Bestec ATX-300-12Z REV.EHR
  • POM_MJ
    • Aug 2009
    • 228
    #61
    Re: Bestec ATX-300-12Z REV.EHR
    Originally posted by PCBONEZ
    Not quite got the idea yet.
    I'll give explaining another shot.....
    Within a series the ESR varies with the can size.
    In the cheap caps that end up in PSU's a ___uF 10v cap is usually physically larger than the same uF cap in 6.3v.
    Because the 10v is physically bigger it has lower ESR.
    That situation is so common that when they use cheap caps they tend to just use 10v by default.
    But... By switching to a better 'grade' of cap [the MBZ in this case] the 6.3v cap now has lower ESR than the cheap 10v cap did and is a significant upgrade without needing a bigger cap.
    Here's an example:
    Look at the CapXon KF 6.3v and 10v 1500uF [A typical PSU type cap.]
    6.3v is 10x16mm and ESR is 0.140
    10v is 10x20mm and ESR is 0.062 [same series, bigger can, better ESR]
    Now look at a better grade cap, the MBZ 1500uF
    the 6.3v is only 10x12.5mm but ESR is WAY lower at 0.026
    That's what I was trying to get across.
    You don't need a 10v cap.
    The grade change already accomplished the same thing....
    .... and in fact upgraded you beyond why the 10v was used.
    And related.
    Now look at the MBZ chart again.
    You will notice that REGARDLESS of the voltage....
    All the 10x16mm have the same ESR and Ripple
    All the 10x20mm have the same ESR and Ripple
    All the 10x23mm have the same ESR and Ripple
    - That's why I say -within a series- ESR changes with can size, not voltage or uF.
    - That is typical of good brands of caps.
    It's because their ratings are an 'at least' or 'no less than' kind of number with a realistic margin for error. Very good way to rate things for use in the real world. As a bonus, when they do things with a margin that way the true value is probably better than what you see in the table.
    If you look at the same thing in the KF chart the ESR is all over the place for a given can size.
    - That's typical of crap brands of caps.
    It's probably due to the ratings in their table being an exact number for THAT cap with zero margin for error. Not a good way to do things because in the real world the actual conditions won't match the test conditions exactly.
    Ok, I get understand now and with replaced by good caps Rubycon, I don't need to recaps again.
    Thankyou very much for your explainations.
    | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
    | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
    | 2xWD7500AYYS | 2xHD322GJ Raid0 |
    • glen65
      • Dec 2008
      • 30
      I have an Emachine with a Bestec 20 pin supply that giving me
      problems and would like to try testing this computer with
      a supply out of another machine. However there is a
      slight difference. The Bestec supply has a pink wire connected
      to the red wire on pin 11 and there is no wire on pin 13.
      But the supply in the other machine has no pink wire and
      does have a white wire connected to pin 13. Can this supply
      still be used in the Emachine?
      • POM_MJ
        • Aug 2009
        • 228
        #63
        Hi
        The pink wire on red wire is +5V sense wire for return to regulation circuit inside the PSU, some of PSU has this wire due to good circuit design of the PSU, doesn't affect to the system.
        The white wire is -5V, thats used in very old system, not see them for long time ago.
        Yes, The PSU has or has no white wire can be used.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Correct.
          The white wire [-5v] has been optional for several years now.
          The pink wire is also optional, it 'measures' [senses] the voltage on the red wire.
          [Kind'a stupid. They do that to measure at a point closest to the mobo to be more accurate. [To account for the voltage drop due to the resistance of the red wire.] The flaw in that plan is the pink wire also has resistance so they might as well measure from inside the PSU anyway. - Method was probably thought up by a wire salesman with a lot of pink wire.]
          Mann-Made Global Warming.
          - Dr Seuss
            • 31304
            the pink wire has virtually no loss because it handles no current draw.
            the design has been around forever - i see stuff from 1978 with it all the time.
            • everell
              • Jan 2009
              • 1514
              problems
              What is model number of your Bestec power supply? Check the label attached to the power supply.
              Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Yeah, and the voltage drop in 18" of copper wire is so HUGE!!!
                LOL !!!
                - Dr Seuss
                  • 31304
                  th volt-drop over 18" of copper wire will be relative to the diameter & current-flow.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    You forgot to include the resistivity for specific alloy of copper used, the diameter of the individual strands of wire, and the temperature of the wire at the time.
                    - Yeah, I know how it works.
                    It's insignificant and not -practically- measurable unless you are measuring to 3 or 4 decimal places.
                    - Dr Seuss
                    • ve3tlc
                      • Mar 2010
                      #70
                      Originally posted by everell
                      OK Toasty - I'll take a shot at it!
                      First I would like to say that most of my work with the Bestec power supplies was problems in the 5vsb circuit. My solution to the Bestec ATX-250 12E was a bit extreme, but it worked. As for the other Bestec models - I have not seen the same kind of 5vsb failures due to the pwm chip in the later models. Most of these failures have been bad caps - just like the other brand power supplies.
                      The Bestec ATX-300 12Z we are discussing here does not appear to have a 5vsb problem. One more piece of proof that the later models are indeed good power supplies when recapped.
                      The problem here is that both 5v and 12v rails are low. They are both regulated by the same regulator chip IC3 which is a AZ431 (or equivalent). The resistor from the 12v rail to the reference pin is R57 which is 24K. The resistor from the 5v rail to the reference pin is R61 which is 5.1K. The resistor from reference pin to ground is a parallel combination of R59 and R60. R59 is 3.00K and R60 is 27.0K. This parallel combination calculates to 2.70K.
                      So why two resistors in parallel between reference pin and ground? As a cost savings, rather than putting in a variable resistor to set the 5v and 12v voltage values, they put in a higher resistance than what is needed (in this case R59 which is 3.00K). Then they bridge a parallel resistance to bring the voltages into spec. So if you play with the R60 value, you will probably be able to put those voltages where you want them.
                      These resistors are surface mount resistors on the bottom of the pc board. You may or may not want to attempt changing them. Also, the R60 value on your board may or may not be 27.0K. The R59 value probably is 3.00K.
                      I realize this was an older post but it had the information I have been looking for. I have been given the BESTEC 300W supplied referenced in the post and would like to use it to power an HF radio. I need to adjust the 12 v rail to 13.6 V. It seems that changing R60 should do the trick. I don't need the other voltages so it doesn't really matter how they are affected. I am interested in the capacitor changes that are mentioned. Is it safe to assume that I should look at beefing up the 12V related caps? Is there any way of determinig what capacitors should be upgraded?
                      • 370forlife
                        Large Marge
                        • Aug 2008
                        • 3113
                        As long as they are 16V caps (which are generally what are always used on the 12v rail,) they should be fine.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          You may have to put load on the other rails to get the PSU to start and/regulate.
                          Because of that the over-all efficiency will be in the pooper.
                          ATX spec limits Ripple on +12v to 120 mV max.
                          Don't need to 'beef caps' unless that's too much noise for your application.
                          - Dr Seuss
                          • wnlewis
                            New wire for my RDE3340 Whirlpool electric range
                            by wnlewis
                            OK. I got the rocker switch figured out thanks to the good advice on this forum.
                            Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                            This is a Whirlpool RDE3340 electric range.
                            The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                            Where may I find parts...
                            01-08-2025, 11:21 PM
                          • emeskay
                            Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                            by emeskay
                            We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                            08-06-2024, 07:13 AM
                          • technicalspecialist
                            Vintage fan repair, copper wire question
                            by technicalspecialist
                            I currently have a customer's vintage fan on the work bench to repair.
                            It uses an induction motor with 4 poles. One of the poles is open.
                            I couldn't find the break so i cut off the original wire.
                            I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                            I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                            The enamelled copper...
                            03-16-2023, 12:54 PM
                            Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                            I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                            I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                            12-16-2023, 08:39 PM
                          • kalemaroni
                            Dell DC Brown wire
                            by kalemaroni
                            There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
                            08-26-2025, 10:10 AM
