Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
  • emeskay
    • Aug 2024
    • 6
    • India
    We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was still usable but text was a little difficult to read.
    Since I wasn't sure if it was the LCD screen itself, I initially replaced the display cable connector (not an easy job since the screen had to be removed, but luckily there are a number of YouTube videos that really helped). However that did not change anything. Now before changing the display connector, I had to disconnect the battery. This turned out to be fiendishly difficult since the connector was impossibly tight. As a result, I managed to break one of the wires - the black one (which for some reason, the repair person had soldered to the battery connector). See the photo attachment to see the broken wire.
    The laptop still works without the black wire but it needs to be plugged in all the time. I also managed (after much difficulty) to find the correct LCD screen for this 1080P touch screen model and replace that. So now the laptop is fine except for the battery connection.
    My questions:
    1. Is there an easy way to replace the cable?
    2. Do I have to give it to a technician (as I have no soldering skills at all)
    3. Would it be best to buy a new battery (Note: Battery was replaced once in 2021 after the old battery swelled up). I assume that the black wire has something to do with charging the battery and it has now not been charged since May 2023.
    It is a perfectly good laptop and since I have already spent some money on it, I would rather be able to simply replace the cable.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Do you have a multimeter and soldering iron/flux?
    The black wire is for Ground and current wont flow unless Ground is connected.
    You can easily solder that black wire to any point which is GND on the motherboard.
    • emeskay
      • Aug 2024
      • 6
      • India
      I could get an inexpensive soldering kit from Amazon. I would also have to invest in a multi-meter. Should be interesting since I have never touched a soldering iron before😀. Lenovo has a few authorized service centers in Bangalore. If they too are going to essentially do the same thing (that is solder it rather than replace the cable or the plug), then I might as well give it a try myself. Any thoughts? Thank You.
      • piernov
        • Jan 2016
        • 4439
        • France
        I'm not sure it makes a lot of sense for somebody to spend time fixing the existing battery. You can see that the data line wires are coming out of the plug and that one red wire (carrying the current from the battery) is pinched. So a proper repair goes beyond just a dodgy fix of soldering the ground wire.
        It would involve either fixing the existing cable (if it's long enough, by cutting and recrimping wires and replacing the housing) or replacing the entire cable (desoldering from the BMS board and soldering one from another dead battery for example). It's not that much work if you have the materials and experience, but still if you can find a good battery I think it makes more sense to just replace it. You can always ask a third-party repair shop what they can do for you. Lenovo will just replace the battery.
        • emeskay
          • Aug 2024
          • 6
          • India
          I contacted an authorized Lenovo repair center here and they have asked to see the laptop to check if the connector repair is feasible. I'll be taking it to them tomorrow and I'll post an update here. Thank you.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Replacing the battery will be perhaps cheaper then the bill provided by so called Authorised Service centre. Moreover,even if you decline the repair,they will charge you inspection charges.
            • emeskay
              • Aug 2024
              • 6
              • India
              I have got the laptop back from the service center. They were able to successfully repair the cable. I have attached a photo of the repaired cable. Note that they seem to have grounded the black wire in a different way.
              Nevertheless, the battery is charging now and the laptop is pretty much normal. While the service charges were higher than what I had expected, it was about 50% of what I would have paid for an new battery. So not all that bad. Also they gave the hardware a general checkup and according to them there are no serious problems but the mic is not working. I'll have to check that out as the mic hasn't been used for a long time. Also for sometime the bluetooth audio has been having a stutter. I resolved that by uninstalling some spurious bluetooth drivers. That more or less solved the problem but there is still a very slight stutter which is noticeable when listening to music. I'm attributing this to latency problems due to software/OS issues. Hopefully that will go away if I do a clean install of Windows 10.
              In any case, thank you very much mcplslg123 and piernov for your help.
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • pabloroggeri
                Lenovo V310-15ISK - It doesn't work after changing the battery
                by pabloroggeri
                Good guys. I changed the battery to a Lenovo V310-15ISK.
                The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
                When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
                08-23-2024, 12:01 PM
              • mkdj
                ASUS X571 no power : battery issue?
                by mkdj
                Mark and model: ASUS X571
                Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                Tests already made:
                - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                - I have removed...
                07-14-2025, 09:16 AM
              • mrkmpn
                Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
                by mrkmpn
                Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
                This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
                03-13-2024, 01:54 PM
              • techfreak9356
                Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                by techfreak9356
                I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                09-14-2023, 11:10 PM
