the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • c_hegge
    • Sep 2009
    • 5219
    Re: the gutless, bloated, and fried power supply hall of shame
    Originally posted by kc8adu
    i suspect cougar is too.
    Nope, Cougar is simply HEC/Compucase's retail brand
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      #942
      btw i did save some parts before i tossed it.
      could have fixed it if i wanted to wait a month for the part to come slow boat but i have better things to do besides polishing turds.
      because that is what all leadman/coming data/deer/whatever they go by this week are.shitboxes.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        I don't blame you. What did you decide to keep out of it? Usually Leadman uses decent wires because they want the exterior to look good so that it will sell...
        • lti
          • May 2011
          • 2547
          The cutout in the heatsink around the 5VSB rectifier diode is nice.
          • cheapie
            null
            • Jul 2010
            • 849
            Here's a Solid Gear SDGR-750E (Leadman LP-8869E) from a friend's computer. Secondary caps are Chengx, no idea about the others. Looks like maybe a 300W to me.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Looks fairly good actually.
              PWM chip for the 5V_STBY, and a decent sized main transformer.
              Note that there is a to-247 device on the secondary heatsink! That is probably a fairly beefy rectifier.
              Muh-soggy-knee
              • lti
                • May 2011
                • 2547
                It's the same thing as the Inland. Based on the model, this one is probably rated for 750W.
                • ncovert
                  • Feb 2011
                  • 291
                  A Leadman with a bridge rectifier? That's news to me!
                  • tleu8472
                    • Dec 2011
                    • 36
                    #949
                    Delta Serverpower 450W EX. (CAA-450BT A). Was browsing the Web on my Ivy Bridge system when there was a loud pop from the power supply and the system shut down. I took it apart but there is no sign of damage. I think only the fuse blew. I would like to identify the problem that caused the fuse to blow. Any ideas? It has only been in use for less than two years.
                    • tleu8472
                      • Dec 2011
                      • 36
                      #950
                      PS. I don't recall any smoke coming out of the unit.
                        master hoarder
                        • May 2008
                        • 12164
                        #951
                        ^ If you're troubleshooting, you may want to start your own thread to get more (specific) replies. This thread is mostly meant for posting pictures of crappy power supplies (which yours really isn't).
                        • tleu8472
                          • Dec 2011
                          • 36
                          #952
                          Thanks for the suggestion. I have just started a new thread.
                          • tleu8472
                            • Dec 2011
                            • 36
                            #953
                            GTR Type-R 400W. Thoughts welcome. All the caps on the secondary are Cheng brand 10V 1000uF, no pi filter coils.
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              #954
                              250W max with ripple barely in specs is the best you could get from it.
                              • tleu8472
                                • Dec 2011
                                • 36
                                #955
                                Forgot to post the power ratings. Is it safe to use it in a 200W system? Eg. Pentium Dual Core (E5400, 45nm), integrated graphics, 2 sticks of DDR2 RAM, 1x SATA 7200rpm hard drive, 1x DVD-RW drive and a 12cm case fan?
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  Looks like a good candidate for some modding though!
                                  Muh-soggy-knee
                                  • goodpsusearch
                                    • Oct 2009
                                    • 2850
                                    • Greece
                                    #957
                                    It is unsafe to use it anywhere unless you put some input filtering, coils on the secondary and change the caps.
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      Agreed. As it stands, I wouldn't allow that within a mile of any of my PCs.
                                      • tleu8472
                                        • Dec 2011
                                        • 36
                                        #959
                                        OK, so I should add pi filter coils on the secondary and change all the caps. Do I need pi filter coils of any particular specification, or can I just rip them from another power supply? Also, on the transient filter, what do I need to add? It appears to have one coil, two X caps and two Y caps in place. Thank you for your advice.
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 4925
                                          • New Zealand
                                          #960
                                          I suspect you will need to calculate the right value for the pi coils rather than just put anything in, if you want the PSU to operate correctly and stable. How you would do that though I have no idea.
                                          -David VanHorn
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
