Vintage fan repair, copper wire question
  • technicalspecialist
    • Jun 2010
    • 65
    I currently have a customer's vintage fan on the work bench to repair.
    It uses an induction motor with 4 poles. One of the poles is open.
    I couldn't find the break so i cut off the original wire.
    I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
    I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
    The enamelled copper wire for sale on eBay is listed in weight, SWG and AWG.
    What would the weight be for 160M of 0.35mm copper wire.
    Are these calculations accurate? It seems a lot.
    If it's broken, fix it. If it's not broken, improve it.
  • petehall347
    • Jan 2015
    • 4446
    Re: Vintage fan repair, copper wire question
    weigh the original wire
    • redwire
      • Dec 2010
      • 3912
      0.35mm I would guess is actually #28AWG 0.321mm OD because the thickness of the varnish adds a little bit.
      #28AWG, I calculate it is 212.904 Ω/km so 28Ω is 131.5m or 431.5 ft.
      You can estimate length for one turn to ballpark the length, measure inductance as well to confirm what you have.
      Inside the winding laminations it will prob. need new insulating tape, make sure the fan chassis is electrically isolated from mains. It might have have arc'd there.
      A motor rewind shop might be able to fix it more easily. They have the wire and winding machines and tape etc.
        • Jun 2010
        • 65
        I forgot to include the link to the calculator website that i used, here it is: https://www.omnicalculator.com/physics/wire-resistance
        • wnlewis
          New wire for my RDE3340 Whirlpool electric range
          by wnlewis
          OK. I got the rocker switch figured out thanks to the good advice on this forum.
          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
          This is a Whirlpool RDE3340 electric range.
          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
          Where may I find parts...
          01-08-2025, 11:21 PM
        • emeskay
          Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
          by emeskay
          We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
          08-06-2024, 07:13 AM
        • edugimeno
          Fancoil.controller with current issues
          by edugimeno
          Hi there! One friend called to say his fancoill (used for a main access cold Air courtain) controller caught fire, and asking if I could recover the half burnt board
          He said the design was too bad as this thing was probably designed for hot water only, as the board was places right underneath the condenser radiators
          I found some burnt traces and after a quick Google search for the board name (Pwr-05v-w) I could see an image of the original I was able to find where the original traces were going
          The scheme seems simple, from what I understand mains gets into the while 3 lead...
          07-26-2024, 01:02 AM
          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
          12-16-2023, 08:39 PM
          by momaka
          03-15-2023, 10:17 PM
