Logitech Z5500 problem need help fixing
  • Exotics
    • Oct 2024
    • 12
    Here's a video I uploaded to show the problem.
    https://youtu.be/MbaZQ7aYMMY?feature=shared
    Quality isn't 1080p yet because I just uploaded it. YouTube takes a while to process videos to maximum quality.
    I have a multimeter and basically no electrical fixing knowledge.
    I came across a post on here describing the same issue if it helps y'all help me. -> https://www.badcaps.net/forum/troubl...500-done-today
    please help me diagnose and fix it.
    thanks
  • Exotics
    • Oct 2024
    • 12
    Hello?
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8180
      I guess if you want for others to chime in, you need to upload some straight shot, high resolution pictures using the attachment function. Otherwise it’s like my car broke, help me fixing it. The other thread points to some diodes to check, did you do that?
      • Exotics
        • Oct 2024
        • 12
        I just explained I know nothing about electronics. I need guided step by step help
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8180
          Here is a schematic for it. Open that sucker up, take it apart (snap some pics while you are taking it apart so you know how it goes back together), post the pictures of the board(s).
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8180
            Watch some “Logitech z5500 teardown or repair” videos on YouTube.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8180
              So this schematic doesn’t include the console, where the problem is supposed to be. So far I haven’t found anything that includes that console.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8180
                Dannyx did repair such thing at one time, maybe he can remember something.
                • Exotics
                  • Oct 2024
                  • 12
                  Update
                  I had given the speakers to my local mobile repair shop who said they'll try to diagnose it (it's free for diagnosis), and I sent them the link I posted here to the forum post of the guy who had the same issue and fixed it, but they told me they went over it with a multimeter but couldn't find the fault. They also stressed they are just a mobile repair store.
                  I called around but no one fixes speakers near me.
                  I will need help fixing this. I'll post photos of the circuits once I go and collect the speakers.
                  • Exotics
                    • Oct 2024
                    • 12
                    Hello
                    I've now taken many photos of the control pod circuit board. Both sides.
                    Because of how many photos I took it's spread over 2 links.
                    https://imgur.com/gallery/ACUaIhO
                    https://imgur.com/gallery/fob5bXT
                    My phone ran out of battery while taking photos of subwoofes circuit board so I'll take and post the rest later.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8180
                      I think the problem is in that control console and there should be some diodes to check. As for making pictures, just take them straight shot front and back, high resolution and attach them to the post with the attachment function.
                      • Exotics
                        • Oct 2024
                        • 12
                        I took over 50 photos. Please click the links to see them.
                        I don't have an expensive professional camera. I have my phone and a g7x which has basically the same sensor size as my phone.
                        I can retake the photos using the g7x if you want.
                        I have no resolution options on my Samsung Galaxy S20, and you can see from the photos it has a bokeh effect.
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8180
                          I just use my IPhone and don’t use a DSLR either. Keep the pictures straight, much easier to see.
                          I did see some sad looking solder joints somewhere that you should touch up in the first batch of pics. Put your DMM in diode mode and poke around on these diodes. A regular diode should measure something like 0.6 or 0.7 on your DMM and backwards it should read OL. There are some Schottky diodes that have voltage drop of 0.2 and that’s normal. If you get to a diode that has a reading both ways, just lift one leg and redo the measurement (it depends on the circuit).
                          A good rule is this; When in doubt, take it out!
                          Thats all I got left for tonight.
                          • Exotics
                            • Oct 2024
                            • 12
                            Sir. I'm sorry but I know nothing about electronics. Please provide a simple step by step guide. Thank you so much.
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8180
                              You have a DMM (digital multimeter), put it in diode mode. Put one probe on one end of the diode and the other probe on the other end of the diode and take a reading. Then reverse the probes on the diode and take another reading.
                              A good diode has a reading of 0.6 or 0.7 on you DMM and when you reverse the probes it should rear OL (open lead)
                              A bad shorted diode, your DMM should beep and show 0.00.
                              Also a bad open diode shows OL in both ways.
                              Maybe YouTube how to check a diode and it should visually explain it to you no problem.
                              • Exotics
                                • Oct 2024
                                • 12
                                Tested both diodes in control pod. 0.751 each. Reversing the probes gives 1.995 on one and 1.910 on the other. Photo of what I tested attached.
                                Also photo of what setting I put MM on.
                                • Exotics
                                  • Oct 2024
                                  • 12
                                  It won't let me upload the photo. So here it is
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8180
                                    O.k. You found possible candidates, as they are not measuring up. You got 0.75 forward bias, but you got a reverse bias reading as well. Problem is, we don’t know why. Is it because of the circuit, or is it indeed the diodes fault.
                                    Now you have to lift one leg (unsolder one side of the diode, which one doesn’t matter) and redo both measurements. The forward bias is right, but in the reverse bias there shouldn’t be anything.
                                    • Sam Scarbo
                                      • Oct 2023
                                      • 38
                                      The post you quoted said the 2 MELF diodes are causing problem as mentioned in that post. They are probably referring to D700 and D701. These are the only MELF diodes i can see in the control pod from your pictures. The post mentioned to replace with some diodes like BAV103. The U701 LM317 plastic casing seems deformed or just dirty in the pictures. You should check all 3 LM317's voltages. That post said they should output 5v, 3.3v and 2.5v. Good luck.
                                      • Exotics
                                        • Oct 2024
                                        • 12
                                        Am I supposed to be checking all this with the control pod powered up? What I checked so far was with it NOT powered up.
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • render1967
                                          Problem with the Logitech G27 gaming steering wheel gear lever
                                          by render1967
                                          Hello! First, please excuse me if my English is not good enough because it is not my native language!
                                          Now let me describe my specific problem. For two days, the gear lever on my Logitech G27 has shown the following defect. When switching in the game (for example ETS2) it often does not detect 1st, 3rd and 5th gear - in these positions it shows neutral or flashes between the specific gear and neutral (for example - 1st <> neutral). When I press the gear lever to the left or right while it is in a position, it still manages to guess the gear and engage. In addition, instead of rear...
                                          11-13-2021, 01:35 PM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                          LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech ThinkCentre M i5-9600T Specification for Upgrade or Repair
                                          This specification for the LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre ThinkSmart Edition Tiny M920q for Logitech boardview and ThinkCentre ThinkSmart Edition Tiny M920q for Logitech schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                          09-12-2024, 01:58 PM
                                        • Gibon378
                                          Problem with stopping audio and video for no reason
                                          by Gibon378
                                          PC Specs:
                                          • CPU: Ryzen 5 1600
                                          • GPU: GTX 1080 Palit JetStream
                                          • MOBO: ASRock ab350 PRO4
                                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                          • PSU: XFX 650W (don't remember what model)
                                          • OS SSD: ADATA SP920
                                          • OS: Windows 10 21H2
                                          Problem description:
                                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                          11-19-2022, 09:41 AM
