Mats / mods: detected and repaired GPU fault. Cant seem to test after!
  • chronic519
    • Feb 2015
    • 13
    • canada
    Hello.
    GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
    Found issue with a RAM block
    Replaced, green lines gone.
    Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
    Used a good card to test and same results low errors 32+.
    I am just search for some form of command to do a full test on the GPU.
    I just ran the mats command with my good GPU and passed after roughly 40 min.
    The repaired one, ran for hours with no result. Just stopped after the 8 hour mark.
    what command do I use to do a full test to ensure the RAM is good?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3658
    • slovakia
    Originally posted by chronic519
    Hello.
    there is no good stability testing. best use game like cyberpunk that put load on core and memory
    • SiO2
      GTX 1070: No output, VRAM? Issues with mats
      by SiO2
      I have an Inno3D Herculez X3 GTX 1070, which does not show any image. After ~30s, the monitor turns on and displays a black screen.
      The card however is detected by the OS, GPU-Z shows 0 MB VRAM. The driver crashed during boot.
      Visually the card is in very good condition. No visible signs of defects, all voltages are present and within reasonable range, but on the high side I think: Vcore = 0.9 V, Vmem = 1.5 V. Vcore measures ~250 mOhm according to my DMM.
      This leads me to the assumption, that something VRAM-related is off. So the natural first step...
      04-23-2022, 05:44 AM
    • maurinaz
      Request: NVIDIA MATS/MODS UEFI payload for RTX 4070 Laptop (GN22-X11 / AD107)
      by maurinaz
      Hello everyone!
      I need the UEFI-compatible version of NVIDIA MATS/MODS to test VRAM on a
      laptop RTX 4070 GPU (GN22-X11 / AD107). My MSI Stealth 16 Studio laptop
      is UEFI-only (no CSM), so I specifically require the mats.efi payload
      that works on Ada GPUs.
      Local repair technicians here do not have MATS/MODS versions that support
      RTX 40 series, so I need the proper UEFI build (v2.0.0 or newer).
      If anyone can share the correct MATS/MODS package for Ada (UEFI boot),
      or any documentation on how to run mats.efi on RTX 4070 Laptop GPUs,...
      12-10-2025, 03:08 PM
    • klugec
      KVA2 RTX 2060 Super 8GB Desktop artifacts
      by klugec
      Hello (sorry for my bad English),
      I have a strange problem with my KVA2 RTX 2060 Super. As soon as Windows 11 is loaded, artifacts appear. Now the crazy thing: When I start Furmark the artifacts are gone and Furmark runs great without crashing. Mats test shows me no errors (PASS). Drivers can also be loaded without any problems.
      Mods shows me the following error:
      Code:
      MODS start: Thu Feb  1 19:16:00 2024
      Command Line : gputest.js -oqa -old_gold -test 94 -dramclk_percent 100 -ignore_fatal_errors -run_on_error -fan_speed 70 -matsinfo
      02-01-2024, 10:58 PM
    • Maxim Bojko
       Palit RTX 2080 Super Jetstream Mats/Mods help
      by Maxim Bojko
      I have a RTX 2080 that is broken, but interesting thing is that the card works how it should work, but when playing the card crashes, black screen fans go to 100% and nothing happens anymore. I changed thermal paste because I thought it was overheating, but no. So I checked with gpu z and here is what I had.
      After a while a dude I got friends with told me to underclock the gpu via msi afterburner. First to underclock the core speed by 200 then open the chart for the mhz and voltage and said that I should change the mhz at 0,9v to 1900mhz. Since then I doesn't crash...
      09-18-2024, 04:18 PM
    • chth96
      How Can I test PWM DM0365R?
      by chth96
      Hello
      I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
      So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
      I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
      I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
      06-18-2025, 04:14 PM
