We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was still usable but text was a little difficult to read.
Since I wasn't sure if it was the LCD screen itself, I initially replaced the display cable connector (not an easy job since the screen had to be removed, but luckily there are a number of YouTube videos that really helped). However that did not change anything. Now before changing the display connector, I had to disconnect the battery. This turned out to be fiendishly difficult since the connector was impossibly tight. As a result, I managed to break one of the wires - the black one (which for some reason, the repair person had soldered to the battery connector). See the photo attachment to see the broken wire.
The laptop still works without the black wire but it needs to be plugged in all the time. I also managed (after much difficulty) to find the correct LCD screen for this 1080P touch screen model and replace that. So now the laptop is fine except for the battery connection.
My questions:
1. Is there an easy way to replace the cable?
2. Do I have to give it to a technician (as I have no soldering skills at all)
3. Would it be best to buy a new battery (Note: Battery was replaced once in 2021 after the old battery swelled up). I assume that the black wire has something to do with charging the battery and it has now not been charged since May 2023.
It is a perfectly good laptop and since I have already spent some money on it, I would rather be able to simply replace the cable.
My questions:
