Axle typhoon ax-p400l (400W) PSU Dead
  • DesperateDude
    • Aug 2016
    • 36
    • Sri Lanka
    Hi people
    I came here looking for helps I saw how you guys helped for PSU repairs. Let me tell you my story
    I have an Axle typhoon ax-p400l PSU which is 400W but suddenly it stopped working because of a lightning strike which came from Network port.
    You may have not heard of this PSU, it's a Chinese made PSU not a high end one like expensive ones over there, but it did me a decent job.
    Computer was intact but is PSU dead.
    I checked it with my digital multimeter and I saw all the cables have power but it was very low. Like around 2V from 12V cable and etc.. Everything I measured had similar problem. All the pins were around 2V or lower.
    So I disassembled the PSU and saw only a 10 ohms resistor was burned but still worked with a burning smell. This resistor is connected to the VCC pin of SG6105DZ. So it seemed like a failure with the IC but I tested some more and saw getting 6V for that said VCC pin.
    Now comes the unfortunate part
    When I was testing these I accidentally shorted 2 main capacitors of the primary.
    Then I tested and shocked to see no power to the secondary side.
    There is a DM311 in the primary side and I tested that too. It was not getting any voltage for its VCC pin.
    Then I tested all the components near that IC. Found an opened 1ohm resistor and I replaced it. But no avail.
    So I checked everything in primary side with my digital multi-meter. And found nothing..
    Then I decided to replace all ICs of the board. There is another IC labeled as WT7518D near that SG one.
    Then I checked and no changes. Then I went desperate and checked all the components which I couldn't check before.
    Only things I didn't check were non fusible resistors and small electrolytic capacitors.
    I found only 2 components burned. One was C12 5T Zenner diode (went open) near SG6105 and the optocoupler labeled as 817CN (LED side was burned)
    I even checked the 3 transformers.
    Even after doing all these no changes (Replaced Optocoupler and replaced Zenner diode with a 12V one). No power to transformers and nothing for secondary side.
    I had enough and thought to ask from you geeks
    PS: I don't have an ESR meter or Capacitance tester. All did using the digital multimeter.
    I am attaching pictures of circuit below..
    Sorry for the long story and there may be some grammatical errors in my English because I wanted to type fast and let you guys know
    Thank you
    Frontside 1
    Frontside 2
    Backside
  • DesperateDude
    • Aug 2016
    • 36
    • Sri Lanka
    Re: Axle typhoon ax-p400l (400W) PSU Dead
    Also I forgot to mention this before,
    3.3V output is shorted to the Ground too.
      • 31068
      check the 3.3v diode - dont be tricked by any low value load resistors
      • DesperateDude
        • Aug 2016
        • 36
        • Sri Lanka
        Hi
        Thank you for replying
        As I said earlier I checked all the diodes and fusible resistors (Not just fusible ones I checked some other ones too but not all) but didn't find any problematic ones. I am clueless
          When you said shorted to GND, what resistance are you seeing? <1 Ohms? There has to be shorted component in that 3.3V Output section. What do you get when you remove the rectifier or Zener protection diode in that section, the shorts go away? Something is being overlooked.
          • DesperateDude
            • Aug 2016
            • 36
            • Sri Lanka
            Thanks for the reply budm.
            I checked using continuity test mode and I get a beep and a resistance of 17 ohms.
            Also for 12v line I get a sudden beep and then resistance increases. I think that's normal and that's because of the related capacitors.
            I checked all the diodes there also even transistors (little ones which were even near the Fan connector) but found nothing..
            But I couldn't check for shorts after removing the diodes when I was testing the PSU.
            Also by the way I see something very strange that is, There is a transistor of the secondary side. Which is a big one and also connected to the heatsink with the 2 schottky diodes.
            And all 3 pins of that one are shorted with each other. This is only when the transistor is soldered to the board. And after removing, transistor was tested good. Only happens when installed back.
              17 Ohms is not shorts. Continuity mode in the meter is only good for checking the continuity from point A to point B, not for checking for shorts circuit.
              Some meter will beep with up to 100 Ohms resistance, it beeps does not mean it showing shorted circuit.
              That resistance reading may be the bleeder resistor.
              You have to do more tracing on the board.
              • DesperateDude
                • Aug 2016
                • 36
                • Sri Lanka
                Thank you for the correction.
                Yes the meter do sounds even for 12 ohms.
