How to test mosfets in parallel circuitry
  • Schorsch87
    • Feb 2013
    • 55
    Hey guys,
    I have the question mentioned in the title. Is it possible to get the bad mosfet within a parallel circuit?
    I think i read something about a current limited supply and look which of the transistors is getting hot?
    Would this work without destroying another parts on the board?
    Best reagards
    Re: How to test mosfets in parallel circuitry
    Test it off the board if the reading looks bad when test it on board.
    • Schorsch87
      • Feb 2013
      • 55
      One of the right 4 couples on the picture is bad. I measure a short. So it would be best to solder them off. Maybe it's not the last one which is bad
        It is not easy narrowing down the bad parts when they are connected in parallel. You can use low voltage high current source to find out which one will get hot.
        • CapLeaker
          Leaking Member
          • 8161
          or an ultra sensitive ohm meter.
          • Schorsch87
            • Feb 2013
            • 55
            This is what I wanted to hear. Maybe I will try this.
            Thanks you.
              Since the MOSFET has body Diode you will want to make sure that you connect the power supply in the reverse polarity of the body diode in case the shorted MOSFET blown open circuit when the power supply is connected to it.
              • rievax_60
                • May 2012
                • 897
                • australia
                The Gates usually have individual series resistors. Comparing G-D and G-S resistance usually finds the faulty MOSFETs.
                • sententia
                  • Oct 2013
                  • 269
                  • Greece
                  You can also use the millivolt range of you DMM (or diode testing), most of DMMs have, and measure the smallest voltage drop to ground while supplying a safe voltage (for that rail) from a current limited supply, 0.25A should be ok.
                  However this is to find the shorted one and not to check if a fet is good....
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    I sometimes use my esr meter to find which device had lowest resistance across lol
                    • TechGeek
                      Computer Geek
                      • Jan 2015
                      • 2254
                      As in 5VDC@100A?
                      Permanently Retired Systems:
                      Kooky and Kool Systems
                      sigpic
                        1~2V 5A, just enough to heat up the shorted parts, we do not want to explode the parts and causes more damages to other part when it goes open circuit.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Originally posted by TechGeek
                          As in 5VDC@100A?
                          Lol thats 500w across a shorted device, think it might smoke a little would probably melt the bloody probes used to test
                          • TechGeek
                            Computer Geek
                            • Jan 2015
                            • 2254
                            lol
                            sigpic
                            • goontron
                              5000!
                              • Dec 2011
                              • 4108
                              • US
                              dont knock it till you try it! i dumped 1800w (12v @ 150A) through a 24v circuit to find a short. Shorted ceramic disk cap was glowing orange!
                              Follow the white rabbit.
                              • chth96
                                How Can I test PWM DM0365R?
                                by chth96
                                Hello
                                I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                06-18-2025, 04:14 PM
                              • BlackScreen_22
                                Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                                by BlackScreen_22
                                Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                                Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                                I had no problems connecting mosfets and capacitors,...
                                08-27-2024, 12:46 PM
                              • khelane
                                test active pfc power with lamp test
                                by khelane
                                Hello
                                I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                Is there a way...
                                06-03-2025, 01:00 AM
                              • chronic519
                                Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                                by chronic519
                                Hello.
                                GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                                Found issue with a RAM block
                                Replaced, green lines gone.
                                Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                                Used a good card to test and same results low errors 32+.
                                I am just search for some form of command to do a full test on the GPU.
                                I just ran the mats command with my good GPU and passed after roughly 40 min.
                                The repaired one, ran...
                                05-20-2025, 07:56 PM
                              • kotel studios
                                Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                                by kotel studios
                                Finally got time to fix this board up.
                                At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                                Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                                04-22-2025, 05:08 AM
