Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
  • lefetylorant
    • Sep 2023
    • EUs shithole
    Hello Everyone,
    Long story short, I got this unit for very cheap.
    I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
    I've performed some measurements:
    - 20V rail perfectly ok
    - 3v3_S5 and 5v_S5 rails are ok
    - The 3,3v rail which should power the SiO chip is not OK, there is 0v on that rail.
    - As I've understood the schematic, that rail is connected to the 12V rail which also does not have any voltage.
    Currently I am a bit stuck, Ive checked the capacitors and resistors around the FETs and the buck regulator, those are measuring OK.
    PQ1103 which is the high-side MOSFET of the Buck regulator receives 20v, but there is no 12v coming out from this circuit. PQ1102 is the low side MOSFET, and the buck regulator itself is PU1101 on the schematic.
    I've also found some interesting thing, there is a rail that is called 3V3_DWS, it is perfectly ok, but there are other rails such as the 3V3_DSW_G0, G1, G2.
    G0 measures fine it has 3.3v, G1 has 0v, G2 has 8,37v.
    These voltages (G1, G2, G0 is coming from a signal called SLP_SUS#) are connected to the 20V rail via a resistor so I guess these resistors are damaged.
    I've uploaded the schematic and the boardview:
    https://www.badcaps.net/forum/showthread.php?t=123548
  • reformatt
    • Feb 2020
    • 1510
    Re: Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
    +SIO_SB3V should be present at the EC (if +3V3_DSW and +3V3_S5 are indeed present). The rest of the supplies are switched on by PS_ON# from the EC after power button is pressed (ONOFF# from SW1, should be pulled high and go low when pressed). Refer to your power sequence on pg 60 to help troubleshoot. You won't get any 12V till you have PS_ON# from the EC.
      LENOVO ThinkCentre M920 + ThinkCentre Tiny-in-One (TIO) 24 Gen3 ThinkCentre M i5-8500T Specification for Upgrade or Repair
      This specification for the LENOVO ThinkCentre M920 + ThinkCentre Tiny-in-One (TIO) 24 Gen3 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M920 + ThinkCentre Tiny-in-One (TIO) 24 Gen3 boardview and ThinkCentre M920 + ThinkCentre Tiny-in-One (TIO) 24 Gen3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
      09-12-2024, 01:58 PM
      LENOVO ThinkCentre M720q + ThinkCentre Tiny-In-One 24 ThinkCentre M i5-9400T Specification for Upgrade or Repair
      This specification for the LENOVO ThinkCentre M720q + ThinkCentre Tiny-In-One 24 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M720q + ThinkCentre Tiny-In-One 24 boardview and ThinkCentre M720q + ThinkCentre Tiny-In-One 24 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
      LENOVO ThinkCentre M72e Tiny ThinkCentre M G470 Specification for Upgrade or Repair
      This specification for the LENOVO ThinkCentre M72e Tiny can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M72e Tiny boardview and ThinkCentre M72e Tiny schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
      09-12-2024, 03:36 PM
      LENOVO ThinkCentre M72e Tiny ThinkCentre M G460 Specification for Upgrade or Repair
      LENOVO ThinkCentre M72e Tiny ThinkCentre M G465 Specification for Upgrade or Repair