                For your information, as I said earlier I did check almost everything and confused then I had no choice but to ask from you guys
                • DesperateDude
                  • Aug 2016
                  • 36
                  • Sri Lanka
                  Anyone?
                  • joshnz
                    • Feb 2011
                    • 969
                    • New Zealand
                    resistance of vcc of DM311
                    My pc
                    CPU : AMD PHENOM II x4 @ 3.5Ghz
                    MB : ASUS M4A89TD PRO USB3
                    RAM : Kingston ValueRAM 16gb DDR3
                    PSU : Cooler Master 850W Silent Pro
                    GPU : ATI Radeon HD 6850
                    • DesperateDude
                      • Aug 2016
                      • 36
                      • Sri Lanka
                      Thank you for the reply,
                      As I remember it has no voltage and also no meter readings for ohms.
                      To check better, to what pin I must connect negative probe of the meter? Ground pin of DM311 or common ground ?
                      Thank you..
                      • DesperateDude
                        • Aug 2016
                        • 36
                        • Sri Lanka
                        Hi
                        I just measured the resistance and I got 20.7K
                        • joshnz
                          • Feb 2011
                          • 969
                          • New Zealand
                          Do you have standby power?
                          My pc
                          • DesperateDude
                            • Aug 2016
                            • 36
                            • Sri Lanka
                            No no power. Nothing at all..
                            Even secondary side of the PSU circuit has no power. SG6105DZ not even getting VCC power.
                            Basically no power is supplying to the secondary side from the primary. All the transformers have no power at either side. DM311 only getting 7V for its 8th pin and around 300V for its 5,6 and 7 pins.
                            • DesperateDude
                              • Aug 2016
                              • 36
                              • Sri Lanka
                              Any one?
                                • 31068
                                get a DM311 datasheet and look at the example schematic
                                • DesperateDude
                                  • Aug 2016
                                  • 36
                                  • Sri Lanka
                                  But that's the first thing I did when started to repair this
                                  • DesperateDude
                                    • Aug 2016
                                    • 36
                                    • Sri Lanka
                                    Hi Guys,
                                    After around 2.5 years I've decided to repair this again.
                                    So here is what I did,
                                    I had 2 more DM311 ICs around, I don't know if they are good or bad. So I tried them all.
                                    Same issue and PSU doesn't turn on. But I saw something new.
                                    For one IC I got around 1.3V for the 5th pin which is the Vstr pin.
                                    And I tried the other 2 ICs too. Then for those 2 I got around 6.6V for the Vstr pin and that's all I got.
                                    No power to the secondary side (Not even 5v standby) or no power to the Vcc pin (pin 2). I've checked all the diodes ,capacitors and resistors around the IC but non of them were bad.
                                    I also noticed getting around 0.37v for the Optocompler's anode and cathode.
                                    But that's all I saw. I am going to order some more DM311 from eBay to try swapping the current ones.
                                    In the meantime could you guys help me out with this if you have any ideas? Are the transformers bad or anything else? I've checked the transformers with the multimeter.
                                    I really appreciate any help you are willing to give me..
                                    In case of if you can't view my old uploaded images of the circuit board. Here are new links
                                    https://www.dropbox.com/s/lbch7ytz4n..._0007.jpg?dl=0
                                    https://www.dropbox.com/s/ez9yrgypa0..._0008.jpg?dl=0
                                    https://www.dropbox.com/s/a5b0ngljcy..._0009.jpg?dl=0
                                    Thank you.
                                    • DesperateDude
                                      • Aug 2016
                                      • 36
                                      • Sri Lanka
                                      Anyone?
                                      • Sparkey55
                                        • Jan 2010
                                        • 1523
                                        Hi Guys,
                                        Thank you.
                                        Please post photos using the attachment button. Off site hosting of photos is a real pain in the butt.
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • zunasthegreat
                                          Chieftec GPS-450-AA with dead 20N60C3
                                          by zunasthegreat
                                          Hello everyone hope all doing well!
                                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                          09-01-2024, 07:12 PM
                                        • Beton
                                          Finding a dead short component
                                          by Beton
                                          Hi guys!
                                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                          I have a bench PSU and if I try to inject voltage the voltage...
                                          12-10-2021, 01:05 PM
                                        • FiguringITout
                                          MSI Raider GE75 - Not posting, probable dead CPU
                                          by FiguringITout
                                          Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                          Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                          07-25-2024, 07:27 AM
