500 watt cutie
  • everell
    • Jan 2009
    • 1514
    500 watt cutie
    Here is a 500 watt cutie. It arrived with stuck fan, output capacitor on all three rails were bulging, one of the diodes on the 5 volt output rectifier was shorted, and the FET linear regulator on the 3.3 volt rail was shorted. I replaced the S20C40 output rectifier in the 5 volt rail with a S20C45 from my junk box. I figured that an extra 5 volts wouldn't hurt. I replaced the CEP3120 FET in the 3.3 volt rail with a CEP603 from my junk box. It was only 5 amps less than the original, but probably wouldn't hurt. The output rectifers on the 12 volt rail are two single diodes soldered to a small frame. They measured OK. I had a fan of the exact same brand in my junk box, so replaced the fan rather than repairing the old one. This 500 watt cutie uses a pair of 13007 transistors for the switching circuit. Input main capacitors are RICON 330 uF/200 volts. The Y caps are ceramic capacitors, a money saving Chinese innovation. Diodes used for the input bridge rectifier are 1N4004. There is no line filter, just jumpers where the line filter transformer should go. I replaced the bulging RICON capacitors in the output circuits with capacitors of equal voltage rating and equal capacitance from parts in my junk box. The output circuits do not have pi filters, just a single capacitor.
    This 500 watt cutie is now working. Just need to find a mother board that needs 500 watts so I can test the power supply under load!
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: 500 watt cutie
    Haha wow 200w maybe lol good job at fixing it though
      • 31087
      Re: 500 watt cutie
      Everell, are you going through bin's or something?
      those half assed things with a partial fan-frame & very thin cases are usually just thrown in a skip as soon as they are removed from the case they often come free with!!
      • chowder
        • Feb 2016
        • 44
        Re: 500 watt cutie
        Wow... I wouldn't trust that POS for 150W, nevermind 500!
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3264
          • Singapore
          Re: 500 watt cutie
          errr why would u be calling this psu a cutie? it aint exactly a chick! even if it was, her body is cheap, her clothes (labels) are cheap, her insides and her head are all empty and her fans? well... she has none to speak of. i'd put a paper bag over her head anyday...
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Re: 500 watt cutie
            Im pissing my self over that haha
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Re: 500 watt cutie
              Please do, I'll bring the popcorn
              Legendary man!
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Re: 500 watt cutie
                Unpopped kernels would be fine, there will be a heat source to pop them at the event.
                • everell
                  • Jan 2009
                  • 1514
                  Re: 500 watt cutie
                  ^ Sounds about right. The original fan was stuck......really stuck bad. I replaced it with one that looked brand new, same brand label. There is no fan controller, the fan is wired directly to 12 volts. When I turn it on, sounds like a thrashing machine. So I don't think the fan will last long. Then the popcorn starts popping!
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    Re: 500 watt cutie
                    great for practice work but the end result isnt worth the energy the soldering iron consumed.
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      Re: 500 watt cutie
                      +1
                      Here, it's easy to find psus for free that are much better than this and definitely worth repair / recapping.
                      • everell
                        • Jan 2009
                        • 1514
                        Re: 500 watt cutie
                        The day has arrived.......this was intended to be an April Fool's Day joke. For those that "might" be wondering, this is an Okia 500ATX. Hopefully nobody seriously thinks I will be attaching this power supply to a real computer!
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          Re: 500 watt cutie
                          Dang. You got us good with that one!
                          Made my day with this.
                          Not going to fix the old one? I thought you revived everything broken . I guess I beat you on the epic fan revival. I had a stuck Mitachi Spacefan that was so stuck, that I actually needed to hammer out the shaft away from the sleeve bearing. Shaft broke from the fan blade assembly in the process, but I glued it back together after getting the shaft out and cleaning the bearing. Fan works now, though it is slightly off balance and a bit noisy.
                          But other than that fan, my other (previously stuck) fans work flawlessly after I rebuilt them.
                          • TechGeek
                            Computer Geek
                            • Jan 2015
                            • 2254
                            Re: 500 watt cutie
                            Permanently Retired Systems:
                            Kooky and Kool Systems
                            sigpic
                            • dmill89
                              • Dec 2011
                              • 2534
                              Re: 500 watt cutie
                              Looks like they keep increasing the rating on these without actually doing anything to the actual components inside. I opened one of these up several years ago (identical inside) that claimed to be a "420W" (couldn't handle 150W for more than a few minutes in reality).
                              https://www.badcaps.net/forum/showpo...&postcount=411
                              • kaboom
                                "Oh, Grouchy!"
                                • Jan 2011
                                • 2507
                                Re: 500 watt cutie
                                40A on +5???
                                There's nothing that'll handle 40A in that thing, unless it's on fire.
                                Gotta give em a little credit- the +5VSB transistor is on the heatsink.
                                [song]
                                "Oh Deer, what can the matter be?"
                                [/song]
                                "pokemon go... to hell!"
                                EOL it...
                                All style and no substance.
                                guilty,guilty,guilty,guilty!
                                guilty of being cheap-made!
                                • Nagy Daniel
                                  Lowest possible resistance on laptop motherboard rail - Guide Table request
                                  by Nagy Daniel
                                  Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                  I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                  I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                  So, I generated a table with AI so I can...
                                  03-04-2025, 08:24 AM
                                • Victor Moreira Silva
                                  Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                  by Victor Moreira Silva
                                  I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                  Well, my decice specs are the following:
                                  Model: Acer Nitro 5 AN517-54-55T5
                                  CPU: Intel Core i5-11400H
                                  GPU: NVIDIA GeForce GTX 1650
                                  Motherboard: GH51G LA-L181P Rev:1c
                                  The symptom:
                                  When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                  05-26-2025, 10:49 AM
                                  KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                  by momaka
                                  For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                  http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                  I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                  What mostly drew me into buying it is its 2x PCI-E power connectors...
                                  03-29-2022, 11:34 PM
                                • lefetylorant
                                  Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
                                  by lefetylorant
                                  Hello Everyone,
                                  Long story short, I got this unit for very cheap.
                                  I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
                                  I've performed some measurements:
                                  - 20V rail perfectly...
                                  09-14-2023, 05:05 AM
                                • fab13
                                  0 Volt PEX Rail on Zotac GTX 1080 8 GB OEM- No short help
                                  by fab13
                                  Hello to all,
                                  I'm struggling with this card lol Zotac GTX 1080 OEM 8 GB
                                  After checking there was a short circuit on the 1.8V from a capacitor and I had no voltage and now I have my 1.8V voltage.
                                  Other problem I do not have the voltage PEX Rail 1Volts and measured value 48 Ohm seems correct.
                                  Measured 3.3 V and 12 V and 5 V OK and 1.8 V OK to the coils
                                  Missing Vcore between 0.8 V and 0.9 V and VEM 1.5 V (Rather normal because no 1 V PEX)
                                  1 ) After checking the controller uP1728QBDDA (See photo Missing PEX) there...
                                  08-21-2022, 08:51 AM
