I've read thru most of the Antec PSU related postings, and seek help. First off, I'm a former Electronic Repair Tech, but that was in the late 70's-mid 80's. I'm pretty rusty these days, but I can do basic troubleshooting. All I have for measurement gear is a basic Fluke LCD multimeter but w/ capacitance measurement. And a Coolmax PS-224 LCD Power Supply Tester
-PSU#1
I've got an Antec Cube Case based PC I built back in 2005. It died after being in good service for 4+ years. I swapped out major components, and verified both the MB and PSU are dead. The Antec Aria Cube case uses a proprietary sized AR-300 PSU (L shaped from the side)
It has the following bulging caps, and all show leakage on top:
(1) Fuhjyyu 4700uF 6.3V
(2) Fuhjyyu 2200uF 10V
When measured w/ the coolmax, the LCD is blank, and the PSU squeals. The PSU fan does not turn.
-PSU #2
Antec SP-500 Not-so-Smartpower 500 PSU. I purchased it new 3 years ago, used in a home data server running 24/7. Started failing 4 months later. Got RMA, but flaked and didn't send it in. Tried to get another RMA recently, but told out of warranty.
It has the following bulging caps, but no visable leakage:
(2) Fuhjyyu 1000uF 10V
When measured w/ the coolmax, the LCD shows normal voltages, and the PSU squeals. One of the 2 PSU fans turns. This is when the 24pin PSU plug is connected, and 4 pin flat connector is wired. When I connect the 4pin CPU connector, the Coolmax shows 4.7-5.1V varying on “5VSB”
I don’t have schematics on either PSU, and wondering what the chances of fixing it by just replacing the visibly disfigured caps. I kinda wish there was an “Antec Cap Fix Kit” that would have enough replacement caps to cover virtually any Antec PSU, but I guess I’m dreaming.
What are your thoughts? I hate to toss them if it’s just a few caps gone bad. However, it would be a real PITA if I had to pull every cap just to test.
PS I can post some pix if that would help.
-PSU#1
-PSU #2
