on but still on after 1sec below is 25q40, panel is CY-GK050HHNVMH, tested without mainboard, leds ok, power ok on plugin
                • lotas
                  • Jan 2016
                  • 4753
                  • Russia
                  #208
                  If this dump is native, original, then it works.
                  Read the dump again with the programmer and see what the programmer shows about the status register, what it is set to (should be 0x88, 0x42).
                  • catran
                    • May 2013
                    • romania
                    #209
                    hmmmm...take a look at the picture please, i thing is something wrong
                    • lotas
                      • Jan 2016
                      • 4753
                      • Russia
                      #210
                      Yes, it is not so, it should be so.
                      • tuanvo_86
                        • Jul 2023
                        • 7
                        • VIETNAM
                        #211
                        Hello
                        I have one u43mu6100 with no boot problems. I have the Ic1604. It is possible to fix it?
                        Thank you​
                        • lotas
                          • Jan 2016
                          • 4753
                          • Russia
                          #212
                          Originally posted by tuanvo_86
                          Hello
                          Thank you​
                          Try.
                          • tuanvo_86
                            • Jul 2023
                            • 7
                            • VIETNAM
                            #213
                            Try.
                            thanks it works
                            • Israel Caballero
                              • May 2025
                              • España
                              #214
                              Hello. I have a samsung ue50mu6125 with the bn41-02568b motherboard that doesn't turn on. Can you help me with its repair? Thank you very much!​
                              • lotas
                                • Jan 2016
                                • 4753
                                • Russia
                                #215
                                Your dump is fine, working.
                                • Salvatore Cancellieri
                                  • May 2025
                                  • 8
                                  • Italia
                                  #216
                                  I have this TV with standby LED off, I downloaded the dump, it doesn't seem original to me, is it possible to try to repair it?
                                  TV UE55MU6220 board BN41-02568A
                                  • lotas
                                    • Jan 2016
                                    • 4753
                                    • Russia
                                    #217
                                    It doesn't seem to you, but it is true, some smart flasher, without unpacking the dump from winrar, wrote it down just like that!
                                      • May 2025
                                      • 8
                                      • Italia
                                      #218
                                      ​I compressed the dump in winrar, is there any way to repair it?
                                      Is there any way to get this TV to work?
                                      • lotas
                                        • Jan 2016
                                        • 4753
                                        • Russia
                                        #219
                                        It won't be possible to restore it, since it's not a dump, either you counted it incorrectly, or someone wrote something incomprehensible there. What happened to the TV, what's its history?
                                          • May 2025
                                          • 8
                                          • Italia
                                          #220
                                          I called the customer, they told me that they tried to repair it but he doesn't know if they tried to program it, I asked if it is possible to have the original file if they saved it
                                          • Yanleb
                                            UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
                                            by Yanleb
                                            My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
                                            Disconnecting the main board from the power supply makes the backlight come ON.
                                            I did disconnect the panel cables and the WIFI modules, the board is still dead.
                                            I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
                                            Thanks.
                                            11-18-2024, 12:34 AM
                                          • ogabuga
                                            Asrock B650E PG-ITX BIOS_WHP1 /25Q40/
                                            by ogabuga
                                            Hello, I need a dump of the BIOS_WHP1 /25Q40/, EC controller chip /NTC6686D/. The motherboard is coming for repair after a another service, what is in the dump that I downloaded is the beginning of the MAIN BIOS, according to the analysis that I did based on the documentation of the EC controller NTC6686D, the content should be different. BIOS_WHP1 /25Q40/ is connected directly to SCE1#, SO1, SI1, SCK1 pins 66, 68, 67, 69 of the NTC6686D​
                                            01-28-2025, 04:48 AM
                                          • alro7779
                                            Samsung UN55MU6103F video problem; has colored stripes on the display
                                            by alro7779
                                            Hello, everyone!
                                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                            09-27-2025, 11:29 PM
                                          • totof
                                            Samsung UE55MU6102K IC1604 dump needed - TV don't start
                                            by totof
                                            Could you help me...
                                            I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
                                            Then motherboard connected, standby led is on and current consuption is 18W.
                                            Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
                                            Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
                                            The model of my TV is :
                                            Power supply BN44-00807A
                                            Main Board BN41-02568B / BN94-12765W
                                            Panel CY-GM055HGLV3H...
                                            05-01-2023, 04:30 AM
                                          • Mirenia
                                            Samsung UEMU6199U - no Standby - bad Firmware?
                                            by Mirenia
                                            I've got a Samsung UEMU6199U which has no Standby LED and no reaction if try turning it on.
                                            Voltages on the power supply board is okay. Backlight test is also okay.
                                            I read about a corrupt firmware on IC1604 on some models, did a dump of this IC and turns out: First sectors are empty.
                                            So I think my TV has exactly this issue.
                                            Can someone please fix the dump?
                                            And how do you do that?
                                            As I understand you fill in the empty sectors and leave the rest as it is. But where do you get the "information" of what you...
                                            05-12-2025, 06:13 AM
