the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 Pro -
Re: the gutless, bloated, and fried power supply hall of shame
btw i did save some parts before i tossed it.
could have fixed it if i wanted to wait a month for the part to come slow boat but i have better things to do besides polishing turds.
because that is what all leadman/coming data/deer/whatever they go by this week are.shitboxes.Comment
Here's a Solid Gear SDGR-750E (Leadman LP-8869E) from a friend's computer. Secondary caps are Chengx, no idea about the others. Looks like maybe a 300W to me.Attached Filesif you find these attachements useful please consider making a small donation to the site
Looks fairly good actually.
PWM chip for the 5V_STBY, and a decent sized main transformer.
Note that there is a to-247 device on the secondary heatsink! That is probably a fairly beefy rectifier.Muh-soggy-kneeComment
A Leadman with a bridge rectifier? That's news to me!Comment
Delta Serverpower 450W EX. (CAA-450BT A). Was browsing the Web on my Ivy Bridge system when there was a loud pop from the power supply and the system shut down. I took it apart but there is no sign of damage. I think only the fuse blew. I would like to identify the problem that caused the fuse to blow. Any ideas? It has only been in use for less than two years.Attached Filesif you find these attachements useful please consider making a small donation to the site
^ If you're troubleshooting, you may want to start your own thread to get more (specific) replies. This thread is mostly meant for posting pictures of crappy power supplies (which yours really isn't).Comment
250W max with ripple barely in specs is the best you could get from it.Comment
Forgot to post the power ratings. Is it safe to use it in a 200W system? Eg. Pentium Dual Core (E5400, 45nm), integrated graphics, 2 sticks of DDR2 RAM, 1x SATA 7200rpm hard drive, 1x DVD-RW drive and a 12cm case fan?Attached Filesif you find these attachements useful please consider making a small donation to the site
It is unsafe to use it anywhere unless you put some input filtering, coils on the secondary and change the caps.Comment
Agreed. As it stands, I wouldn't allow that within a mile of any of my PCs.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
OK, so I should add pi filter coils on the secondary and change all the caps. Do I need pi filter coils of any particular specification, or can I just rip them from another power supply? Also, on the transient filter, what do I need to add? It appears to have one coil, two X caps and two Y caps in place. Thank you for your advice.Comment
I suspect you will need to calculate the right value for the pi coils rather than just put anything in, if you want the PSU to operate correctly and stable. How you would do that though I have no idea."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
by bauto601Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
A "nice" YoungYear unit? - Badcaps
The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish.... -
by eccerr0rIntroducing... the POS-124Z which really is a POS:
Yep it's a POS allright.
I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
So I had to take a peek:
EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?... -
by tamerelaputeHi,
I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
Except the cpu, I cant feel anything getting warmer.
I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
I believe that if the cpu was fried,... -
by x_orange90_xI was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
by LapsmithWhile installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
- Loading...
