Bestec ATX-300-12Z REV.EHR
  • POM_MJ
    • Aug 2009
    • 228
    I've a Bestec ATX-300-12Z REV.EHR.
    It supply 4.98V(5V), 3.32V(3.3V), 11.80V(12V).
    Is there possibly to make it supply 12.0V (or nearly) on 12V rails? How to do?
    please advise.
    3.3Vsense is brown wire, 5Vsence is pink wire, has no 12Vsense wire.
    | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
    | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
    | 2xWD7500AYYS | 2xHD322GJ Raid0 |
  • Toasty
    • Jul 2007
    • 4171
    Re: Bestec ATX-300-12Z REV.EHR
    Usually putting a load on the power supply brings the voltage closer to spec. 11.80v is within the ATX specification of +/- 5% (11.4v-12.6v).
    Toast
    veritas odium parit
    • POM_MJ
      • Aug 2009
      • 228
      I've measure those voltages when the PSU is supply to M/B DFI NF4-D, Athlon64 3000+, DDR1 2x512MB, GeForce 7300GS, no HDD.
      and put more 12V load by 6.6 ohm (serie of two 3.3 ohm resister).
      I've used the above system to test many of PSUs, all of them are supply 12.xxV except this Bestec unit.
      Could be possibly, It has some defected in 12V circuit?
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        11.8 is well in atx spec, so no it is not defective. This is a heavily 5v and 3.3v based unit, with little on the 12v, and with that processor is a 12v based cpu I would expect it to be about there.
        Are you doing a burn in test while measuring these voltages? If not, it may just not be a big enough load for that bestec to ramp up the 12v.
        • Toasty
          • Jul 2007
          • 4171
          I don't know the age or "hours-in-use" of this supply. You may want to investigate those output caps. OST's are known crap and could be weak allowing the 12v to sag.
          Toast
          veritas odium parit
          • POM_MJ
            • Aug 2009
            • 228
            Thankyou for every answers.
            Yes, like Toasty said 11.4V-12.6V is stay in ATX spec.
            I just worry with this unit because it doesn't supply 12.xxV like the others.
            No, not yet.
            Ok, I'll try to burn in test with a bigger load, then post the result later.
            Toast
            Output caps are look good, they're Ltec and Jamicon.
            for 12V pi filter, 2,200/16V and 1,000/16V Jamicon.
            more info about output diodes, used STPS3045CW for 3.3V, 2xSPTS3045CW for 5.0V and 2xSPTS20H100CT for 12V.
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              All the ones that I see in that picture with the X top are OST. I only see one jamicon, and one tk.
              • Toasty
                • Jul 2007
                • 4171
                >>Output caps are look good, they're Ltec and Jamicon.<<
                <shakes head>
                More crap. Looks mean nothing.
                Replace those output caps now and save yourself the headache(s) later on of:
                1) chasing errors that will have you swearing it's a Windows problem
                2) blown caps on the mobo from having to handle the ripple from that PSU
                There are 7 I think. Looks like one under the wire bundle. 15 minutes now = saved hours later.
                Toast
                veritas odium parit
                • c_hegge
                  • Sep 2009
                  • 5219
                  The OST caps could already be failing. I've seen them fail without bulging or leaking. The others (Jamicon and Ltec) may be OK now but replace them anyway as they will more than likely fail in the future. Also, given the problems that other members have experienced with Bestec PSUs, I wouldn't even re-cap it. Just toss it out and replace it with thermaltake or coolermaster.
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3112
                    Bestecs are actually good power supplies after being recapped. Almost as good of quality as delta's, excluding the -12E series.
                    I would choose it over some thermaltakes. Lower end ones are overrated HEC's, and the higher end are CWT's that have mediocre ripple suppression (just under atx spec,) and ok voltage regulation.
                    Coolermaster, unless you buy the higher end AcBel's, the low end ones are overrated and mediocre.
                    Just buy delta or seasonic (or new antecs)
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Be wary of Antec.
                      A recent experience suggests they may be returning to old ways.
                      News at 11.
                      [Or rather after I have a chance for more than a quick look and can check some date codes.]
                      Mann-Made Global Warming.
                      - Dr Seuss
                      • 370forlife
                        Large Marge
                        • Aug 2008
                        • 3112
                        Originally posted by PCBONEZ
                        Be wary of Antec.
                        News at 11.
                        Umm? What kind of antec are you looking at? Almost all their units are delta, except for the TPN series which are seasonic, and Quattro series that are Enhance.
                        • Toasty
                          • Jul 2007
                          • 4171
                          Good. More business!
                          The Basiq series??
