Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
    • Jul 2011
    • 6066
    I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
    I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap ) the other one 1500 watts ( tap ) however between the two different settings the heater element wire is larger in diameter that the one that is 1300 watts so I going to use the larger diameter one for a low voltage unit that I also have in mind building as well
    By me saying this
    I have a very important question to ask about how do I calculate the length of the wire to act like an incandescent light when using it instead of a fuse
    I would like to have a wattage of let say 300 watt 500 watt 700 watt 1000 watt 1300 watt but I not sure exactly how to determine what length l need for each section ( one note the wattage might be different than what I have above but it is just an example)
    One note when I tried this heater at 1300 and the 1500 watt setting the coil did not glow which is a good thing but it does give a lot of heat out of it
    • Jul 2011
    • 6066
    I bought another heater this one the heater element glow when running from Ollie today and I have it ready for testing switching power supplies I just need an outside electric box and switch and outlet which I get sometime tomorrow I also ordered a voltmeter module to measure the voltage drop across the heater element to roughly estimate how much current is flowing to the device under the testing jig I will post some pictures when I have it completely done with this project
    • petehall347
      • Jan 2015
      • 4439
      seen it done for dummy loads but not as current limiter
      • redwire
        • Dec 2010
        • 3912
        An incandescent lightbulb has a 10-20:1 increase in resistance once its filament is hot. It's a bit worse with halogen lamps because their filament runs hotter.
        I measured cold resistance on 300W 120VAC halogen 3.7Ω and 60W 120VAC long-life bulb 20.8Ω
        So resistance goes up 11.5-13X and inrush current is pretty high either way.
        Resistance-wire heaters also have resistance go up when they heat up. But not as much because they don't glow super orange hot usually, they run cooler.
        You could use a heating element and then also have an ordinary low wattage like 25-40W bulb in parallel for an indicator. Or an ammeter.
        For 300-1300W that is a lot of heat to get rid of, you need a cooling fan and using a length of wire as a resistor - well it's going to just get too hot and melt the insulation, or be so long it's not practical I think.
          • Jul 2011
          • 6066
          I finally found some electrical connectors for the wire type of heater element so I can begin to put that version together and try out how well it plus the voltage meter modules came in the mail in the last couple of days ago so now it is time to put it together and see what happens next
          • redwire
            • Dec 2010
            • 3912
            What kind of connectors? The heater wire is typically nichrome or kanthal and soldering does not work I thought. Use crimp ferrules or spot welding tabs on the ends.
              • Jul 2011
              • 6066
              This is the product that I going to use to join the heater element wire to regular wire so I can make the connection between the two different types of wires
              Copper Post Connector, Conductor Range 8-14, #10 Bolt Size
              https://www.homedepot.com/p/ILSCO-Co...173825#overlay
              I though about spot welding the two different types of wires together but could not find the right type of connectors to do this type of spot welding so I decided to use a set screw type of connectors to make sure that it has a proper connection to each other
                • 31199
                dis-similar metals must be clamped or crimped
                • sigmeyer
                  Repairing a heater wire in a toaster.
                  by sigmeyer
                  First of all i just wanna say i love posting on this website and i get alot of useful feedback doing so , i just wish i could do it more often...
                  Okay , so i am currently doing nothing because of the corona outbreak thing and i was trying to repair a cheap toaster that i have...And unfortunately it is just as i thought , the heater is broken. And i was wondering what can i do about this? So here is what i tried so far
                  I have dissasembled an old chinese soldering iron and i took the heater wire from it to try reconnect the broken heater wire... and it worked untill the wire...
                  05-25-2020, 07:21 AM
                • madan1
                  Diesel heater emergency power supply / poor man's UPS
                  by madan1
                  Hello everyone.
                  Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and...
                  12-18-2022, 08:05 PM
                  Surface Mount Fuses Fundamentals Datasheet
                  TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                  TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                  10-07-2024, 06:07 AM
                • flysky
                  Gigabyte H610M S2H V2 help to identify the element.
                  by flysky
                  There is a motherboard Gigabyte H610M S2H V2 (DDR5), I can't find boardview
                  Help to identify the element, marking on the element - C31PH. It stands next to the USB 3.0 and it looks like it is ESD Protect chip. We need a datasheet to this element. Maybe someone has already identified such an element. Help please.​
                  01-23-2025, 07:21 PM
                • emeskay
                  Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                  by emeskay
                  We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                  08-06-2024, 07:13 AM
