Dell DC Brown wire
Tags: None
The ground are indeed the ground wires.
The reds will be the power wires to supply the ~19v to the logic board.
The brown wire will be the PS_ID (power supply ID) communication line and will mate with the needle like center pin inside the DC jack. This is a 1-wire interface line used by the EC to gauge if the power adapter is suitable to power the motherboard. -
Thank you. I can't see where it should solder onto on the back of the jack. There are only 3 points - the 2 grounds and the 19v.Comment
Why do you think that there are 2 grounds?
Do you have a multimeter?
Take some measurements where are the front connections on these backside connections.
https://electronics.stackexchange.co...t-are-they-for
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by TruneHi all,
I am hoping someone may be able to help me.
I have a Dell Inspiron which originally had a faulty DC port, where the centre plastic had broke. The DC port was replaced with a new one, which then resulted in the battery not charging, the laptop running slow and a message stating that the AC Adapter was not of the correct type. In the bios it would show it as unknown.
The assumption was made that the AC Adapter must have also got damaged during whatever broke the DC port, so a genuine Dell replacement was attempted. Same issue, same message. Since then,... -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
Channel: Schematic Requests ONLY!
by harpI thinking to modify some ATX ver 1 supply, and wonder what if I connect 10k pot on 12v and center tap on brown wire? What range of 3.3v correction can to expect, or something will blow up if I close to rails, leave narrow 3.3v range?
It is KA7500B ic, but 3v3 sense is connected to TL431, I am not sure there is any connection between. - Loading...
