Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • lotas
    • Jan 2016
    • 4653
    • Russia
    #141
    Circuit diagrams for new models, starting with the “D” series, cannot be found even in service centers, since they do not repair boards, but replace them entirely. Why can’t you read eeprom 24c512, did you unsolder it and read it through an adapter?
    • Mr.Pc
      • Jan 2023
      • 41
      • Brasil
      #142
      Thanks for the explanation regarding the schematic. Regarding reading the eeprom, I unsoldered it and put it in my adapter, which is also soldered to the eeprom, but it didn't recognize it, so I believe it is bad. An interesting detail is that it doesn't have a pin 1 indicator (only on the motherboard it does) and I also didn't understand why pin 1-4 is on gnd on the motherboard, I looked at the datasheet to try to understand better but it didn't work. Anyway, I imagine that if this eeprom is bad, I won't be able to solve it because of the software that I can't read.
      • lotas
        • Jan 2016
        • 4653
        • Russia
        #143
        And how do you read it, like an eeprom or like a spi flash 25q40, you can post a photo of the eeprom itself and the programmer log, what it writes.
        • Mr.Pc
          • Jan 2023
          • 41
          • Brasil
          #144
          I can yes!
          • lotas
            • Jan 2016
            • 4653
            • Russia
            #145
            Originally posted by Mr.Pc
            I can yes!
            Why do you choose "Auto 25...", this is not the 25th series (spi flash). and 24 series (eeprom), you need to manually enter 24C512 and press "Select".
            • Mr.Pc
              • Jan 2023
              • 41
              • Brasil
              #146
              I had already done this, but another error occurred. (check id error) So as I didn't know what it was, I was afraid to continue.
              • lotas
                • Jan 2016
                • 4653
                • Russia
                #147
                Yes, why do you always have 25, it should be 24, I wrote above that you need to write 24C512, or is the number “4” button on your keyboard not working?
                • Mr.Pc
                  • Jan 2023
                  • 41
                  • Brasil
                  #148
                  Forgiveness! It was my lack of attention . I managed to read it now.
                  • lotas
                    • Jan 2016
                    • 4653
                    • Russia
                    #149
                    Yes, it is damaged, try recording a dump on it, the one I posted here on 24C512.
                    • Mr.Pc
                      • Jan 2023
                      • 41
                      • Brasil
                      #150
                      Right! I'll do it now and I'll be back here to tell you.
                      • Mr.Pc
                        • Jan 2023
                        • 41
                        • Brasil
                        #151
                        I made the recording, but it didn't work. Now the LED no longer blinks, the regulator that was previously oscillating between 2.5v and 3.3v is now between 1.12v and 1.11v and getting very hot. I took the 24c off again and put the old software on, but it persisted the same way. To program the 24c, just load the .bin and click on program, right?
                        • lotas
                          • Jan 2016
                          • 4653
                          • Russia
                          #152
                          First erase the chip, then program the bin file, maybe after your experiments this eeprom is damaged, try without it, the power will not rise to 3.3v, is the chip soldered correctly?
                          • Mr.Pc
                            • Jan 2023
                            • 41
                            • Brasil
                            #153
                            Got it! The 24c is soldered correctly. I turned on the board without it and the regulator still gets quite hot, so I removed the inductor and it doesn't heat up anymore, but I believe that something really happened in these tests because when I put the inductor in, both the regulator and the inductor start to heat up again. I'm going to change the inductor tomorrow to see what happens because I don't have equipment to measure inductance. Regarding deleting the 24c, when I open the recorder program, the option to delete it becomes unavailable, so I can only load the .bin file and program.
                            • lotas
                              • Jan 2016
                              • 4653
                              • Russia
                              #154
                              Something may be shorting on this bus, what resistance on this bus is not low, maybe an inductor (turn-to-turn short circuit). eeprom 24 series does not have a status register.
                              • Mr.Pc
                                • Jan 2023
                                • 41
                                • Brasil
                                #155
                                Hello! I replaced the inductor and it was back to normal. I believe that when I went to remove it I heated it too much and it must have ruined it. On the 24c the LED was blinking the same way. I did both with your dump and mine again.
                                • lotas
                                  • Jan 2016
                                  • 4653
                                  • Russia
                                  #156
                                  I don't know how else to help you...​
                                  • Mr.Pc
                                    • Jan 2023
                                    • 41
                                    • Brasil
                                    #157
                                    Since then you've helped me until now, so it wasn't a lack of help. I'm going to try to buy another motherboard. Have a good day!
                                    • lotas
                                      • Jan 2016
                                      • 4653
                                      • Russia
                                      #158
                                      If you are looking for a new motherboard, look for the number on the white paper tag, it is BN-94-xxxxx, so that there are fewer compatibility problems with your panel.​
                                      • Mr.Pc
                                        • Jan 2023
                                        • 41
                                        • Brasil
                                        #159
                                        I haven't made the purchase yet, but I'm grateful once again for this important tip.
                                        • Beard dwarf
                                          • Dec 2024
                                          • 5
                                          • Украина
                                          #160
                                          SAMSUNG UE40MU6402
                                          There is no standby mode. I tried to fix the firmware myself, the standby mode appeared, but when I turn on the image there is no. Maybe I did it wrong.
                                          Can anyone help?
                                          • totof
                                            Samsung UE55MU6102K IC1604 dump needed - TV don't start
                                            by totof
                                            Could you help me...
                                            I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
                                            Then motherboard connected, standby led is on and current consuption is 18W.
                                            Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
                                            Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
                                            The model of my TV is :
                                            Power supply BN44-00807A
                                            Main Board BN41-02568B / BN94-12765W
                                            Panel CY-GM055HGLV3H...
                                            05-01-2023, 04:30 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • jeangonbay
                                            Samsung UE43MU6105K IC1604 dump needed - TV don't start
                                            by jeangonbay
                                            Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
                                            The model of my TV is UE43MU6105K
                                            Main Board: BN41-02568B
                                            BN94-12007Y
                                            Could you help me to repair the dump please. Thank you.
                                            02-16-2024, 05:46 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