                          veritas odium parit
                          • POM_MJ
                            • Aug 2009
                            • 228
                            from your recommendations, firstly I need to replace all output caps, I think.
                            After that, more pictures will coming and burn in with big load test result also.
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3112
                              The Basiq series??
                              Maybe the old FSP based ones that were terrible, but the newer ones are delta, too.
                              http://www.jonnyguru.com/forums/show...86&postcount=1
                              • Toasty
                                • Jul 2007
                                • 4171
                                @POM_MJ -
                                Check for a cap around 2200uF near the 5vsb transformer. It will be on the other side of the 2nd heat sink in about the same position as the green output coil. That's a common failure also.
                                Toast
                                veritas odium parit
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Earthwatts EA-500D - The Delta version.
                                  The first one I looked at only had one LTEC and the rest were UCC or CapXon.
                                  The LTEC was a 1000uF in +5vsb but right in front of the fan so well cooled.
                                  Another EA-500D came in last week. Just took it apart.
                                  It's got 4 LTEC [8mm and up] and at least one TAICON 6.3mm in there right in a hot spot.
                                  Dates on parts inside suggest Sept 2008 [or later] build.
                                  I dunno the dates on the first one and it's in service so I can't check right away but I'm pretty certain [because of when I got it] that's it's an older revision than this one.
                                  - Dr Seuss
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    Oh JOY! Those are the models I received as replacements for the SP-450's.
                                    I only took a few cursory shots of the internals and the bottom of the main board. I did not disassemble the units for a clear look. One shot does show 3 Taicon's. Two are near the smaller output coil just under the mains plug. Another sits flat against a small board with a trim pot that's mounted perpendicular to the main board against the side wall at the outputs.
                                    Mains filter are 2 SamXon CH's. That's all the clear identification I can see. I can see a couple smaller ones in a dark blue with white lettering wrapper, and a chocolate brown one that's likely a UCC.
                                    I guess even Delta can be coerced into putting junk in their units. Sad day.
                                    Toast
                                    veritas odium parit
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      The 8mm and LTEC I see are either the same chocolate brown as UCC or dark blue.
                                      The 10mm LTEC I see are the same chocolate brown as UCC.
                                      The 8mm/10mm CapXons are also that same chocolate brown.
                                      All 3 brands are using the same color brown.
                                      Isn't that SPECIAL!
                                      - Dr Seuss
                                      • weirdlookinguy
                                        • Sep 2007
                                        • 1638
                                        Antec just discontinued the black Solo case, as well as the white version that came with a PSU included. These were really nice, sturdy cases with 0.8 steel, a killer glossy finish, sound-dampening sheets on the side panels, and really thick and sturdy caddies for HDDs. I have one myself, and I believe Topcat has four of them.
                                        Not-so-coincidentially, IMO, they just put out this cheapass $50 black case that feels really flimsy. I don't know (or care) what the model name/# is, but it seems like it's the Solo's replacement.
                                        I don't know if this coincides with Delta, but it's really sad to see a company that used to be known for quality (Antec) bust a China on us and go cheap like that.
                                        UPDATE: This is the case:
                                        http://www.newegg.com/Product/Produc...82E16811129042
                                        It's not TOO bad, but it feels like a toy compared to the Solo.
                                        • wnlewis
                                          New wire for my RDE3340 Whirlpool electric range
                                          by wnlewis
                                          OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                          This is a Whirlpool RDE3340 electric range.
                                          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                          Where may I find parts...
                                          01-08-2025, 11:21 PM
                                        • emeskay
                                          Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                                          by emeskay
                                          We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                                          08-06-2024, 07:13 AM
                                        • technicalspecialist
                                          Vintage fan repair, copper wire question
                                          by technicalspecialist
                                          I currently have a customer's vintage fan on the work bench to repair.
                                          It uses an induction motor with 4 poles. One of the poles is open.
                                          I couldn't find the break so i cut off the original wire.
                                          I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                                          I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                                          The enamelled copper...
                                          03-16-2023, 12:54 PM
                                          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                          12-16-2023, 08:39 PM
                                        • GlenBrim
                                          1070 GPU. DVI port removed, wire in its place, why? Stuck on low clocks too.
                                          by GlenBrim
                                          I got this recently as-is. Gigabyte 1070 video card.
                                          DVI port is removed. I don't know why.
                                          A wire is soldered across two spots where it looks like the DVI port was. I don't know why.
                                          I've read of people simply ripping out DVI ports and the rest of the cards still working fine. Never read anything about soldering a wire in there for some reason.
                                          The card seems to work fine, except it's stuck in low clock speeds. While starting a game or benchmarking, the clocks may momentarily increase to around where they should be, then goes way back down and stays...
                                          02-14-2024, 02:08 AM
